Question about Motorola Mobility Droid (2 GB) Cell Phone
Droid 2 phone keeps powering off
Keeps powering down saying no service and it keeps putting up this circle with a line threw it.
Press call butnon
Posted on Jan 07, 2013
Incredible 2 phone won't turn on
your phone is not supported 32gb memory card that's why your phone is totally hang so if u want to fix it you have to update your software and go to a service station
Jul 09, 2017 | HTC Droid Incredible 2
Is there another way to power on a droid 2?
It's happened to me a few times recently. Simply taking out the battery, then putting it back in usually does the trick. Try plugging in the charger with the battery in. If that doesn't work, take battery out, plug in charger, then put battery back in. Hope this helps.
Mar 03, 2012 | Motorola Mobility DROID 2 Cell Phone
When i turn it on and it gets to the screen where it says verizon wireless it just keeps flashing verizon wireless over and over.
hi,well on the droide,you can try this first,,power off the phone..then remove your sd card and sim if aplicable..
then push and hold the camara button,and then push and hold the power button,in a few seconds youll see the boot screen come up..
it will give you the option to restore the phone or boot the phone.
o restore ,or down to boot,try the boot first because the restore will cause you to lose your data.hopefully you have backed your contacts up..if just doing the boot dosnt work,follow these steps again to do the factory restre..If that dosnt work contact me here and ill
Oct 05, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
Htc incredible keeps saying droid and loop[ing from white htc screen to "droid" screen
Try to update to the latest android version. Your carrier might help you with this because it is so new. However if you dropped it (etc.) and your carrier doesn't replace it for you, You can get the part at Droid Repair and there is a guide that shows you how to put in the part at Droid Repair Guide.
Feb 16, 2011 | HTC Droid Incredible Cell Phone
Well my motorola droid is slow I don't know why I recently bought it and it takes a long time for a video to load while am using my normal 3g network
hi daddy hector the motorola driod comes with a 16 gb card if you are using a 2gb the phone's memory is slowing the phone down. You need to put the 16gb card back into the phone. Now if you have the droid 2 the 3g is faster because it is using the a faster processor. Where you got the phone is also important. It sounds like you got the phone from an authorize dealer. Teh corp stores are selling the driod 2 global. So you need to speak to the corporate national customer service and see if your phone is indeed a brand new phone. Hope this help
Dec 24, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
My droid screen suddenly turned black but i could still use it, i tried resetting it by pulling the battery out but the same thing occurs. Whenever i would turn the droid back on, the Motorola symbol is no...
You might want to try a hard reset on the phone, it should put your phone back to normal if its a software issue, if its a hardware issue you might have to take the phone apart or send it in for repairs or warranty return.
You can hard reset your Motorola Droid if you want clear all of the data off of the device and start fresh. Here’s how it’s done.
1. Turn the Droid off. If it won’t turn off, take the battery out then place it back in.
2. Open the keyboard and press the X key while pressing and holding Power. The device will power on. Keep holding the buttons down until a yellow triangle appers.
3. Press the Camera and Volume Up buttons at the same time to get to the menu. (I had to press them several times).
4. Use the direction pad to the right of the keyboard to select the Format option.
Aug 16, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
My droid is on the pattern lock page (i do know what the pattern is) but it wont let me put the pattern in. I have removed the battery and powered the phone back on and the same thing happenes it is just...
You can hard reset your Motorola Droid phone if you want clear all of the data off of the device and start fresh. Here’s how it’s done.
Jun 14, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
My droid wont unlock
DO A HARD RESET ON IT
*Turn the Droid off. If it won’t turn off, take the battery out then place it back in.
*Open the keyboard and press the X key while pressing and holding Power. The device will power on. Keep holding the buttons down until a yellow triangle appears.
*Press the Camera and Volume Up buttons at the same time to get to the menu. (I had to press them several times).
*Use the direction pad to the right of the keyboard to select the Format option
www.usedcellphoneshop.com
May 24, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
I dropped my droid in water about two weeks ago. I removed the battery and placed the phone in a zip lock with some rice for several days to dry it out. Unfortunately I don't think it was dry enough when...
If you're out of warranty, you can try to open the DROID and remove all traces of the waterdamage. There is a Droid Repair Guide that shows you how to take it apat. There are services that can do it for you. Droid Repair.
Jan 06, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
Motorola Mobility Droid (2 GB) Cell Phone Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
