Question about Dell UltraSharp 2005FPW 20.1" LCD Monitor
Where to buy backlight inverter for DELL 2005FPW monitor
My Monitor 2005 FPW needs to replace with new Backlight inverter, can you please suggest a site where I can place my order?
    Problem Solver:
  • 19 Answers
Http://www.lcdrepair.us/
Posted on Jan 20, 2009
Dell 2005FPW screen turns black after a second ,can not get it back on
this is a fairly common problem. The backlight circuit is probably shot. Not much to do but replace the monitor.
Oct 05, 2014 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Hi i have a dull screen on my dell inspiron 6000. i have replaced the inverter and replaced the backlight but still dull. is there anything else i can do?
Maybe your problem was the Video Card. Did you try an external monitor before you replaced the inverter and backlight? Try an external monitor and if it does the same thing then the Video Card is bad.
May 11, 2012 | Dell Inspiron 6000 Notebook
Power light flashes monitor does not turn on hear little chirping sound and see a little light flashing inside the back of the monitor
Check and replace burned high voltage ballast transformer and busted backlight inverter...
Too risky to do it yourself without proper knowledge and right tools..
Suggest you bring your monitor to a credible technician to have your parts replace and avail of warranty if there is still..
Much apprreciated if you rate this help..thanks..
May 24, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
It started flickering then went black. When powered off and then back on, it will work for a couple of seconds then go black.
Hi!
I think what your monitor is experiencing right now is because of the backlight inverter in your lcd monitor is about to give up...The backlight inverter is a cold cathode light thats responsible for the image in your screen.. if the lights located on the upper and lower edge of the monitor will be busted then what you will see is black screen.. You will need to replace that in your monitor.
However, without the proper skills to do that and proper tools to open the monitor.. it will be risky for the safety of your monitor..
I suggest that you bring your monitor to a credible technician to replace busted backlight or (burned high voltage ballast transformer - supplying current to backlight)
I hope this help..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Dell 2005fpw flash problem
Often this is a capacitor problem, there have been many problems with them as of late. http://www.badcaps.net/forum post here and they will be able to help you out.
Jun 12, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Blank monitor
Luckily I'm not in it for the money so here's your answer. (Sorry drumbanger.)
When it goes black, look at your power button. Is it still green? If so, the backlight display is bad. If the power light has turned orange, you're most likely looking at a power/inverter problem. Sadly, if you don't have another monitor that you can swap parts out with, you're looking at a new monitor. But with the economy on the downslide, replacements keep getting cheaper! Research online and you'll find some fantastic deals! Rate me if you find this helpful.
Feb 14, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
I have a Dell flatscreen monitor that will not turn on. The power light blinks blue slowly
Hi...there,
It's seems you got a busted backlight inverter. If you still under warranty send it back to Dell for repaired. Happy Holidays!
Dec 18, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
No display all lights on bottom right blink
Hey...
Seems your lucks just run out....you've got a busted backlight inverter. Need to replaced a new one...
Nov 21, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Monitor switches off every 10 minutes for 8 minutes
Hi..there,
well, you can repaired it yourself, Just need to replaced a couple of bad capacitors in the backlight inverter.
Oct 13, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Opening Up a Dell 2005FPW
Hi...there,
If you got power with no screen or both... Then it's your backlight inverter are busted. Need to replaced or repaired. To repaired look for a capacitors with a bulged on top of each caps. Not sure...just replaced all the caps... Good lucks!
Oct 07, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell UltraSharp 2005FPW 20.1" LCD Monitor Logo
739 people viewed this question
Alun Cox
