Question about Air Tools & Compressors
We have atlas copco GA22 when it is on stage of auto loaded the compressor didnt compress the air, we try to replace with new solenoid valve and unloading valve but the problem still exist, any sugges
Atlas copco GA22
5 Suggested Answers
miket756
  • 2702 Answers
SOURCE: air compressor atlas copco ga30 oil seeping out
you should have an oil trap or two in the line from the out let of the compresor before it go's into the factory
they also trap any water in the air there easy to fit into the line and not very pricy
Posted on Feb 11, 2010
compman66
  • 169 Answers
SOURCE: the air compressor xats 67 starts, runs but cannot
suspect that the inlet control valve or control regulator may be at fault, but are you sure that your demand is not more than the compressor can deliver? if you close off the service valve will it come up to pressure and idle back as normal? if so then you may have a leak in your system or your demand is to large. But having a knowledgeable service tech check it out would be the next step.
Posted on Feb 16, 2010
  • 243 Answers
SOURCE: starts but can not compress
hi i think the drivebelt for the screw is broken or missing all theeth. when this is, after starting the engine runs at max rpm and no pressure will be built up. to check the belt, wich is behind a plastic panel just behind the compressor oilfilter, its easy to take off the oilfilter, take off the plastic panel, using screwdriver to bend the lips, and look at the belt. very oft its broken and you will find the teeth everywhere in the housing. if the belt is ok, the problem will be in the regulatingsytem, but thats only a smal chance. to change the belt you need a special tool to bring it to the correct tension. you can always ask more info. good luck.
Posted on Feb 17, 2010
Testimonial: "thanks a million times i tried ur suggestions and it worked as the belt connecting the compressor and engine was worn, thanks once more."
  • 6 Answers
SOURCE: We have GA18 atlas copco
Dear Sir we can supply you Spare Parts for compressor please Email at hydroair@rediffmail.com
Posted on Sep 16, 2011
Hi , ive got GA22 but it running very high,sometimes trips out. We have replaced everything to date - service,soleniod,flushed cooler,cleaned cooler,new pipes,new seperator,thermostat on constant...
Check the direction of the cooling fan, if it is a centrifugal fan it will blow no matter what way it turns, but it will not blow as much if it goes the wrong direction. Check for the arrow and make sure it is going the way it says it should.
Mar 23, 2015 | Atlas Copco GA Rotary Air Compressor - 20...
Atlas copco troubleshooting
If pressure on display is higher than set pressure of your safety valve,then your safety valve is doing its job. If pressure on display is lower than set pressure of your safety valve,then your safety valve is defective.
Aug 06, 2014 | Atlas Copco GA Rotary Air Compressor...
Always exhausting through auto dumps
Depending on type will require replacement. Usually dirt becomes lodged in needle valve assembly so can have go at cleaning.
Mar 31, 2014 | Atlas Copco 15hp Rotary Screw Air...
Atlas copco ga37
Two potability s sounds like Piston rings totally worn out,need to remove heads to check,the other potability is valves worn or sticking , but because of u say no air at all id say its head of remove barrel and check the piston if the bore is ok then u will b able to just replace rings if pistone is badly then u need to replace piston complet with mew rings come complet
Oct 08, 2013 | Air Tools & Compressors
Have a GA7ff Atlascopco Screw Compressor. Discharge of oil from Intake & went out on heat overload.
Sounds like a bad oil seal. If the oil level is too low, it will overheat.
Jun 02, 2012 | Air Tools & Compressors
We are using three screw oil free atlas copco compressors{ZR-275}. They often encounters the problem of high outlet temperature of first stage , almost near tripping stage. and we have to replace the...
Dear Hamza,
High Temperature at First Stage means your Second stage is becoming Weak and it is not capable to pull the maximum air from First stage, If it is only at loaded position.
If this is your regular problem you must check your Water condition it should not be below 20 degree C and not above 40 degree C.
You may also try to blow some dry air into second stage ( HP Element ) when ever it is in off position.
Hope this will help you.
Regards
Ashfaq
May 21, 2010 | Atlas Translator Atlas Copco Air Hammer...
Atlas copco screw compressor running but not compressing.
what type of compressor, can you please give some more info.?
Feb 25, 2010 | Atlas Translator Atlas Copco Air Hammer...
Compressor is loading without unloading
hi mate it could iver be a faulty load solenoid valve or the unloader its self is jaming up inside which means you have to strip it away from the air end and replace all the seals inside or give it to a specialst we are compressed air engineers we could sort it i will leave you a number call us anytime 07958354730 or call 01752 848801 many thanks
Jun 08, 2008 | Kano Technologies Atlas (K752HCDR) DVD+R...
Air Tools & Compressors Logo
61 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
