Question about GE Refrigerators
GE Profile water filter light will not go off after the filter has been changed, water has been run through the new filter, reset light has been pressed for three seconds (several times) and it remains orange/yellow. How do I turn the light to green?
SOURCE: reset the water filter indicater light
hold light and lock buttons until lamp blinking release and lamp turns off no it is reset.
Posted on Mar 03, 2008
SOURCE: Water filter indicator light
On my samsung I needed to press the ice timer and ice mode together for 3 seconds.
Posted on Mar 29, 2008
SOURCE: Can't reset indicator lights when water filter is changed
My manual says to "Press and hold the LIGHT and LOCK pads until the CHANGE FILTER light blinks (approx. 3 seconds). The control is now reset for 12 months or another 416 gallons.
Posted on Aug 12, 2009
SOURCE: Water filter warning light
Push the light - it will flash red after a few seconds -then turn green.
The answer above on this page was correct
Posted on Oct 14, 2009
  • 288 Answers
SOURCE: GE Profile refrigerator temperature problem
refrigerators have 2 coils. the evaporator coil and the condensing coil. one is on the bottom of the fridg and one is on the back or inside behind a false panel. these coils must be kept clean or if the condensing coil cannot reject the heat absorbed by the evaporator, the box temp will stay high and if the evap coil cant absorb heat the box temp stays low running the risk of freezing
Posted on Nov 27, 2009
I have GE profile refrigerator with bottom freezer the indicator light to replace the water filter came on I did so but it will not pump out water I held the reset button for 3 seconds still nothing
Double check the filter install you did. Make sure there isn't any clear plastic seal over the center hole of the filter and retry the water. If it worked before the problem has to be in the filter install or the filter is possibly defective and wasn't manufactured properly. The reset button is only for the warning light---has nothing to do with filter or water operation.
Apr 10, 2015 | GE Refrigerators
Filter light will not turn off
Resetting your Refrigerator filter indicator light after changing your water filter
Some people are not aware that after you change your refrigerator water filter, there are two more steps that should be taken to complete the water filter change process.
Step 1:
Reset your water filter indicator light - Most new refrigerators come equiped with an indicator light that notifies you when it is time to change your water filter. This light does not automatically reset when you change your water filter. Here is a list of refrigerator manufacturers and how to reset the indicator light.
GE General Electric Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Step 2:
Flush a couple of gallons of water through your new filter. Since most refrigerator water filters are made of carbon, some carbon residue is present in the first gallon or two of water. This will leave a bitter taste and residue in your water. If you continue to have these problems after flushing a couple of gallons through the filter, it is possible that you have a defective water filter.
Nov 11, 2012 | GE PFSS9PKy Refrirator
How do I change the water filter on my GE Profile French door refrigerator?
The filter on the one I know (see below) has the water filter in the upper right of corner of the refrigerator. In my experience, you should move all food from that side of the top shelf of the refrigerator and put a shallow pan underneath. Some water will spill.
First get the cover out of the way by pressing in on the tab on the front and tilting the cover down. Remove the old cartridge by rotating it counter-clockwise. The front end of the cartridge is shaped to make a handle. Use care in case any air bubbles have built up behind the cartridge; they could force the cartridge out suddenly. Remove the foil from the end of the new cartridge. Line up the arrow on the cartridge and the arrow on the cartridge holder and then rotate the cartridge clockwise until it stops. You will feel a "click" as it locks into place when properly installed. The grip on the front should be positioned vertically. If the cartridge is overtightened, it will leak. Close the cover and the refrigerator doors. Run the water dispenser for 3 minutes (1 1/2 gallons of water) and discard the water. This will clear the line and prevent future sputtering. It will probably sputter while you do the inital clearing.
Reset the water filter replacement light by pressing and holding the Reset Water Filter pad for 3+ seconds.
The manual for most GE refrigerators are available online from the geappliances.com site. A very similar unit has the manual here: http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=PFSS5NJWSS .
I hope this helps.
Dec 16, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
I just installed a new MSWF water filter cartridge on my GE Profile refrigerator. After pushing the reset button, there is no water flow at all. I can hear the pump humming. I tried removing and...
Tried new filter. Thought water line frozen. Problem solved by bypassing the water filter. Now that I'm working without filter I will troubleshoot the filter receptacle.
May 04, 2010 | GE Profile 25.5 Cu. Ft. Side-by-Side...
No water, no ice, but new water filter cartridge
If it was running before the filter change you need to purge the filter cartridge of the air in the lines. Also check voltage on the back on the water control valves . While someone presses dispenser you should get 120volts AC on the plug receptacle side for the dispenser . Let me know what you find, Sea Breeze
May 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
The warning light to reset filter came on. I've
Resetting your Refrigerator filter indicator light after changing your water filter Some people are not aware that after you change your refrigerator water filter, there are two more steps that should be taken to complete the water filter change process.
Step 1:
Amana Refrigerators - Press and hold the Auto and Dispenser Lock buttons until the water filter status indicator light flashes.
Frigidaire Refrigerators - Press and Hold the Reset Button Until the Indicator Light Flashes.
HotPoint Refrigerators - Press and Hold the Reset Button for around 8 Seconds.
Jenn-Air Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Kitchen Aid Refrigerators - Press and Release the Light Button 5 times Quickly.
Maytag Refrigerators - Press and Hold The Light and Lock Buttons until the Water Filter light flashes.
Samsung Refrigerators - Press and Hold the Ice Type and Child Lock Buttons at the same time for 3 seconds.
Whirlpool Refrigerators - Press and Release the Light Button 5 times Quickly.
Step 2:
Once these two steps are completed, you are all set to enjoy great tasting ice and water through your refrigerator. If you don't see your manufacturer listed or the insructions don't work for your model please post a comment with your make and model number so that we can provide exact instructions for your model.
May 06, 2009 | GE PDS22LBN Bottom Freezer French Door...
GE PROFILE PSS26msrd Ice maker not working water dispensor ok new water valve new filter fill tube seems clear Does anybody have any sugestions before i replace the ice maker unit?
water does become ice inside the pipe in side the freezer it happens to my frige at list once a year, put a hard wire or pencil up to make sure that is not the problem, before you spend any more money
Dec 06, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
