Question about Viking 7qt Stand Mixer
Where can I order a gear box for a VSM 700 Viking mixer
  • 3 Answers
Call 800-216-5775
Posted on Jan 08, 2013
Can anyone tell me a web site where i can find mechanical parts for my viking 7 qaurt mixer vsm700
probably the best place to find what you on is to go google and type in--parts catalogue for viking mixer model vsm700 and if there are sites that handle viking parts , you will get them there
Might even find the manufacturer site and be able to get parts direct from their spares department
Jan 11, 2016 | Viking Food Mixers
Viking 7qt mixer schematic
Not sure if one exists anywhere, but even Viking no longer has them. I am trying to use a Cuisinart schematic for their's to see if it's close.
Jul 17, 2012 | Viking 7qt Stand Mixer
My Viking mixer stand bogs down and stops when it is under a serious load. I sent it to a Viking repair place and they adjusted it but it still bogs down and stops under a load. It is the 1000 watt 7 qt...
The best you can do is to send it right back and make them fix it right... there is nothing you can do with that motor to make it run better..
heatman101
Dec 24, 2010 | Viking VSM700 Stand Mixer
We have a Cuisinart Hand Mixer Model # HM70 and the Beaters do not stay in the mixer holes. Can this be fixed in any way? Jack
Cuisinart hand mixers are not repairable. You can buy replacement accessories like beaters, but you can't buy any internal replacement parts.
I have a Cuisinart HM-70 and I stripped the plastic gears inside by trying to mix a really thick dough. It was easy to open and get to the plastic gears. When I called Cuisinart to try to get replacement gears, they said that they don't sell replacement parts and their hand mixers are not repairable. I looked all over the internet and no one sells internal parts.
Unless your mixer is still under warranty, I believe that you're out of luck and your mixer is headed to the electronics recycle pile.
Most handmixers today are sold with plastic gears - including high end brands like Viking. For me the lesson learned is to buy low end hand mixers (don't buy a top of the line 9 speed mixer) and treat them like they're disposable when they break.
Dec 03, 2010 | Cuisinart HM-70 220 Watts Hand Mixer
The mixer turns on, motor is running, but the beaters are not turning
Most likely what has happened is that the gears have stripped. The gears inside are plastic but the spindle is metal. When a dough is too heavy and gets caught up in the beaters it tends to eat them. If you take it apart, you will probably find that the gears are shot.
The fix...order new gears, tear down the mixer and replace them. These gears really should have been metal! Check the sunbeam web site for authorized repair places to get your parts.
1. Remove the ejector button...it should pop out with a flat head screw driver. There is a small phillips head screw under it. Take it out.
2. Take out the screws on the bottom. This should allow the face plate on the mixer to slide off, allowing your motor assembly to then be pulled forward.
3. Remove the mounting brackets/shock absorbers...they are rubber u shaped items that hold the motor in. Once that is done, remove the black plastic bracket on the bottom; two phillip head screws. Then unscrew the two long screws underneath. they hold on the speed control electric board as well as the top to the gear box. Pop the silver fasteners on the side of the gear box and you are in. the gears should lift out. put the new ones in and do the whole thing in reverse.
hope this helps.
Nov 29, 2010 | Sunbeam 2350 Heritage Series Mixer
How much grease should I pack into a gear box of a food mixer? should all cogs be covered?
pack it full the grease seems to find a way to move a way from the gears after a while so you new grease and pack it in
May 20, 2010 | Hobart D300 Stand Mixer
The mixer attachments will not rotate just a motor noise
Hi RDROSE29, it appears your mixer’s had a transmission failure in the primary gear box or the planetary gear assembly (agitator). One of the main gears has failed, hence the loss of power to the agitator, while the electric motor still runs.
The inspection and troubleshooting of the mixer transmission is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. If you're lacking one, you can download it from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in this case K45SSW, and then select the file under Parts List (1) K45SSWH0.pdf (341.41 KB) (definitely check to see it this matches your mixer). Turn to pages titled ‘Case, Gearing & Planetary Unit, for the disassembly, troubleshooting, and reassembly of your mixer, along with all the parts. I suspect your culprit gear is Illus. No. 8, Worm Gear, in Illus. No. 38, Worm Gear Bracket and Gear assembly. KA designs this gear to fail on purpose so the rest of the mixer will not self destruct.
Once apart you can check for any other unseemly wear and tear on the gears, etc. You may find more parts that need replacement than just a bad gear. You may also want to consider replacing all the grease, particularly if there are gear particles suspended in it.
Besides needing a replacement gear and grease, you might consider replacing the gasket, too. I recommend using a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call).
As far as parts go, here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself.
Here are some links to several excellent websites that detail the disassembling/greasing and reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
If you feel this is beyond your capabilities and will be too difficult to do by yourself you can take your mixer to a local small appliance repair shop and have them troubleshoot and fix your mixer. KA Customer Care can provide you with the name and phone # of the closest authorized KA repair shop in your area or you can do a Online web search, but be sure to get at least three estimates before deciding to commit to one repair shop.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it. hslincoln
Dec 06, 2009 | KitchenAid K45SS Classic Stand Mixer
Replacement parts for Wolfgang Puck stand up mixer
Very close; stand mixer parts (included accessories and manual only) can be accessed from this page:
http://www.wpcookware.com/categories.asp?cat=32
Just select your mixer's part number (located on a sticker inside the base) and click the link for a list of available parts. You will have to create an account to see anything useful, but all they ask for is your name, a password and an email address. When adding items to your shopping cart, be sure to check the 'Select Item' box. The ordering page will ask for the usual info. Prices are reasonable, but beware the shipping cost!
Jun 20, 2008 | Wolfgang Puck Stand Mixer
"clunking sound"
The plastic worm gear had teeth missing. I was able to order a complete drive unit ($85) from appliancepartspro.com
May 22, 2008 | Bosch 700 Watts MUM6622 Universal Series...
Viking stand mixer dough hook will not come off
Had the same problem with dough hook not coming off. Sent to a Viking dealer in Rockford and was quoted $600. to replace gear box. Took it back without repairs and call Viking listed in manual and sent it to them on a Monday and by Friday had it back fixed and no charge.DM
Feb 18, 2008 | Viking VSM700 Stand Mixer
Viking 7qt Stand Mixer Logo
85 people viewed this question
Top Viking Food Mixers Experts
Tom Chichester
Bill Boyd
Are you a Viking Food Mixer Expert? Answer questions, earn points and help others
