I'm trying to find the Hugall Hoile RB1 manual.
Hugall Hoile irrigation system.
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: Our auto irrigation system wouldn't turn off. We found the Davey XJ70 pressure pump was leaking so replaced the leaking pipe. Now the watering g system won't start. What do we do?
Hi Geralidine
Sounds like your pump is "air bound"...meaning that the impeller housing of the pump is full of air, and it cannot pump water.
Try bleeding the air out of the pump and put a positive pressure (garden hose pressure) and make sure that you shut the airbleed valve off after you start to pump.
Please take time to rate me
Bud
Posted on Mar 31, 2013
What is a Drip Irrigation System?
According to Wikipedia "Drip irrigation, also known as trickle irrigation or micro irrigation or localized irrigation, is an irrigation method that saves water and fertilizer by allowing water to drip slowly to the roots of plants, either onto the soil surface or directly onto the root zone, through a network of valves, pipes, tubing, and emitters. It is done through narrow tubes that deliver water directly to the base of the plant."
Sep 10, 2013 | Garden
Tip
Drip it don't drop it
The popularity of Drip Irrigation Systems has been rising in the past years. It is true that this method of irrigation is usually a bit more expensive than sprinklers and isn't as resistant on the long run, but on the other hand the water saving and the system's efficiency definitely make it worth it. So why not giving it a try?
First of all, this system waters plants and flowers more slowly and the water goes straight to the roots, so no water goes to waste.
Moreover, it requires to be activated with less frequency than sprinklers.
In most countries it's one day of irrigation every week during the winter, two days during spring and fall and three during the summer.
Did you get one yet?
If you did here are two basic suggestions to start and keep up a satisfying drip irrigation system.
1. In order to figure out how long to leave it running, you can measure how much water your emitter produces and according to that and your plant's needs, set the system's timer.
So take a spoon and measure how many seconds the system takes to fill it up.
14 seconds = 1 gph (gallon per hour)
7 seconds = 2 gph
4 seconds = 4 gph
If your system is of the first kind, producing 1gph, usually you should leave it running for about 90 minutes, if it's the second (2gph) for about 60 minutes and if the third (4gph) for about 30 minutes.
(If your plants require a higher-flow emitter you can get one that produces up to 20 gph and leave it for about 12 minutes each watering.)
2. In order to keep your drip irrigation system in good shape check its line periodically for breaks, or its emitters for clogs.
Make sure that each emitter releases the right amount of water.
Also you should flush the drip irrigation lines and filters about twice each year. You can do this by uncapping the end cap on the drip line and letting water flush through the line.
on Sep 10, 2013 | Garden
Hi Geralidine
Bud
Mar 31, 2013 | Plumbing
Reebok RB1 display fades
Run the software calibration for easy troubleshooting, and fix it.
However adjust the REED switch, clean it, and tight all plug or connector very well.
Please read you instr. manual or download from
www.iconservice.com
God bless you
Nov 24, 2012 | Exercise & Fitness
My Raindrip timer for drip irrigation doesn't work and the owner's manual does not say how to open it up to get to the battery. It also doesn't say how to operate or set the damned thing.
Here is a manual for a rain-drip system, you did not say the system number, hope this helps Tim:
http://waterheatertimer.org/pdf/Raindrip-R673CT.pdf
May 19, 2011 | Garden
No set-up for a Naan Irrigator greenhouse 8x6x7
try this link
http://www.naandanjain.com/e/Knowledge_Desk/Greenhouses%5B107%5D.htm
Jul 30, 2009 | Rion 8x8 Hobby Greenhouse
Irrigation system problem
How big is your pump? How much HP rating? It could be a case of blocked water line. Just check your pipe lines and the gate valve for blockage. Just your e-mail
for your comments.
Jul 04, 2009 | Plumbing
160 people viewed this question
jasbo
jasbo
