Question about Zanussi ZWD12270 Front Load Washer / Dryer
Zanussi zwd12270s leaking from filter
No obstructions also did a hot wash with no powder to clean through
  • perry_sharon
    perry_sharon Jan 07, 2013
    Do I check in hoses or out
  • 1462 Answers
SOURCE: Zanussi F1045W Front Load
indicated low water pressure from your external supply or blocked filters in the fill hose. turn water off, remove hose and check filter in end of hose - it is just a bit of gauze. also look into the valve and clean out if needed
Posted on Jul 20, 2008
barkencoa
  • 3463 Answers
SOURCE: Leak after cleaning out filter
Make sure that you have screwed the filter back in tight, and also check that there is no dirt or anything else round the filter seal to stop it sealing proerply.
Posted on Dec 10, 2008
  • 43 Answers
SOURCE: zanussi zwf1432s washing machine. Barrel not turning.
take off the sump on the bottom of the drum mybee a hair clip or some thing inside
Posted on Jan 06, 2009
SOURCE: Jetsystem blocked.
I had the same problem, if you undo the self adjusting clip that holds the drum seal in - then pull back the top of the seal near the nozzle thats blocked, this will reveal the pipework attached to the nozzle. Then use a pipe cleaner and push up through nozzle - the attached pipe is clear so you will see any gunge and be able to loosen the debris. After cleaning reassemble seal then run a empty cycle which will clear the loosened debris. Regards, Grant
Posted on Jun 07, 2009
SOURCE: zanussi washing machine filter
Open the panel at the bottom right of the front of the washer. Then pull out the drain hose and pull the plug from its end - this will drain most of the water. Then the filter turns anti-clockwise - if it is too stiff to turn by hand I use an open set of pliers or strong scissors to give more grip (It may be an idea to put a cloth between the pliers/scissors and the filter to offer some protection.
Posted on Jun 21, 2009
How to clean it
You could purchase front loader washing machine cleaning chemical or soap. My experience with cleaning chemical and soap was to just masking smell, not fixing the problem. I did a few search and came out with using vinegar, baking powder and bleach is most effective way to clean and get smell out of washing machine. ie run cleaning cycle with 1 or 2 cup of vinegar, let it run for 20 ~ 30 minutes and pause for 30 minutes (it help break it up) let resume and finish cycle. Run cleaning cycle again with baking powder. If your machine don't have cleaning cycle use hot water and heavy load setting. Hope this help you.
Apr 19, 2014 | Zanussi FS1255S Front Load Washer
I have a hoover hsw2125m washer dryer. the powder is not emptying from the drawer but i dont know how to check for blockages?
A lot of times the hose gets just clogged. What you do is get a tea pot, and boil some water. Then carefully pore some hot water slowly down the drawer, little by little until it breaks up the soap to unclog it. Another affective way is buy a can of air in a can. Compressed air in a can is used for many uses, such as cleaning a key board or lightly blowing out electronics, can get it at almost anywhere they sell computers. Then you do small burst of air in the detergent drawer. However I would try the hot water first, and save some hot water for a cup of tea as your patience of having it work. Thanks Mike
Apr 07, 2012 | Zanussi FLE1416W Front Load Washer
Washing machine won't drain
Check the inlet to the pump for blockage, make sure that the outlet pipe is not kinked, that there is nothing obstructing the pipe. Check the filter to see if it is not clogged or obstructed. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Apr 02, 2011 | Miele Washing Machines
,seems as though washing tablet dos not desolve during wash leaving glass with a coating off powder on them,filters have been cleaned
John, clean filters, add salt and rince aid and buy a bottle of dishwasher cleaner and run the cycle on the 70degree setting. Good luck!
Aug 11, 2010 | Zanussi Dishwashers
Washing cycle stops before finishing
Hello, i have exactly the same problem. Did you find the solution?
Thanks
May 24, 2010 | Zanussi ZWD12270 Front Load Washer / Dryer
Dishwasher detergent clumps in pre-wash and main wash compartments
Make certain that there are no apparent obstructions between water and detergent. If no obstructions and the detergent dispenser and spray arms are operable, then the detergent should dissolve during wash. Otherwise, try using a different kind and amount of detergent (e.g.: powder vs. gel or gel vs. powder, and less detergent). If still clumping, contact an appliance service company.
Feb 20, 2010 | Maytag Dishwashers
My Zanussi FJ 1254W has suddenly started leaving lots of undissolved powder in the clothes after washing. I've checked that the filter is clean, and used Calgon though a couple of washes, but it hasn't...
Try filling it up with HOT water and vinegar use about 2 cups for a full load. Also take the hot and cold water hoses off the washer and check the screens for little sand like rocks that can block the water flow. I always use liquid and not the powder. Another thing is not to put the clothes in first. After you try the other things first then try to add the water first with the powder and then put the clothes in. Don't over load the clothes. This can cause the powder not to dissolve either. Hope this helps.
Dec 06, 2009 | Zanussi FJ1254W Front Load Washer
Jul 20, 2008 | Zanussi F1045W Front Load Washer
Hotpoint Aquarius Extra WMA48
firstly you will need to take out the soap drawer and thoroughly clean it and the spray holes that are above the soap drawer. secondly i would reduce the cold water pressure to a fast trickle/jet that way it will not be spraying all over the place. the filter sounds as though it will need cleaning out. unplug machine, from the rear is a metal plate, remove it to gain access to the bottom hose-this incorperates the filter. undo secure jubilee clip and lower hose. remove debris and check the hose and pump for further obstructions. you should be ok after that. try to beat out the dog blankets outside b4 washing to remove as many hairs as poss. tone.
Jun 11, 2007 | Hotpoint WMA48 Front Load Washer
Zanussi ZWD12270 Front Load Washer / Dryer Logo
60 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
