Question about Euro-Pro 7535 Mechanical Sewing Machine
How to lubricate - Euro-Pro 7535 Mechanical Sewing Machine
  • Euro-Pro Master
  • 7,365 Answers
Check with euro pro and ask them if you can lubricate the machine
or if it's self oiling
http://www.sharkclean.com/
Posted on Jan 08, 2013
My featherweight 221 white machine seems to be running slow
Lubricate the motor and the gearbox on the underside . Unplug and cycle the sewing arm manually spreading the lubricant feel for the sewing arm to release from being hard to operate. Put it all back together. Plug the unit in and practice sewing arm movement on a piece of scrap material. Run it forwards and backwards if adequately lubricated it should free up of the excess traction on arm movement.
Nov 09, 2017 | Sewing Machines
How do you lubricate the machine?
Your manual should have directions on how to oil and lubricate your machine. If you do not have a manual a make and model number is needed to help you further.
Jul 09, 2017 | Sewing Machines
Routine lubrication
Lubricating...
Some sewing Machines w/computer is equipped with a
LM (low mass) hook system which requires no
lubrication. But...
HINT*** If however you do lubricate any parts, always
run the sewing computer immediately afterwards
on scrap material to avoid soiling your work!!!
Apr 11, 2015 | Sewing Machines
Not sure where to oil my sewing machine
Each machine has different lubrication requirements look to your user manual for lubrication points and how often to lubricate.
Cheers,
Kelly
Apr 21, 2014 | Sewing Machines
Does the Singer 221k7 need to be lubricated? If so, where?
contact singer customer service and ask them if your machine
needs to be oiled
Mar 27, 2013 | Sewing Machines
Where exactly do I place the oil for singer model 7442
The 7442 is permanently lubricated, and has a self lubricating design, you shouldn't have to oil it yourself at any time.
Are you having another problem that perhaps makes you think it's a lubrication issue?
Jul 01, 2010 | Singer 7442 Mechanical Sewing Machine
The side wheel controlling the needle/the sewing has suddenly gone very stiff & will only turn forwards not backwards. I have been sewing through polythene not fabric. Is it this which has caused the...
DO NOT LUBRICATE THE MOTOR!! The machine needs to split, ie the outer casing needs to be removed, inspected, and CAREFULLY lubricated. It also might be that as you have been sewing heavy fabric you could have knocked the timing out.
Oct 13, 2009 | Bernina Sewing Machines
Where do u oil the machine
lubrication depends on the make and model of machine. most newer machines require very little if any oil by the user, however should be serviced by a technician every year or 2.
generally speaking lubricate all moving linkages or sliding or rotating shafts at the point where metal to metal contact is made. use good quality thin lubricant which will not 'gum up' after a few months.
scott.
Jul 28, 2009 | Singer 3116 Simple
My husqvarna 905 serger is making a noise and starts running in slow motion. If it needs to be oiled the instruction booklet lacks that info
Lubrication points are in section 3-12 on page 34 of my manual. Look for Lubrication in the index if you don't find it there.
The 905 should be lightly lubricated each time it is used or after about 6 hours of operation. I recommend removing all lint and lubricating when you are finished working for the day so it will be ready to go when you need it next.
It should also be serviced regularly, depending on how much use it gets. If it is furry around the edges, find a certified repair center that you can trust. Ask around at any sewing get-together and you will be able to determine a reliable technician to take it to.
Jun 12, 2009 | Husqvarna Huskylock Computerized 905
My Husqvarna Prism 990 only sews in reverse.
You could have an electronic problem on the main printed circuit board or in the feed length stepper motor. You may also just have a bound section in the feed mechanism. I don't think there is a cure all answer for this problem.
A 1/2 second hesitation between depressing the foot control and motor response is very common in these machines
If your husband lubricated the bushings on the upper and lower shafts of your 990 I recommend that you have him remove all of the lubricant possible and keep your fingers crossed. The 990 is a self-lubricating machine and applying machine oil to these bushing will probably cause them to seize. The 990 should never be lubricated in many of the places you would lubricate many machines. Hopefully, you haven't done irreparable damage.
Apr 21, 2009 | Husqvarna Viking 1
Euro-Pro 7535 Mechanical Sewing Machine Logo
41 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
