Question about Konica Minolta Magicolor 2530 DL Laser Printer
I have to change black toner in my Konica 2530DL. Have never done it before. No one kept the manual and I can't figure out how to get the black toner cartridge out!! Help please.
Press the up/down buttons on the printer till you hit menu special pages; press menu select button
press > arrow until you hit menu engine; press menu select button
choose engine replace toner; press menu select button
choose color to change and it will autorotate so that you can pull CMYK catridge out
Posted on Mar 09, 2009
This works thanks!
Posted on Mar 14, 2009
My machine comes up with "low toner K". I assumed
Yes they do come in various other separate colors as well. As your machine is a "low toner K" I can not guarantee that it will support such application.
http://mhelpdesk.com/field-service-management-software/
Aug 23, 2013 | Konica Minolta magicolor 2530DL
Konica Minolta Magicolor 2530DL streaks. maintenance
Lift drum out, look down behind toner and you will see a glass lens.
Clean it with a soft cloth or tissue. Works every time.
Aug 24, 2012 | Konica Minolta Magicolor 2530 DL Laser...
Model 2530DL - Fatal Error Code 08H - help!
Worcesterlad came up with this some time ago: it's not a solution but somewhere to investigate:
Error 08 relates to the main motor having problems turning. Quite often this is caused by a faulty consumable (opc,toner or transfer belt). Could also be that the lid is not closing properly and stopping the toner carousel turning freely
Jul 14, 2011 | Konica Minolta Magicolor 2530 DL Laser...
THE KONICA MINOLTA MAGICOLOR 2530DL/ ALL FOUR COLORS OF INK ARE LEAKING ALL OVER THE INSIDE OF THE PRINTER, WHAT WOULD CAUSE THIS?
Most likely reason is the printer is either a display model, or previously been sold and returned. The toner cartridges are usually sealed and these seals need to be removed prior to use. I would recommend returning to the supplier and asking for a new one, with the toner cartridges sealed. Once toner has been spilt, it is very difficult to remove all traces. A standard vacuum cleaner may be suitable to remove the worst.
Mar 08, 2010 | Konica Minolta Magicolor 2530 DL Laser...
I have a Konica Minolta 2530DL printer. I have
the reset is done via a 'first use fuse' in the drum unit.
check the contacts or put in a new one.
Oct 21, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Instructions for Fuser Unit Change - Konica 2530DL
Send me you email at dhudson at Gmail dot com, and I will reply with the manual attached. It is a very involved process, that, having done it, would not ever want to do again.
Apr 17, 2009 | Konica Minolta Magicolor 2530 DL Laser...
I have a konica Minolta Magicolor 2530DL and I just refilled the toner and now I cant get the new chips to read. I want to know if there is a way of disabling the chip so I can print. I know I have enough...
You need the chips to tell the printer which color is installed. You can put your old chips on the toners and set the engine menu to continue on errors to print even when the counters show that it should be out..
Apr 07, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Changing toner in a konica minolta 2480MF
http://kmbs.konicaminolta.us/productsattachments/manuals/magicolor2480MFUserManual.pdf
check page 92-101 in pdf or 82-89
hope this works
Nov 20, 2008 | Office Equipment & Supplies
(the infamous) ?X toner not installed? error message
I just got off the phone with KM tech support for the same problem with my 2430dl.  Take out the drum and remove the toner cartridges, then look inside the printer.  You will see a piece of glass about 6" long.  Next to it, on the right side of the printer, there is a little white plastic enclosure that contains three spring-loaded contacts; this is the sensor that reads the chips on the individual cartridges.  First, try cleaning the three contacts with a swab/alcohol, as well as the chips on each cartridge.  If this doesn't solve the problem, then the problem is likely with the sensor.  The part number should be 4139-6306-02, and it runs about $5. This should solve the problem.
May 10, 2008 | Konica Minolta magicolor 2430 DL Laser...
Konica Minolta 2400w
compear the the C and K toner circut boards, maybe you have to but something under circuit board, so it reaches the reading mechanism. after making any changes turn off and on the printer.
good luck
Jan 10, 2008 | Konica Minolta magicolor 2400 Laser...
Konica Minolta Magicolor 2530 DL Laser Printer Logo
205 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
