How to install new heating element on LG ptac model LP090CED-Y8
How do you install new heating element on this ptac?
2 Suggested Answers
kevin_getz
  • 1031 Answers
SOURCE: wall oven wont heat up even when new element has been installed but everything else works
Check your circuit breaker for trips. You may have a bad thermostat.
Posted on May 25, 2012
How do I hook up remote thermostat to LG LP120CED?
Some thermostats have a five minuter time delay to protect the A/C when power fails. Some units also have a time delay, if so both must be satisfied before it will start.
Aug 08, 2015 | LG Heating & Cooling
I have a LG LP150HED-Y8 AC, A CH CODE LIGHT CAME ON HOW DO I FIX THIS?
Low pressure switch will shut down right after starting when it is low on freon. A small amount of freon will get it started but when the compressor starts it moves freon from the low line to the high
Jul 28, 2015 | LG PTAC LP150HED Thru-Wall/Window Air...
I have an LG hotel ac/heat ptac unit. It is showing a code of FP what does this mean?
I'm pretty sure the FP code means freeze protection engaged. It prevents the outside coil from freezing
Feb 19, 2015 | LG LP076HD3A Packaged Terminal Air...
Ge Zoneline PTAC Model AZ28E12DABM3. Marginal heating. This unit only seems to put out marginal heat. We pulled the heating elements and found one of the strips burnt. We installed a new element and t
These units are energy efficient ,so much so that the elements are designed not to heat too much. Not sure as the manufacturers specs, that will be on the schematic. Unfortunately, there is no fix for this.
Jan 13, 2015 | GE Dryers
Sanyo PTAC model STB0823H1 elec. heating element
Try 1st link for Support Request, 2nd link enter zip code
http://shop.panasonic.com/hvac/how-to-buy/distributor-locator.dot
Dec 12, 2013 | GE Zoneline Deluxe Series Cooling &...
Zone aire ptac
sounds more like a relay
Nov 15, 2013 | Heating & Cooling
Amana Ptac model PTC153B50AM, getting no heat
The heater relays on the circuit board are famous for going out in this model.. Can purchase circuit board for about $100 or individual relays for about $4. Have to solder them in.
Nov 13, 2013 | Amana PTC153B50AM Split System Air...
I have a FEDDERS PTAC/HP -07B/09B/12B/15B. It blows cold air only. NO HEAT!
First of all check your unit model has heater system. And then
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Jan 04, 2011 | Fedders Heating & Cooling
LG PTAC acting strange in heat mode
I believe the problem in lies in the dual stage heat mode setup on the thermostat, but the unit going into defrost does make the unit act kinda strange. Even more so than other types of equipment. I would suggest hiring a licensed HVAC service technician if the problem cannot be resolved by yourself.
Dec 15, 2008 | LG LP120HED Wall/Window Air Conditioner
I need a Service manual with part numbers for a ptac unit withe the folowing . Model number LP121HEM Serial number 612KA00552. I would like it in a pdf format if you could. Thankyou.
You can find the brochure, users manual and service instructions at this web site. I hope this works for you:)
http://us.lge.com/products/model/detail/Home%20Appliances_Air%20Conditioners_PTAC_LP121HEM-Y8.jhtml
Jul 01, 2008 | LG Heating & Cooling
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
