Question about Porter Cable Cable 352VS 8 Amp 3Inchby21Inch Variable Speed Belt Sander with Cloth Dust Bag
Manual for porter cable 352vs belt sander - Porter Cable Cable 352VS 8 Amp 3Inchby21Inch Variable Speed Belt Sander with Cloth Dust Bag
mikeymiddles
  • 58 Answers
SOURCE: belt sander clogged dust collection
What have you been sanding?  Make sure the sander is unplugged. Remove the dust collector bag and use a flexible wire, like a coat hanger, to free the clogged material from the dust tube.  Replace bag and sand away!  Hope this solution works for you.  Michael Mittelsdorf
Posted on Jan 10, 2009
muttandjeff
  • 359 Answers
SOURCE: Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Posted on Jan 11, 2009
  • 3 Answers
SOURCE: I have a 352VS Porter Cable sander. It started
check brushes or maybe the armiture is bad.
Posted on May 10, 2009
  • 1584 Answers
SOURCE: I have a Porter Cable 352VS Type 4 sander needs bearings.
You need special pullers for these, you will have to take it to a power tool repair shop.
Posted on Jan 26, 2010
  • 4088 Answers
SOURCE: After installing new belt, on Porter Belt Sander
There is a tracking adjustment knob on the side of the sander--adjust one way or the other until it tracks properly. This is something that will change by itself as the sander is being used--check periodically.
Posted on Feb 13, 2010
Please help me find a free owners manual for my porter cable 352vs belt sander
The ServiceNet site has the manual for most Porter Cable power tools here: http://servicenet.portercable.com/ . The 352VS documentation is here: http://servicenet.portercable.com/Products/Detail/352VS . Look in the right hand column for the Instruction Manual; you'll see an option to download a PDF or have the manual sent by email. However, you need to look at the sander and attempt to find the Type number. This will be on the label with the model and serial number. There are 7 different belt sanders that were released with the 352VS model number. Use this number to get the details for your sander. The direct link to the manual for the Type 1 version, today, is http://servicenet.portercable.com/Products/GetDocument?docName=EnA00111.pdf&productId=55856&productType=12187&documentId=32863&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/Porter-Cable/EnA00111.pdf .
I hope this helps.
Nov 20, 2015 | Sander Tools & Hardware - Others
Porter cable 352vs manual
My Porter Cable 352vs Belt Sander was clogged from sanding epoxy, wet wood, something like that. No dust collection at all.
I had to remove 4 screws on the housing, one screw under the front handle and another below the rear handle. The housing came out very easily (with a little wiggle). Pay very close attention to where the position of your plastic fan housing sits. It will only be installed in one spot.
http://www.ereplacementparts.com/images/porter_cable/352_TYPE_1.pdf
The pdf diagram was not exactly correct on the housing placement.
Once opened, The wood and epoxy were caked in everyplace. I brushed them out and replaced the screws.
Good as new.
Good luck.
Feb 24, 2012 | Tools & Hardware - Others
Have a porter cable 352vs 3"x21" belt sander. was using it and blue sparks started occuring in the rotor and brush assembly. kept using as I needed to try and finish my project. No longer...
this tool has various type numbers but I checked on the type 5-6 and came up with the same number. the brush number I found is NO30461 and they run from around 3.50 to 4.00 each. If you have removed the brushes if the spring is burnt/collapsed it could have been from a loose brush cap or worse an armature problem. Before I sent it out for repair I would look at the brushes, UNPLUG tool first and remove them after removing look into the brush holder and see if the commutator (part of armature you can see) and see if it is discolored or other obvious imperfections. You can buy replacement brushes online from "ereplacementparts.com" or direct from "dewaltservicenet.com". Let me know if you need more assistance before voting and thank you.
Feb 24, 2011 | Porter Cable 352VS Factory Reconditioned...
After installing new belt, on Porter Belt Sander 352VS #6 the belt drifts of to one side until it comes completely off. How do I stop this?
Feb 13, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Jan 26, 2010 | Porter Cable 3" x 21" Electronic Variable...
Porter cable 352vs belt sander wont run.... was running fine grinding down subfloor untill the end of the day...next day it won't start at all? any ideas?
The very first thing I would check is the condition of the motor's brushes. I'd bet just about anything that they're just worn down passed the limit length. I have the same model PC belt sander... and have used it to do that very same task... I came upon your query because I'm shopping for new brushes. This is a very easy fix by the way.
Jun 09, 2009 | Tools & Hardware - Others
Jan 11, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Porter Cable Cable 352VS 8 Amp 3Inchby21Inch Variable Speed Belt Sander with Cloth Dust Bag Logo
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim London
Jim London
Ed Mac
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
