Question about GPS
I have a used garmin pilot 6550 gps with the power cord that plugs into the lighter. I do not have the manuel or know how to operate it or how to program the maps into it. I need to know everything I need.
  • 50 Answers
Do you mean the street pilot c550? Most manuals can be found on their offical web site here: http://www8.garmin.com/support/userManual.jsp
You can also find instructional DVD's at:
http://www.bennettmarine.com/garmin.html
Posted on Jan 21, 2009
Garmin street pilot 330 charging problem
Linda,
You need to check the fuse for both the car's cigar lighter AND the one in the GPS power plug (that goes into the cigar lighter outlet). Both must be good for the GPS to charge and power up.
I don't know if your friends cord worked in you car - or hers - so you're going to have to find out if it is the cord fuse or the car fuse. Since her cord worked on your GPS, start by using HER CORD connected to YOUR GPS in both cars. If it works in her car, but not in yours, check & replace your car's cigar lighter fuse. If or when it works in both cars, disconnect her cable and connect your cable to your GPS again. Connect into your cigar lighter. If it works, you're done. If it doesn't work, disassemble the plug at the end of the GPS cord (cigar lighter end) and check and replace the fuse if blown. You should be good to go at this point.
Please rate this reply if found to be helpful - good luck!
Jul 07, 2010 | Garmin StreetPilot C330 GPS Receiver
Power plug broken, missing parts to get power
Eloise, did you ever find a solution to this problem with yur Garmin? I have the same problem and don't want to spend $40 for an entire mount. Let me know, you can email me at JeffWang3@gmail.com. Thanks!
Mar 28, 2010 | Garmin StreetPilot C330 GPS Receiver
Street pilot 330 will not turn on when plugged into car power supply. Poosible battery charge needed?
Does the car charger cord have a fuse in it at the point where it plugs
into the lighter port, a lot of car chargers have a fuse, I can't tell
if your end, the part that goes inside the lighter port has a cap that you unscrew to replace the fuse, and garmin does not show it.
If the car is running, and it does not work, there is something wrong with the car adapter, or the unit at the plug, the battery should not have anything to do with it.
If the battery starts the car the battery is fine.
Feb 07, 2010 | Garmin StreetPilot C330 GPS Receiver
GPS plug do not fit in car cigarette lighter
Buy a adapter for your cigarette lighter socket that has multiple sockets with one that will fit the Garmin adapter.
I've never heard of a problem you are having??
Are you using a Garmin plug?
If not get one.
May 08, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin street pilot c340 won't recharge. Loses charge while operating in the car and is plugged into the cigar lighter. Socket in car works as I use it to run other items like ipod etc. Have there been any...
Try to charge the GPS by using the USB cable and connecting to your computer. Of course the computer must be on. If it charges connected to the computer you can most likely assume that the 12 Volt car charging system is defective. Please let us know if this resolves your situation.
Thanks for using Fixya.com
Harleyknut
Apr 06, 2009 | GPS
My garmin street pilot 330 will not power on
I've had a couple of Garmin C330 units and a C340. They're good quality except for the flimsy power plugs. My first one out of the box had a defective plug which made intermittent contact when I plugged it into the lighter. Tightening the knurled nut on the tip of the plug helped somewhat, but didn't fix it completely. It became a non-issue after I bought a friction mount which came with a better cord and plug. The friction mount also stopped the problem of the suction cup constantly falling off the windshield.
Lee
Jul 08, 2008 | Garmin StreetPilot C330 GPS Receiver
GARMIN STREET PILOT-330 GPS
Hello KTFORE1,
The Street Pilot 330 comes with both a vehicle power cord and a USB cord for connecting the unit to the computer. If I understand you correctly the GPS isn't getting power from the vehicle power cord. Does the GPS charge if connected to a computer using the USB cable? If so the problem is likely the power cord or cigarette lighter socket you are using. If the GPS doesn't charge from USB port on your computer then the problem is likely the GPS itself.
If you determine that the cable is the source of the problem, check and replace the cable's fuse. You will probably also want to check and replace your vehicle fuses as the circuit that powers the cigarette lighter might have a blown fuse. If replacing the fuses doesn't solve the issue then you might need to replace the power cord.
Best Regards.
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Gps - street pilot i5 garmin
try this first-if the unit has batteries installed, remove them so unit runs on power cord only
Jun 01, 2008 | Garmin StreetPilot i5 GPS Receiver
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
83 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
