Question about Samsung WF337AA Front Load Washer
What does nf mean on a samsung front load washer vrt?
  • 3 Answers
SOURCE: Samsung VRT washing machine
nF means that washer tried to fill but was unsuccessful. Water supply valves needs to be fully open. Lines may be kinked or screen by the hose hookup at the washer end may be restricting flow. Check to ensure the screens are cleaned by removing hose and pull screens and clean them then try the washer again
Posted on Jan 18, 2008
SOURCE: Samsung Front Load VRT
I've had that same code, the machine completely stops and you have to start over with the load, the repair man samsung sent out still cannot fix my problem. he says there is a defect on these machines, good luck!
Posted on Apr 22, 2008
pride applia
  • 232 Answers
SOURCE: I keep getting a nf error message. what is this
water fill valve screens may be plugged filling too slow or valve may be bad or is one of the hoses turned off
Posted on Dec 31, 2009
SOURCE: samsung vrt washer will begin cycle but get so far
You might have an object jammed in the pump housing. First thing you must do is to unplug the machine from the power outlet.You will then need to remove the back panel of the washer to access the pump. Disconnect the wiring from the pump and remove the two hoses by compressing the two clamps. ( Be ready for water to pour out of the hoses) Remove the three mounting bolts that hold the pump to the frame of the washer and remove the pump assembly. It is easier to work on the pump if you remove it from the mounting plate. Remove the three screws that hold the impeller housing to the pump motor. Seperate the two parts being careful not to damage the rubber o-ring that seals the unit. Inspect the impeller housing for any debris. (I found a nickle blocking the outlet port in mine). Remove anything you may find and reassemble in reverse order. The machine should reset itself and run as normal.
Posted on Jan 23, 2010
SOURCE: VRT with a nf message.
if water flow is OK from the supply, remove the top cover and check the pressure hose that runs from the tub to the pressure sensor. They have a tendency to come loose on these machines. That is what my problem was...Always unplug power before removing covers...
Posted on Jul 26, 2010
I get the nf halfway through the cycle. ALWAYS with 26 minutes remaining after opening and shutting the door several times and can get it to resume the cycle.
SAMSUNG WF331ANW/XAA TROUBLE SHOOTING GUIDE ...
www.manualslib.com > ... > Washer > WF331ANW/XAA
View and Download Samsung WF331ANW/XAA Trouble Shooting Guide technical information online. 3.7 cu. ft. High Efficiency VRT Steam Front Load Washer (Neat White). ... DC68-02834A-03_EN. 2011-09-28. 4:00:29. Previous page ... SamsungWF337AAG · Samsung WF338AAB · Samsung WF331ANR/XAA · Samsung ...
Support - Washers WF431ABP/XAA ' Samsung Washers ...
www.samsung.com > ... > Washers
Samsung Electronics
Dec 08, 2015 | Samsung WF338AAB 4.0 cu. ft. Front Load...
Why is my samsung vrt steam washer leaking from the bottem right model #WF331ANW/XAA
Locating And Repairing A Mystery Leak In A Front-Loading ...
? 3:55
www.youtube.com/watch?v=3D5q1ynWb-U
Jul 28, 2012 - Uploaded by SamuraiRepairman ... source of a leak in a front-loading washing machine and then mercilessly repairs it. ... LG Washer Repair & Diagnostic -Leaking Water from front & bottom ... Samsung Front-LoadWasher Disassembly - Washing Machine ...
Samsung vrt steam washer leaking - Fixya
www.fixya.com/support/t13638559-samsung_vrt_steam_washer_leaking
Jul 15, 2012 - Samsung vrt steam washer leaking - Samsung WF338AAB 4.0 cu. ft. ... I have a vrt ... I hope this helps.... Take of that little door on the front. Have a ...
Oct 29, 2015 | Samsung Washing Machines
Can I get a list of error code and what they mean and how to fix. I keep getting nF as an error. What does this mean?
It means 'not filling'. So either nor or both of your water lines are turned off or just barely open, or the filter screens on your hose washers are clogged. Clean/clear them, or check water flow and you should be good to go.
Mar 10, 2015 | Samsung WF431ABP VRT Steam Front Load...
What does LE mean on display panel of my Samsung vrt front load washer?
Le means there's a problem with filling. Check to be sure inlet hoses aren't kinked, and no blockage at the inlet, as well as water turned on.
Feb 23, 2015 | Samsung 3.7 CuFT VRT Front Load Washer
You should be getting error codes. Here's a link to Samsung's online help (it also provides a list of error codes and what they mean): http://www.samsung.com/us/support/owners/product/WF331ANW/XAA
Hope this helps.
Aug 16, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
Jul 06, 2008 | Samsung WF337AA Front Load Washer
Apr 15, 2008 | Samsung WF337AA Front Load Washer
Nov 24, 2007 | Samsung WF337AA Front Load Washer
Samsung WF337AA Front Load Washer Logo
263 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
