Question about Alesis Palmtrack Handheld Portable Digital Recorder, 24-bit Sd
Alesis palmtrack factory reset
My palmtrack can't see the sd card on powerup. I'd like to do a "hard reset" to initial factory settings to see if that helps.
How to do a factory reset on a alesis s r 16 drummer
Power up while holding play-erase. BUT...when performing a re-initialization, this will erase all existing patterns, songs, and drum assignments. This will not erase the factory preset patterns or kits.
http://community.alesis.com/alesis/topics/sr-16-factory-default-reset-question
Sep 27, 2017 | Alesis Music
How to erase data on nokia n800 rx34 tablet (hard reset) and can I use one of the sd memory slots as a Sim card slot?
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones
HARD RESET:It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset
•Enter the code: *#7370# and press Yes to confirm initialization.
•Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc)
•To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons:
•on/off + * + 3
•Before making a Hard reset better backup all your important information: contacts , memo...etc
May 24, 2017 | Nokia Cell Phones
How do i do a hard reset on my kurio kd interactive
To factory data reset a kurio 7, Click settings Scroll down to Backup & reset Click Facotry data reset
Click Erase SD card to erase an SD Click Reset tablet -
Nov 28, 2014 | Tablets & eReaders
SD CARD reader error: Insert removable disk into drive F:/
One of two I was say is the issue.
  • When you improperly ejected the card you messed up the MFT (master file table) on the card. You will want to format the card.
  • You could have hosed the drivers. In Device manager look under the driver details there should be some files listed. You will probably need to delete these and replace them. Since they may be system files you would need to replace them in a live boot environment such as a linux live boot cd (ubuntu.com) would be the easiest. Get the drivers it has listed copy them to a thumb drive. Boot the computer to the live CD, delete the driver files and replace with the new ones.
Dec 18, 2012 | Electronics - Others
Won't Record From Shotgun Mic.
Adjust Recording Levels.
Win 7Start > Control Panel > Hardware and Sound > Sound > Microphone >Properties > Level.
Oct 04, 2012 | Alesis PalmTrack Handheld Portable SD...
Frozen Galaxy Tablet
Update your firmware by using your sd card... place sd card in compurter...Go to galaxy website download firmware to your sd card then follow direction from website how to start the download on your galaxy.Good luck
Dec 17, 2011 | Samsung Tab Tablets & eReaders
Good day! I have a Samsung galaxy 5 phone here and the problem that i encountered is that when I will insert an SD card to the sd card slot. it will say " Blank SD card" although that card is not...
Copy all your valid information from the SD card to your C: drive, and burn the files to CD-recordable.
Then, insert the SD card into the phone, and allow it to "format" or "initialize" the SD card for use with your Samsung device.
Jul 20, 2011 | Computers & Internet
Hello, I have a HTC HERO, or better I've had, because now it doesen't read any more my SD Card, and without this it's not usefull anymore. :( I've restarted my phone , i've changed the...
That does not sound fun, I know my brother has had this problem with his HTC phone. What he did was that he formatted the memory card and also hard reset the phone. This returns the phone in to factory settings and you will loose everything personal not stored on the memory card. Hard reset can be found if you press HOM > MENU, then tap Settings > Security > Factory data reset. Begin with doing that and maybe, if your lucky it will solve your problem.
Good luck, and please if you find my answer helpful please give it thumbs up :)
Jun 08, 2011 | HTC Hero Smartphone
The process android.process.acore has stopped unexpectedly. please try again keeps appearing not allowing me to do anything but turn it off what do i do
I would preform a factory reset (note: this will erase all messages, contacts, settings, apps, etc.). To do a factory reset, go to: 'Home' > 'Settings' > 'SD card & phone storage,' then select 'Factory data reset.'
I hope this helps!
May 07, 2011 | Computers & Internet
Open Questions:
Alesis Palmtrack Handheld Portable Digital Recorder, 24-bit Sd Logo
Top Alesis Computers & Internet Experts
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Alesis Computer and Internet Expert? Answer questions, earn points and help others
