at pc? more info? i think wrong section ^_^
What is rundll32.exe (rundll32.exe error)?
rundll32.exe (rundll32.exe error) Description:
Rundll32.exe is a program which would have been on your pc since the day you purchased your pc. Always verify the exact disk location as many virus and spyware writers will attempt to fool you by using a similiar name or same name in a different location. This file is part of the Microsoft Windows operating system. Rundll32.exe will actually execute functions in DLLs. If you are deleting files on your computer as a spyware removal protection method, then note that this is a required system file. Note that rundll32.exe can also be running many different other DLL or EXE programs, so you may want to check the programs listed after it in your startup list also, as these may be executed by it. Rundll32.exeis considered safe and is not spyware, adware, or virus related and does not need to be removed.
rundll32.exe error:
rundll32.exe error. Be sure to always double check your spelling if you are concerned about spyware, as often spyware will use a very similiar spelling of system processes or other common tasks. rundll32.exe error
remove rundll32.exe virus:
Remove rundll32.exe virus. Remember that although many files are always in default file locations, some files can easily be moved to different locations or change names like many spyware, adware, or popup programs do. If you suspect you have spyware or adware, check to see if you see a similiar names stored elsewhere. It always helps to check your tasklist also to see what is currently running on your computer. You can always view the tasklist on your computer by pressing ctrl-alt-del to view your "task manager", and then click the "processes" tab. This will show you all tasks running on your computer. Dll files will NOT show on your computer tasklist, as dll files are actually part of other processes. You may see similiar program names running if spyware or adware is on your computer, for example, ati2evxx.exe may be slightly misspelled to keep you from finding it, or spyware and adware may be named very similiar to a system file. Make sure always check the location of tasks or processes if you are concerned.Remove rundll32.exe virus
rundll32.exe Common Path(s):
This will be found in your windows\system32 folder. You will see it starting up programs like: RUNDLL32.EXE C:\WINNT\System32\NvCpl.dll,NvStartup
^_^
rundll.exe is missing
windows. cannot find rundll32.exe
