Question about Dishwashers
I have a Technika Dishwasher TBD4SS-2 it does not clean the dishes on the bottom shelf?
I just had the same issue on a Technika TSX6SS-2.
Called in a service tech to fix it and it was a little clip under the machine that was putting it into Half Load mode (although the light on the panel wasn't indicating it was). The spring / clip on the clip had broken due to corrosion from the tablets (according to the Tech).
He removed it and all is working OK again - although I can't (and never did) use the Half Load option.
I have a Technika Dishwasher TBD4SS-2 it does not  - 000792ec-f802-457c-8c9a-7e51220ab5e7.jpg
Posted on Jul 18, 2013
I do not know this specific machine, but most dishwashers showing this issue have the waterswings being clogged with food residu. Remove the swing arms from the machine and clean them.
Posted on Jan 07, 2013
markevans
  • 148 Answers
SOURCE: dishwasher
basic checks:
is water entering into the machine.
is it hot.
is it being heated during pre-wash
is the soap being dispensed
is the pump running when cycling?
do the arms turn freely?
you mentioned the top and bottom shelves. are there places where the dishes 'are' being cleaned?, or are you meaning that in general they are not being cleaned at all?
most of the above indicators are observable by stopping the wash cycle from time to time in various modes.
to see if water is being pumped at all, put a bowl on the top and bottom shelf, and nothing else. if there is water in it after it cycles then the pump is moving at least some water.
start with these observations and please report back
good luck
mark
Posted on Dec 28, 2007
  • 2920 Answers
SOURCE: dishwasher isn't cleaning dishes properly
try running bleach through the system.....pour some in the bottom and in the soap disp and run it
Posted on Jan 04, 2009
kachbibi1
  • 979 Answers
SOURCE: Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
Posted on Jan 17, 2009
lancer721
  • 229 Answers
SOURCE: My Kitchenaid dishwasher not cleaning dishes on top shelf
You need to clean the jets on the machine arm with an old toothbrush etc... then clean out the debris filter on the bottom of the tub near the dryer bar. The calcification in the little jet areas causes this problem. This should help.
Posted on Jan 18, 2009
onthejob5130
  • 640 Answers
SOURCE: My dishwasher will not clean on the top shelf
cheap trick...take a glass and put it on the top rack...right side up run dishwasher for about 4 mins is the glass full with water,no ok than check your drain hose the water is sphion out during wash,,lift it the height of unit..keep me posted
Posted on Oct 10, 2009
After a full cycle the dishes are covered with pulverized food on top shelf only.
Most (if not all) dishwasher have a food grinder in them just like a "garbage disposal" in your sink. (It's NOT really meat to be a garbage disposal)
In any case if the ground food is ending up back in the washer it means its not being flushed out when the washer empties.
You will need to remove the bottom rack and the bottom spinner. Open the pump and clear any debris The round tank tat the lower arm sits on should also be cleaned out. If the washer is over 5 yrs old consider replacing the impeller and all the pump hardware also.
Without specific Make and Model I cannot give you detailed instructions or parts #s. When asking about things like this alway have the make and model # Good luck
Jan 22, 2017 | Dishwashers
I need a user manual for my dishwasher Bellissimo technika model tbd4ss-3? Help
Have you tried the internet by entering your information or is there a number on the back that you can call for help
Dec 25, 2012 | Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Hi ive jst moved into a rental home and i need a manual for the dishwasher bellissimo TBD4SS-4. thank you
Hi.
Bellissimo appliances are built by Technika (see website).
Unfortunately Technika does not provide online manual. To get the owners manual please contact Technika or contact Bellssimo.
Here contact forms:
Technika
Bellissimo Appliances
Regards.
Ginko
Sep 14, 2011 | Dishwashers
Top shelf dishes do not clean. used dishwasher cleaning products but does not help. bottom shelf cleans good.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Dec 27, 2010 | Whirlpool DU1301XTV Builtin Dishwasher
I have just moved into a new rental & the Technika Bellissimo Dishwasher isn't cleaning the dishes particually on top shelf. I have cleaned dish washer from top to bottom (arms as well)It is driving me...
That looks like the Washing powder residue. I am having a similar problem. But I am finding that the heating element isn't working anymore and hence can't rinse with hot water thus appears the soapy residue which dries into a 'sandy' substance as you say. Sorry no solution for you yet, can you check if when it finishes and you open it - its still hot inside?
Apr 02, 2010 | Dishwashers
Oct 09, 2009 | Dishwashers
Dishes on top rack don't get clean
The following suggestions will greatly enhance the ability of your dishwasher to clean all of the dishes thoroughly:
1. Rinse all of the food off of the dishes before you put them in the dishwasher.
2. Run the hot water into the sink until it is as hot as it gets before you start the dishwasher.
3. Do not pack the dishes into the dishwasher, just put in a reasonable number without crowding or stacking them on either shelf.
4. Pull the top shelf all the way out to be sure that the water connection at the rear of the top shelf is connected. Sometimes, this connector comes disconnected preventing the water from entering the top spray assembly.
THese things should make a huge difference.
Good luck with this and please rate my answer. Thanks. Joe
Feb 03, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Jan 16, 2009 | KitchenAid Dishwashers
Dishwasher isn't cleaning dishes properly
Jan 04, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Dishwashers Logo
191 people viewed this question
Top Dishwashers Experts
