Question about Ridgid Tools & Hardware - Others
Belt sander not sending dust into bag
I've used my Ridgid belt sander to do an entire floor with no problems. Now I'm trying to do another floor but none of the sawdust is going into the bag although the bag is filling up with air. I've taken it apart as much as I dare and can see no obstruction. Help!
3 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: Bosch 3 x 21 Belt Sander
Remove the dust bag and unplug sander for now. Everywhere you see an access hole (fan area, dust port, back of sander blow thru the tool to remove lodged dust that clogged the system, Also look for broken belt pieces in the back of sander. Then while running (remove belt) blow again thru all the ports to try and reomve as much contamination as possible. When finished you can feel to see if air coming from dust bag port, it not you still have a clog that might need more work. If I have clarified your request would you please rate this response accordingly and thank you.
Posted on Sep 12, 2009
al_kupchella
  • 843 Answers
SOURCE: The sawdust is not going
The dust bags on most sanders are only marginally effective. They work OK on random orbit sanders with the holes in the sanding pad, but are next to useless on belt sanders. You might try attaching a vacuum cleaner hose instead of the bag. On the other hand, if the the belt is clogging up, that's not going to be helped by attaching a vacuum hose. The belt is "loading" up probably because the material you are sanding is damp, or maybe you are sanding paint, which tends to melt then stick to the belt. If you are just trying to keep the belt from clogging (or unclogging it), rather than keeping the dust contained, try running the belt against a wire brush after every couple of minutes. Good luck, Al K
Posted on May 04, 2011
Belt sander runs until I put pressure on it
It sounds like the sand paper itself is slipping. There should be an adjustment to tighten the pressure on the sand paper itself.
Feb 28, 2015 | Ridgid Makita 98462 9910 Belt Sander 120v...
Sawdust is not going into the dust bag, could the sander be clogged?
that would be my first guess, also look for pieces of sanding belt that might have clogged the passageway
Sep 11, 2011 | Black & Decker 3 x 21 In. Dragster Belt...
The sawdust is not going to the bag. I've completely blown my sander with air and tried to unclog anything without taking the sander apart, but still all sawdust stays on the belt and not going up the...
May 03, 2011 | Black & Decker 3 x 21 In. Dragster Belt...
How do I adjust an older model 360 sander to keep the belt running stright? I've been trying to adjust the knob on the side but it does not make any difference whch way I turn it the belt runs to the...
Ah. The knob may be way out of adjustment. Since the you've damaged a belt already, use it as a test belt to get the knob back to where it should be. Unfortunately there is no easy solution - it will require some trial-and-error.
Hope this helps.
Apr 27, 2011 | Porter Cable Cable 360 3" x 24" Single...
Sawdust does not collect in bag but remains on wood that is worked on. Have tried to locate problem (probably blockage but have not found cause or remedy)
Best way to clear the vacuum path: remove the sanding belt and collection bag. Use an airhose to blow compressed air through the opening where the bag attaches to blow out anything that may be in the airway. After blowing through the outlet, check around the rear of the drive pulley for any wood that may have to be picked out. Reattach everything and try it again. If it still doesn't work, the vacuum is driven by a fan on the end of the armature. You'll have to take the case apart and check that to see if the fan blades have broken off or the fan has come lose from the armature.
Oct 12, 2010 | Makita 9404 4'' x 24'' Belt Sander
Sep 10, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
Dead. Power is connected, wires are in tact. Just died when I was using it. Is ther an internal reset?
Try to plug something else into the outlet, just to make sure that the breaker didn't trip.
Try to run the sander without a belt. It may be in a bind.
With the sander unplugged, check the motor brushes. Replace if necessary.
If everything above checks out OK, you may have a loose wire.
Regards, --W/D--
Jul 13, 2009 | Ridgid 3 X 18 Belt Sander
Describe your Black & Decker BR318
This is a good sander but no portable belt sander is really a floor sander.
Jun 13, 2009 | Black & Decker BR318 3" x 18" Belt Sander
Tools & Hardware - Others Logo
730 people viewed this question
Top Ridgid Tools & Hardware - Others Experts
rickb63
Jerry Kramer
Jerry Kramer
Are you a Ridgid Tool and Hardware - Other Expert? Answer questions, earn points and help others
