Question about KitchenAid KUDE70FXSS Builtin Dishwasher
KitchAid KUDE70FXSS Green light is Flashing 4 times
The Green light (Clean) is flashing 4 times and the Dish Washer is inoperable. Any suggestion is appreciated.
  • 901 Answers
SOURCE: start light keeps flashing but washer won't operat...
Check whether inlet water is flowing into the machine.
Posted on May 24, 2010
SOURCE: we can't get it to cycle.... the green light next
Found it; High temp scrub--Energy saver dry---High temp scrub---Energy saver dry--press start, close door ,wait for it to reset,open door press cancel and you are ready to go.
Posted on Sep 02, 2010
KevinWhite
  • 1902 Answers
SOURCE: DISH WASHER NOT WORKING, ONLY CLEAN LED FLASHING
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Posted on Mar 15, 2011
KevinWhite
  • 1902 Answers
SOURCE: CLEAN LIGHT BLINKS 7 TIMES
Flashing light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
Kevin
Posted on Aug 08, 2011
  • 107 Answers
SOURCE: The "clean light" is flashing
Indicates control hasn't sensed a rise in water temp during heat cycle. Make sure you hear the water being circulated during wash cycle. If so the heater, control board, thermostats or wiring are most likely bad. If heater, therms, and wiring check good its usually the control. When fixed press Heat dry- Normal-heat dry-Normal or High temp- air dry-high temp- air dry to reset control.
Posted on Sep 25, 2011
Led light flashes 4 times, pauses then repeats
Which light blinks 4 times and pauses wash normal heavy etc if the model in the blue box is correct the to enter diagnostic press any 3 keys within 8 seconds I usually use normal and the 2 keys to the right all lights should light up if touch pad is up top where you had to open door to accomplish this then close the door after a pause the clean light will begin to flash example 7 flashes pause 1 flash these are your fault code it will do this 3 times for each code. The tech sheet should be behind the toe panel located below the dishwasher door which just repeats what I explained.
Feb 04, 2014 | KitchenAid KUDE70FXSS Builtin Dishwasher
CLEAN LIGHT BLINKS 7 TIMES ON KITCHEAID KUDP DISH WASHER
Kevin
Aug 08, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dish washer the clean light stays on and the dish washer wont run
Kevin
Jul 15, 2011 | Whirlpool Dishwashers
I have filled dishwasher selected temperature and the start light is flashing but nothing happens I think the m/c type is 7197
The Start/Resume light is flashing
This flashing light indicates that your cycle or start-up was interrupted.
Possible causes: The door opened during the cycle, or the power was interrupted.
To resume operation: Make sure the door is closed, and press Start/Resume.
The Clean light is flashing
You should call for service if the Clean light is flashing and the machine is inoperable. It is normal if the Clean light stays on after the cycle is complete. The Clean light is an indication that the dishwasher has been run and that the dishes inside it are clean. Once the door is opened after the cycle is complete, the light will shut off.
The lights are rapidly flashing
Any key that gets stuck will rapidly flash. Press the key a few times in order to release it or press Cancel.
The Rinse Only light is rapidly flashing
If multiple keys are stuck, the Rinse Only light will flash. Press each key, one at a time, to release the stuck keys, or press cancel.
Jun 28, 2011 | Dishwashers
Green clean light is flashing, it will not clear and will not run because green light is flashing
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
Kevin
Jun 08, 2011 | Dishwashers
Kevin
Mar 15, 2011 | KitchenAid KUDE60FVSS 24 in Builtin...
The "clean" light is green, flashing.Dishwasher won't restart.
This is due to the water not heating properly. I have put together some instructions on how to reset the control so you can use the dishwasher again and what to check for as to why it failed. Follow the link and let me know if it was helpful.
Flashing Clean Light
May 23, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
The green indicator light "clean" is flashing and I am not able to start the dish washer
Go to your electrical panel and turn off the circuit breaker for your dishwasher [or remove the fuse]. leave it that way for two minutes and then put the power back on.. those steps should reset your machine.
Aug 12, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
The dishwasher won't start, the clean light flashes green 7 times
I have the same problem with ours Stock #17039 Type #575-0 Model # 665.17039401
Apr 14, 2009 | Kenmore 24 in. 16029 Built-in Dishwasher
Ariston dish washer model ll64xaus Lights 3&4 flashing and unit wont start
Hi pedretti,
I'm Harvey the Master Plumber.
Your problem is: Ariston dish washer model ll64xaus
Try resetting the d/w. Just turn off the curcuit breaker for ten minutes. Sometimes the control board needs to be reset. If this persists you may have to replace the board.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 28, 2008 | Dishwashers
KitchenAid KUDE70FXSS Builtin Dishwasher Logo
1,351 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
