Question about Canon PowerShot SD10 / IXUS I Digital Camera
No images/picture:only right after turn on
Hi there- the camera all of a sudden lost its picture- has power, turns on and off- but it no longer shows my review images or shows me any picture/image at all. EXCEPT for one second immediately after I turn it on. Any sugesstions? Jessica
  • Jessica Rabbit Jun 30, 2007
    Thank jackboy!
    I will let you know what happens -and yeah, I think a a new camera is on the horizon;-)
Plug it into the computer and turn the camera on (as if you were transferring pictures). No amount of fooling around fixed it until I did that.
I did have the screen flicker at a non-constant rate after waiting a minute or two on "camera" mode. Nothing happened with review mode.
I have also heard things about old rechargable batteries not giving enough power to make the screen turn on, but this camera takes lithium... and I doubt that was the source of the problem... I really don't know what caused it... Probably was power. The camera would not turn on when the battery was out and it was connected via USB, so the USB connection apparently does not supply power to the camera.... so I still don't know what the problem was...
Posted on Apr 11, 2008
    Genius:
  • 2,985 Answers
Could be A. Battery contacts need a clean take them out and with the end of pencil eraser clean the contact in base of the chamber. B battery door losing tension - press it closed whilst in use. C. an internal connector worked loose try gently squeezing around the base of the screen- this usually where the connectors are. Do get onto Canon Tech Support Team. Just be prepared for a no repair solution. I.E. new camera
Posted on Jun 30, 2007
SOURCE:
Have a Canon 5d mark 2 . Was using it today all worked ok. Then it suddenly wouldn't review photos or bring up the menu . It shows black screen but when turned off it says the normal sensor cleaning
Hi Dear!
According to your problem note said wouldn't review photo or bring up the menu. You have to check all taken picture if there is blank, black, or corrupted picture file(cause won't able to see the image) are come from mirror box sequence control unit failing. At the beginning of this problem can not be noticeable, later it causes more and more blank image come out. However, if you don't have any blank image, then a loosen screw piece running around and touch circuitry in side could be serious. These two symptom are common and manufacturer's engineer design defect, but they won't tell you. Other then that you have no problem on your camera like last statement "when turned off it says sensor cleaning" This is camera's default setting that whenever you turn off camera will clean off sensor by itself.
Hope You Luck! A Professional Camera Clinic Guy!
Sometime there is defective main picture control process! But Canon won't say about it! At least you can try to convince them. (I want you shoot continuous a lot and video shooting) If it happen, then your main process board defect!
Apr 07, 2015 | Canon Cameras
My CM-818T3 will not show image
The camera has to be on th right setting also...is there a manual switch on the camera it self? If not is the power hooked up properly, is there a light switch turned off that actually turns the power off to the outlet your using for the camera?
Feb 20, 2014 | Astak Home Security
Canon 60D playback images turning up black
Did you switch to Tv (shutter mode) and took pictures for several seconds? like in the dark? Because saving the picture can take as long as the shutter time was.
Before panic. (Actually you never should panic) check your camera in automatic mode. And make sure you did not select any power save action, that puts your display on dark while shooting.
But always be sure your battery is charged and check its capacity. In the menu yo can check under the wrench symbol, when you select Battery info. Page 268 of the manual.
Working with a bad battery can damage the camera in the end.
Dec 27, 2013 | Canon EOS 60D Digital Camera
SONY DSC-T1 CAMERA WHEN TURNED ON PREVIOS PICTURE SHOW UP FINE ON THE VIEW SCREEN BUT WHEN THE THE SELECT MODE SWITCH IS MOVED TO EITHER TAKE A NEW PICTURE OR TO MOVIE MODE THE VIEW SCREEN IS MOSTALLY...
Based on the information you've provided it seems that the CCD Image Sensor of the Camera is affected. If the CCD Image Sensor is affected, the images captured may be discolored or with lines on it. Even if the CCD is affected, the previously captured images and icons of the Camera will display normally. You may try power resetting the Camera.
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
Also try resetting the Camera back to factory default: The RESET button is located at the lower right side of the control button. To reset the camera just press the RESET button using a sharp-pointed object.
If the issue remains the same, then service may be required.
Thanks for using FixYa.
Mar 01, 2011 | Cameras
My camera all of a sudden when I turn it on gives me a black screen and won't take a picture
If it is Sony DSC-T1 camera then it got ccd imager chip failure problem that is why no image in lcd screen to take fresh picture.
CCD Imager chip will be replaced to fix this issue.
Let me know if camera model number if different or you need ccd imager chip part number info.
Thanks.
May 28, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Display screen no longer works while taking pictures
Sounds like they accidentally pressed the DISP or DISPLAY button on the back of the camera. This manually turns the screen on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time with the camera turned on.
Aug 01, 2009 | Canon PowerShot A630 Digital Camera
D80 with nikkor 18-200, no picture
raatl, You mean the LCD on the back of the camera right?  The image that shows up (playback) can have the duration changed in the menu settings, it may have been turned off which is a choice as well that mode (not having the LCD on) extends shooting time which used to be a problem with the earl D70 and the earlier battery type.  The D80 doesn't have that issue, try experimenting with how much time you really need to have the display on, if you shoot and like to show the image to people set it longer or just hit the playback a couple of times as you are showing people.
randy320sgi
Dec 20, 2008 | Nikon D80 Digital Camera with 18-135mm...
Fuji F700
If you mean while you're trying to take a picture, one configuration option for the F700 is to turn off the LCD when taking pictures and use the view finder-- this saves battery power. If you press the DISP button to the right of the LCD should turn on.
To turn the LCD back on-- Press MENU/OK (you should see the SELF TIMER screen). Press RIGHT ARROW to select the SET option. Press UP ARROW to select the SETUP option. Press MENU/OK. You should see the SET-UP screen. Use the UP/DOWN Arrows to navigate the options; use the LEFT/RIGHT Arrows to cycle through the options. The IMAGE DISP and the LCD options control when the LCD is powered on.
Jul 01, 2008 | Fuji FinePix F700 Digital Camera
No Picture
1. If you are using TIFF mode for uncompressed images, the camera takes much longer to process the image because of the very large file size. It takes longer between shots and longer to play back a TIFF image. The TIFF setting on the camera Top LCD Display is 'No Stars' (One Star = Basic, Two Stars = Normal, Three Stars = High Resolution, No Stars = be patient for TIFF). Unless you are doing professional images, we suggest that you use the normal or high resolution JPG settings (Two or Three Stars / FULL) for good results. 2. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 3. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. 4. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M11 Digital Camera
No Picture
Sep 15, 2005 | Toshiba PDR-M21 Digital Camera
Canon PowerShot SD10 / IXUS I Digital Camera Logo
51 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
