Question about Kenmore Sewing Machines
Kenmore Sewing Machine Model 385-1684180 feeder teeth are not advancing, what adjustment can be made on settings to correct this issue?
Singer Sewing Machine 534 repairs
hi it sounds like the timeing has moved on (1) and also on (2) would need to be seen by dealer.
Apr 09, 2013 | Sewing Machines
The Feeder Dogs are not moving forward or backwards on my sewing machine.
Are the Feed Dogs dropped? Check your manual for the location of the switch. .... otherwise your mechanism has been compromised. Take it in for repair.
Mar 19, 2013 | Kenmore Sewing Machines
The feeder on my 6690 won't pull material through
Look in your owner's manual. I'm sure your machine has a reverse feed button but don't know if you can manually disable the feed teeth. If it is so equipped, it doesn't drop the teeth. Rather, it simply causes them to go straight up and down. If the teeth truly stay below the needle plate level, they are likely out of adjustment and need to bereadjusted and raised.
Jan 08, 2013 | Husqvarna Viking 1
Feeder dogs will not feed fabric at all.
it's possible that the feed dogs need a adjustment or they need to be
timed by a sewing machine repair technican
Dec 06, 2012 | Sewing Machines
Bobbin thread bunching, fabric not advancing
Check your manual to find out how make sure that the feed dogs are up. Those are the "teeth" on the bottom that move the fabric along. If you're not sure or can't find the manual then posting the question with machine's model number might help.
If the fabric won't advance because the bobbin thread is jamming: Check to be sure that your tension is set correctly and that your machine is threaded correctly - even experienced sewers can occasionally miss a spot like forgetting the change the loop after rewinding a bobbin. Also make sure the the thread in your bobbin is the same brand and type as the spool that is threaded. An imbalance in the types of threads can throw off the tension.
Jan 12, 2011 | Kenmore Sewing Machines
How to adjust preasure on Kenmore Sewing Machine
Hi, not knowing which model # Kenmore it is its difficult to answer. Some have button on top to press down, some had the adjustment inside the left cover and probably other ways I could look up if I knew what model you had.
Rick
Mar 22, 2009 | Kenmore Sewing Machines
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Kenmore sewing machine # 385.17626 feed dogs not advancing fabric. Appear to move up and down, but not forward to back.
I had the same problem and had recently posted my own message, with no replies. Took it to a repair person and he fixed it at no cost - it was stuck in reverse because the mechanism(s) were all gunked up. Take off the accessory box on the machine and the bottom plate. move the mechanism so they move freely and take out any gunk you see. The feeder dogs should now move back & forth in addition to up & down, feeding the material properly
Jun 21, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing Machines Logo
47 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
