Question about Sony Cfd-440 Boombox Am Fm Cassette Cd Radio Mega Bass W/guarantee
What is the "ISS" switch on the back for?
2010 Malibu error codes po700,po716,po717
DTC P0700: Transmission Control Module (TCM) Requested MIL Illumination
Which one of these transmissions does your Malibu have ?
Automatic Transmission - 4T45-E
Automatic Transmission - 6T40/6T45
Automatic Transmission - 6T70/6T75
Do you know how to find out look at the VIN # ?
DTC P0716: Input Speed Sensor Performance
DTC P0717: Input Speed Sensor Circuit Low Voltage
The automatic transmission input speed sensor (ISS) is a permanent magnet with a coil of wire wound around. The ISS mounts in the case cover facing the reluctor wheel of the input shaft. As the reluctor wheel is driven by the turbine shaft, an AC signal is induced in the input speed sensor. Higher vehicle speeds induce a higher frequency and voltage at the sensor. There is a fixed air gap between the sensor and the teeth on the sensor reluctor wheel. The ISS input is used by the transmission control module (TCM) in order to control line pressure, torque converter clutch (TCC) apply and release, and transmission shift patterns. This sensor is also used to calculate the appropriate gear ratios and TCC slippage. This diagnostic indicates stuck, erratic, or intermittent conditions in the system.
Diagnostic Aids
• Road test the vehicle while monitoring the Transmission ISS parameter on the scan tool. The Transmission ISS parameter should vary with engine speed changes and not abruptly drop out.
• Inspect for an open or shorted AT ISS wire.
• Inspect for a disconnected AT ISS connector.
• Inspect for a faulty AT ISS.
Trouble Code P0717 Input speed sensor
Jan 19, 2017 | Cars & Trucks
Je pumpmst 0pmd1 120 /2 hp 50/60 hz. single phase Had o replace piggyback plug now pump runs constantly .ISs this normal if not how do i fix the problem?
The piggy back plug connected to the switch that turned the pump on and off. It sounds like the pump now cnnectes directly to the line without the switch in series with it.
Jan 24, 2014 | Plumbing
1998 grand Marquis blows out Fuse 13. This shuts off power to the instrument cluster and shutting the Headlights, only when the Variable Control iss in the "Auto" position. In the "On " position th
(1998 Gr. Marquis) I just found the culprit of my fuse #13 for the speedo, temp and votage gages. I had to remove the gear shifter cover which was not difficult also the metal brace across the bottom and the ignition key, but it was a tiny exposed burr in the overdrive shift button wire just at the end of the gear shift leaver. I elec. taped it up and now, no more blown fuse!
Feb 28, 2013 | 1998 Mercury Grand Marquis
Error no 22:10 how to solve for hp 500 Plus
Back up EEPROM failed which was located in ISS( Ink supply station) & need to replace.. But this is major issue, only professionals can do this activity, other wise both ISS & Electronic module's will effect.
This is only one major activity in 500 & 800 series.
Pl consult HP trained professionals..
Nov 03, 2012 | HP DesignJet 500 InkJet Printer
My HP DesignJet 500 plotter printer doesn't recognize any of the 4 ink cartridges
>Your have new cartridges,not refilled right?
>Remove cartridges,
>Remove right door,
>Check ISS unit cables,PCB & connectors as shown in snap shot,
Most of the cases ISS arrested with ink leakage from cartridges, result connectors,PCB tracks & cables got damaged.. check perfectly if found shoot the problem....
> Replace ISS unit,, But only professionals can do the replacement..
*** Reading, writing & initializing the backup EEROM located in ISS unit, if any thing goes wrong both ISS & Formatter assm will loose their memory..be careful..
Dec 05, 2011 | HP DesignJet 500 InkJet Printer
HP DesignJet 500 - Printer will not recognize any of the four ink cartridges
>Remove cartridges,
>Remove right door,
*** Reading, writing & initializing the backup EEROM located in ISS unit, if any thing goes wrong both ISS & Formatter assm both will loose their memory..be careful..
USB connector cable which pair are video ,which are audio?? eg: red wire is ? black " is ? green ? white ?
abbey tuuney usb ko kya audio video wire samjha hai kya jo tv k picchu lagao aur tv chal padi no its wrong yaar usb it means universal serial bus iss mai device kai tarah k electronic signal bhejta hai which is converted by the device as it needs
Jun 21, 2011 | Audio Players & Recorders
2002 escort idle is to high
it sonds like it is your iss switch idle speed switch
check for fault codes to make sure sometimes the computer does not fault this switch
Dec 30, 2008 | 2002 Ford Escort
Help!!!! Windows Media Player and ISS problem
Do you have an exact error message by any chance?
Sep 30, 2007 | Intel Anypoint Network Adapter
Sony Cfd-440 Boombox Am Fm Cassette Cd Radio Mega Bass W/guarantee Logo
101 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
