Question about Hitachi C25-RF35S 25" TV
Old Hitachi sound...
Hi, I have an old Hitachi and everything seems fine with my sound... I mean if I connect my dvd player to it I have no problem with the tv... If I want to watch cable on it... I have no sound coming out from it... I have noooo idea what this might be, but it's really weird... I tried everything... The Cable is plugged in just fine there is no reason it shouldn't have sound... Could you please help... It might just be some stupid mistake I can't figure out... Thank you,
  • Benjamin Brunner Jul 02, 2007
    Ok first of all you got me wrong... It might be easier to understand like this... I'm sorry I wasn't clear enough...
    If I want to watch cable television... without any dvd involved... there is no sound coming out from the tv...
    If I plug the dvd in sound comes out from the tv... only if I play a dvd...without changing anything... If I plug the dvd in and want to watch cable immediatly when I change the input on the tv and cable turns on the sound goes away... I turn it back on to the dvd it's perfect... I took it the tv apart everything seems to be fine with it...
    Don't tell me to read the manual.. ahahaha It's about an 8 year old Hitachi and I have nooo idea where it is :)
Unplug the dvd in to the tv, see if u have sound then...gotta read the manual. go into menu and see if what the sound is.. u might have to switch it to tv stereo or mono. gotta read the manual good luck
Posted on Jun 30, 2007
SOURCE:
Can't change to channel 3 to use the dvd player
Your Vizio TV should have provisions on the rear panel for direct connection of your DVD player. Use those connections and select your DVD player as a video input.
Mar 08, 2018 | Vizio 42 in. LCD TV
I have an old Yamaha RX-V793. It works perfectly fine. Now I have a new LCD screen, a new DVD player and my new cable tv set top box. All 3 take and use HDMI. I'd like to be able to HEAR BOTH my DVD...
hi,
u can make connections only through digital inputs(optical and coaxial). u can connect the digital outputs of ur dvd and cable set top box to the receiver. no way to connect HDMI. HDMI is a high definition media interface. for using it u have to go for a av receiver that supports HDMI.
ok
Dec 23, 2010 | Yamaha RX-V793
Hitachi DV-p345 dvd player. It plays old DVD's like Madame Bouquet but does not play modern DVD like Meet the Fockers says bad disk, the DVD plays fine in a PC. Plays Mpeg music CD's also. Is there some...
yes all resent dvd's changed to DVD VR mode (DVD Video Rom) where it used to be only DVD R, you might also having a problem on zones, if the new one come form anywhere but Australia there is a zone different and it will not play (just because you brought it here doesn't mean it came from here)
Sep 27, 2009 | Televison & Video
The volume will not work. i have tried everything, the mute is not on, the audio button has been tried. the tv works fine but when the dvd is loaded, the sound disappears.
hi sir
the problem can be in he dvd software as it may be the cause or please check the wires it may be very old which may hamper.
thanks
Jun 29, 2009 | Cyberhome CH-DVD 300 DVD Player
Hitachi l42vpo1u no sound through hdmi
HDMI port damaged, mainboard need to be replaced.
But be absolute sure your HDMI port is not working properly, I recommed you try it again with another HDMI cable, you can also try same cable in another TV.
Bye
May 18, 2009 | Televison & Video
Black and White menus and playback
If you are connected on av2,make sure it is not on av2s,as this will give a b/w pic
Mar 07, 2009 | Panasonic Televison & Video
Pictures fine.. but absolutely NO SOUND....
in menu-audio-advanced settings-internal speakers should have check mark beside,
Using dvd player do you have sound??
Jul 22, 2008 | Hitachi 43FDX01B TV
Play cd and dvd but no sound
this is a simple problem in u r speeker so first remove u r speeker and chek the connections are perfect r not if the connectinons r fre fect then the problem will be in speker,i hope so the emiter is lost so once u see the connections and if u find nothin in it change the speeker then u r problem will be solved
Feb 25, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Video on game and dvd seem to work
DO you have hdmi monitor turned on?
Jan 05, 2008 | Onkyo TX-SR605 Receiver
Snowy screen playing dvd's
1.Check audio/video RCA jack cables
2.check S-video(if you use S-video cables)
3.check with another dvd player to get normal picture on your tv system. if picture is normal in this process. then problem with your old dvd player.
4.if same problem occurs in other dvd player. then problem with your television. external audio/video processing circuits
5.if the tv is ok. then the problem with your old Dvd player audio.video converting circuits
6. if can be rectified by authorised service engineers
7.Contact service engineer. as there is no recitification process from user part
Dec 15, 2007 | Hitachi 43FDX01B TV
Hitachi C25-RF35S 25" TV Logo
126 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
