Question about Amana Front Load Washing Machine Washer Soap Dispenser Nfw7200tw
Amana NFW7200TW front loading washer door not latching. Possible that latch is locked shut. How to open latch? repair?
Looks like a black (plastic?) latch will not open in lock housing. Door will not fully close (so washer will not operate). I have manually pressed the door sensor so that the washer will start with the door open. When doing so lock will "click" and then when I stop the cycle it will "click" open. Both sounds normal, but there is no visible movement and door will still not latch.
  • elisegaretto
    elisegaretto Jan 07, 2013
    This is with the wash machine door... not the soap dispenser. Not sure how that switched.
2 Suggested Answers
SOURCE: amana front load washer door locked with door open
To get the front off. (All screws look to be #2 Phillips Screws)
1. You have to unscrew (2) phillips screws from the back that holds the top on.
2. Slide the top off. (slide towards the back)
3. Then where the control panel is there is about 4-6 screws holding that plastic piece on, take those out this will allow you to pull the control panel up and out of the way.
4. At this point you can unscrew the 4-6 screws in the door area that holds the front of the washer on, once you unscrew those screws there is a tab that you have to lift the front over to pull the front off. This will allow you access to the locking mechanism.
5. There are only 2 screws holding te locking mechanism on.
Posted on Nov 18, 2010
NFW7200TW hums and does not turn or fill with water
if it doesn't fill the water valve will hum,first thing is to see if it's a problem with the house water valve or the washer valve,shut off the water supply,reomve the water hoses from the back of washer,mark the hoses so they go back on the same way,stick the hoses into the washer or a bucket and turn the water on,if water comes out of hoses then you know the problem is just the washer,check the valve,look at the screens where the hoses connect to the valve,usually sediment gets in there and the valve on the washer has to be replaced,on some the screens can be removed and cleaned,also you say you have trouble with the lock,what's humming is it the lock or the valve,if you turn it to drain and spin will it run?you could have a bad door switch,if door doesn't latch washer won't run but most likely bad water valve
Jun 15, 2013 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Door latch stays locked
remove the top and there is a manual release for the door near the latch. You will need to replace the door lock. Here is a link to the part.
Oct 17, 2012 | Amana NFW7200TW 3.5 Cu. Ft. Front Load...
Ge front loading washer door won't unlock
Some machines do this when the power is cut, there should be what looks like a screw heat on the front of the handle which will allow you to unlock the door and open it. If there is still water inside you will need to empty the machine first. There is usually a hatch at the bottom of the unit, open this hatch and you will find a cap to unscrew, unscrewing this cap will empty the contents of the machine onto your floor so be prepared!!!!!
May 08, 2011 | GE Washing Machines
Door is locked, wont open
remove bottom acces panel 1/4 screw sometimes torx bit ubplug washer reach in on non hinge side against doorshould be door lock latch assymbley, bottom of latch assymbley is a round plastic end thats spring loaded ,pull downward and open door replace door lock assymbley
Jan 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The door is open, but the latch is in a locked position.
it sounds like the child lock as been turned on,check the handle part to see if it as a **** in it were you can turn it with a screwdriver just turn this upwards or sidewards to see if the door will lock or open ?.rgrds,paul
Jul 07, 2009 | Washing Machines
HE front loader washer door opened during cycle and will not shut
the latch broke within( the hook inwhich actually hold doorshut) , youll need a new latch assy.
Mar 14, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Latch is in lock position and we cannot shut the door
you ll have to order and replace the latch assembly ther are 2 for this model depending on your serial number
Nov 17, 2008 | Maytag Neptune MAH5500B Front Load Washer
Door will not shut
if the stike on the door is not broken then it is the door latch
May 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door latch repair
Try this link http://www.repairclinic.com/SmartSearch/smartsearch.aspx?SearchText=%60Awashingmachine&gclid=CPn0wqbb75ICFRQfsgoddySB5A
Apr 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Amana Front Load Washing Machine Washer Soap Dispenser Nfw7200tw Logo
35 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
