Question about GPS
I want t travel accross europe and do not have full addresses to enter into my garmin nuvi 250 please could you tell me how to do this Lynn
  • 50 Answers
The nuvi 270 is the model that comes with pre-loaded maps of europe. The nuvi 250 only has North America. You can find the right maps on Garmin at: https://buy.garmin.com/shop/buymaps.do
You can purchase all of europe or select areas which are $50 dollars cheaper.
Posted on Jan 21, 2009
  • GarminJunkie
    GarminJunkie Jan 21, 2009
Can we download European maps onto our Garmin 200W for travelling with motorhome
If you bought the satnav in the USA it won't work in Europe. If you bought it in Europe you can download the maps but the full map of Europe won't fit on it. You can fit Western Europe or add and remove countries as you need them. It's probably not a satisfactory solution when traveling with a motor home. You can put the map on an SD card but the nuvi 200W has problems reading maps from SD cards of 2 Gb or more. The map of Europe would take a 4 Gb card to hold it all.
You would probably be better to buy a cheap satnav of Europe. You can get them from http://www.pixmania.ie/ie/uk/xx/617/xx/1914/23/criteresn.html?sSortInfo=Prix-ASC
if you want to buy on line or Halfords shops if you prefer to deal with someone face to face. Some of them cost less than €100 and would be near the same price as buying the map of Europe.
Or if you want a satnav that covers both the USA and Europe and will work in both the Garmin nuvi 1370 or the 2370 would do the job but costs a bit more.
I hope this answers your question.
Jun 07, 2011 | Garmin nuvi 200W GPS Receiver
Can't select correct street/avenue
Can you please give the make and model no. of the device.
Jun 18, 2008 | GPS
How instal maps on sd memori card for garmin nuvi 250
Hello
Insert the memory card into the memory card slot on Garmin Nuvi 250 GPS device. The memory card slot is located on the left side of the device. Push the card in until it clicks. (If you inserted a memory card that already has pre-installed maps and files, there is no further action required. The device will access the new maps based on the address you enter.)
Connect the Garmin GPS to the computer using the USB cable. The mini-USB connector will need to be inserted into the rear of the Nuvi 250; the larger end is inserted into the computer's USB port.
Locate the computer file that you want to download to the Garmin memory card. The Nuvi 250 is capable of reading JPEG formatted images and GPX formatted Waypoints and other mapping-related files. Right-click on it. Select "Copy."
Select the "Computer" folder from the computer's desktop Start menu. Double-click on the "Removable Disk" drive that represents the Garmin Nuvi.
Right-click in an empty space within the drive and select "Paste." The files have now downloaded to the memory card and will be accessible through the Nuvi 250 menu options.
Good Luck, and do rate the solution if got help
Dec 06, 2010 | Garmin nuvi 250 GPS Receiver
Garmin nuvi won't let me enter full address and the address i want is not on the list
Instead of entering the city, press "Search All." Then enter the rest of the address. Sometimes the address is listed as being in a different/nearby city due to the ZIP code. Let me know if this helps.
Apr 30, 2010 | Garmin Nuvi 660 GPS Receiver
Garmin will not recognize destination
How are you entering it? You should go to "Where to?", "Address", then "Spell State/Province". Enter "On" and the unit should pull up "Ontario". Press this, then press "Spell City/Postal Code". Type "Ot" and the unit should pull up several cities, including "Ottawa, ON" Press this, then enter the rest of the address. Let me know if this helps.
Apr 25, 2010 | Garmin nuvi 260W GPS Receiver
How to change home address on garmin
Where to > Favorites > All Favorites > Home > Edit
enter the changes
press Done
If this solves your problem, please come back and rate our solution. Thanks.
Dec 24, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
I have a Garmin nuvi 260 and I bought it in U.S. I am going to the Netherlands and when I type in Netherlands it tells me it cannot find it. How do I use this in Europe?
You'll need to buy and install European mapping, such as Garmin's City Navigator® Europe NT, or the slightly cheaper but more restricted City Navigator® Europe NT – Benelux/France.
Web address below:-
https://buy.garmin.com/shop/shop.do?pID=11017#mapTab
Aug 04, 2009 | GPS
I have a garmin nuvi 250 device and want to update the maps for the UK and Europe. I have been told this can be done for free, can someone please help?
oh man i don't like when people ask me for free but u know what i bet u are a great guy and i can help u.THE ONLY THINGS YOU'L NEED IS AN USB,GPS WITH FREE SPACE,AND GOOD FAST INET.
Open www.thepiratebay.com
and type in the search engine garmin nuvi 250 (map and version)
for example
garmin nuvi 250 europe 2.16
i don't think there is a map that is 2.16 but...
than download the one you want and type in keygen generator garmin 250 nuvi
and than download it when you downloaded all the data copy the map in your garmin drive
and copy the .meta file to the keygen file folder load/run the keygen and write your device code than copy the map code. than disconnect your device and then when your device asks you for the map code write the code that you just have copied
Apr 26, 2009 | Garmin nuvi 250W GPS Receiver
GPS Logo
181 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
