Question about Jacuzzi Pool & Spa
The hot tub reads - - - and has power but nothing is working.
It started by needing to be restarted by the breaker being turned off then on. It would work , jets too, but did not stay working. Now the breaker routine doesn't work either and nothing is working, except there is electric to it. It even heated up but not all the way. It would say 106 - and the temperature was only 99...then would drop because it did not stay runnning. It is 37 and less degrees now outside and I am afraid the pipes will freeze. Help!
  • Jacuzzi Master
  • 717 Answers
This problem is over a month old so i am not sure if you still need the help.Start by turning off the breaker. Unplug everything from the hot tub i.e. pump, heater, air blower, light - anything connected to the spa control box.
Now turn on the breaker.
Check the voltage coming out of the transformer in the spa control box. You may have a bad transformer or a bad circuit board. If you have power coming out of the transformer going into the circuit board, do the following:
If it doesn't blow the breaker then systematically do the same process but plug in one item at a time starting with the pump first until you find the problem.
Rod
US Parts Center
Posted on Feb 08, 2013
5 Suggested Answers
  • 77 Answers
SOURCE: QCA Opal hot tub display reading OH.
The tub experienced an overheat situation. This may be due to leaving the t stat turned all the way up and not monitoring or the hi-limit sensor is defective. The hi-limit sensor will shut down the heating cicuit if temp gets above 105 D optimally.the fact that the heater light is on is a good sign that things are working at this point.Whether or not a suitable temp(100-103 D) will be arrived at is to be seen. If spa heat kicks off before set temp is reached then replace hi-limit sensor.
Posted on Apr 22, 2009
zeusfaber
  • 247 Answers
SOURCE: no power to hot tub...
In all liklihood, your problem is a breakdown in the insulation of the heating element. The elements tend to be mineral insulated then metal jacketed. Once you get a bit of corrosion on the jacket and a little water gets into the mineral powder, it's insulation properties fall off sharply, shorting out the power supply.
There are two practical ways of testing this:
The pro way of doing it is to borrow a high voltage insulation tester, disconnect the power leads from the element and check the resistance between one of the elements terminals and the jacket. Treat anything less than a megohm as a failure requiring replacement of the element. (nb. This is one of those rare cases where you need to use a proper insulation tester - an ordinary multimeter often fails to find this problem)
The alternative is just to replace the element and see how much difference it makes.
A.
Posted on May 25, 2009
  • 8 Answers
SOURCE: panel reads HHO-----, no temperature display until
"OH" is an overheat error. In normal function, it is used as a safety shut off if the spa water temperature reaches over 110 degrees in the event of a thermostat failure. But more commonly, (if the water temp hasn't gotten too hot) it indicates that the temp sensor(s) have failed. If you have a digital display on the topside controller of your spa, then it is a circuit board controlled spa pack. Most spa builders use the same control pack manufacturer - Balboa Watergroup. The sensor kit usually consists of 2 probes and wires that plug directly onto the circuit board. Depending on the spa, they could both be located onto the heater manifold, or one on the manifold and one mounted to the tub making direct contact with the water via a thru-wall sensor mount. If I knew the spa manufacturer, I could further assist you. If you replace the sensors, and encounter the same problem... then the circuit board is bad, and usually a costly replacement. The sensors are usually listed as a "BA sensor assy" Hope this helps you,
Posted on Dec 26, 2009
Coastsider
  • 331 Answers
SOURCE: mystic hot tub doesn't stay hot enough
Is your spa wired for 110Volt or 220V?
Posted on Apr 14, 2010
The display panel on my hot tub shows a lock and none of the function keys respond when touched
didnt specify if you had a 4 8 or 10 button panel your unit is locked the only control that will work is temperature your owners manual has how to unlock it under side panel the following link is for an 8 button panel and the instructions are on page 6
http://qcaspas.com/media/pdf/Jewelp3-8Btn.pdf
Oct 28, 2015 | Qca Spas Jewel Series Topaz Plus Hot Tub
Hydropool hot tub
see if voltage from transformer if ok board
Oct 07, 2017 | Pool & Spa
Hot tub turned off during filter replacement
Hi Amy, When you say " I can't get it back on" do you mean the breaker won't reset? Is there power at the spa? Is the pump running but not pumping water? Depending on the spa, you may have created an air lock in the system and need to bleed the air out. It's possible that some water got into the equipment area and shorted out the system. In which case you need to open the equipment area and dry everything out before trying to turn the breaker back on. I would need more specific info to help you with this problem.
Nov 10, 2013 | Pool & Spa
I have a 15 year old Hydropool Gold Series hot tub that I bought used a month ago. We got it all hooked up and working great but was told the timer never worked so it ran 24/7. Yesterday my husband turned...
If you can find the points on the timer try sanding them down. If they were burnt and stuck the spa would have run continuous. When you pulled the timer you may have broken them free but a burn would have kept them from making contact. I hope this helps, if not you might try reversing the leads coming into the timer or wherever you unhooked it to take it out. good luck.
Dec 05, 2010 | Qca Spas Paradise Hot Tub
I have a 240V hot tub and when I turn on the Cutler-Hammer GFCB250 GFI Circuit Breaker, 50A, it trips immediately. I spoke with a tech support guy from the hot tub mfr who says that the heater and pump...
It is very possible breaker is bad. If you have another 50 amp breaker in the box try swapping them and see if it still trips. GFIC breakers are finicky and they do go bad. I would make sure that the heater is not shorted out before replacing the breaker. It shows 15 ohms which is not what you would normally see which is 9-12 ohms. The reading of 15 ohms you got is high but if the manufacture says that is acceptable then we must assume it is. You also need to test for a short before eliminating the element as a possible cause. Test it with your ohm meter set to the highest setting. Measure between one element terminal and the sheath of the element. Any reading indicates a short to ground indicating the element is bad. If you find it is good then a defective GFCI is really about all it can be.
Sep 20, 2010 | Eaton Corporation GFCB250 GFI Circuit...
Hot tub breaker not tripped but nothing works
Sounds like your controller has sustained damage. You need to have a professional inspect it to determine what has gone wrong.
Apr 14, 2010 | Pool & Spa
My electric went out for 24 hours. I hooked up my generator to the breaker box to power the house. The generator only powers one 110 leg so there would have been 110 going to oneside of the 220 breaker to...
You should start with checking all your breakers to be sure the breaker did not pop just half of your breaker. This is something you should do with all your breakers. When you do this you should shut down all your 220v breakers so you don't get bleed back through the system. Other than that you need to look for resets on the tub. The heater is a good place to start and don't forget the gfci's on the tub or in the bath or laundry room.
Dec 13, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Froze the jacuzzi.
You'll need to start electrical troubleshooting from a point where you have power and then keep testing further into the unit to find out where the power stops. Is there a local 'ground fault' reset button inside the hot tub control area (under the tub?)
Jul 11, 2009 | Home
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Pool & Spa Logo
109 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
