How do you change the developer (powder) on the OCE 2510?
I have the developer (powder for the machine already). I just do not know how to change the powder. I am pretty good with electronics and such. I just need to be pointed in the right direction. Thanks!
2 Suggested Answers
  • 1297 Answers
SOURCE: Oce tds 400 random black lines on demo print
Check the developer and clean the charge corona and the transfer /separator corona assy.Clean the PH unit lens.
Posted on Jan 29, 2013
Loud toner error
The machine does not use the toner directly from the bottle, it goes thorught a developer chamber filled with developer powder. Then the toner is charged and can "jump" over to the latent image of the drum.
In this developer chamber, there are some small gears (2-3 tiny gears) that may be worn out. Some developer may have entered the "gearbox", and the deveoper powder is very abrasive.
The teeth of the gears will eventually stop to contact and mesh up. The internal parts of the developer changer stops to revolve, and there is no toner mixed with the developer.
You can see that there is a build up of toner, but it does not enter the developer unit. These gears have to be replaced, and I allways change the developer powder at the same time.
mp 2000 developer gears-2rhlv5r3sdqqpeuzs0ozcjtp-5-0.jpg These gears must be replaced it they are worn. The image shows a brand new part that contains the gears.
mp2000 developer toner input side-2rhlv5r3sdqqpeuzs0ozcjtp-5-1.jpg This is the side of the developer unit where toner enters the developer unit. With defective gears, the developer unit can not pull toner inside of the unit, and the toner builds up in front of the unit.
The gears are cheap, but will often result in the need of new developer powder - and that is expensive.
If print quality does not have to be too good, one can use the old powder and save money. Some of the powder is lost during use, and leaks. There may be some dust in the developer too.
In order to get high quality several parts may need to be replaced.
It is quick and easy to change these gears, just a bit dirty job.
Jun 24, 2017 | Ricoh Office Equipment & Supplies
I changed the cartridge in my oce fx3000 copier and I still get the message "change drum" and it won't work
The toner cartridge is a completely different unit from the drum unit. The drum unit is replaced separately, and is good for about 25,000 pages. The toner cartridge contains the toner powder. The drum actually fuses the toner powder to the paper.
Feb 26, 2015 | Office Equipment & Supplies
Oce tds600 error code in 05701
This is a "developer pollution" error. You probably are getting a message referring to a failure to optimize what you are trying to print.
That being the case, perhaps a change of the "ink" is in order or whatever you can do to clean the machine as something something is gumming up the developer..
This OCE is a Cannon company. If your manual has no cleaning instructions, you are at the mercy of techs familiar with doing the process for your machine. Or, you might get lucky with tech support of Cannon. Typically, manufacturers would be about the only ones able to identify what such codes means. Hope this helps.
Nov 09, 2014 | ErrorExpert Computers & Internet
Toner rate for oce 9400 is very low
How much black is on the page. Manufacturers usually base theirs on approx 5% coverage. Big title blocks and pictures us more toner.
Dec 27, 2013 | Office Equipment & Supplies
I have Printer refill powder in plastic bag, can i use it to refill some printers catridges or i need machine to make refill ink?
whats the model no of the machine? ink and toner are 2 totally diffrent things one is a powder and other is a liquid
Sep 25, 2013 | Konica Minolta 8936-488 Developer Model...
Jan 29, 2013 | OCE Office Equipment & Supplies
HOW TO PUT DEVELOPER IN OCE 9400
Take out the developer assembly, vacuum it out completely and put in new developer. Generally this is done by a trained Oce technician.
Sep 19, 2012 | OCE 3140 Copier
Developer pollution error. Generally happens if the machine runs out of toner and nobody fills it up after it asks for toner. If there is no toner in hopper, add a bottle. If there is toner, call your authorized Oce technician.
Sep 01, 2012 | OCE Office Equipment & Supplies
Put wrong toner in machine now prints are black
There is only one way to solve the problem. Call a oce service rep. to come out and have them vac. out all of the wrong toner out of the hopper & developer unit and give the bill to the person that put the wrong toner in to begin with.. Good Luck...
May 27, 2009 | OCE Office Equipment & Supplies
24 people viewed this question
k24674
jasbo
jasbo
