Question about Breville DF30 Deep Fryer
Deep fryer wont turn on
Machine wont turn on, has a reset button but still doesn't work
Wont turn on
Mine doesn't turn on either.
I keep pressing the power button but nothing happens.
Press it longer than 3 second.
Press it harder than normal.
Also press the reset button at the back.
Nothing works it just won't turn on.
The power LED does turn on, but the heater and the rest of the display doesn't work.
Mar 30, 2014 | Tefal Ultimate EZ Clean Pro Deep Fryer
Fryer turns on heats up and then will not keep temp.
You would be correct in your assessment to check the thermostat.
Jul 29, 2013 | American Range AF45LP Deep Fryer
I have a tefal family actifry and a green error flashed up and a long alarm. What is this telling me?
Tefal Actifry GH800215 user manuals GH800215
www.tefal.com/instructions.../Fryer/Actifry/Actifry.../1500634805
TefalThe Actifry Plus GH800015, GH800215 deep fryer allows you to make 1.2 kg of chips with only 1 ... To display Instructions & Manual, choose your language :.
Apr 13, 2013 | Tefal ActiFry Deep Fryer
The pilot is on but the switch won't turn the fryer on. The gas is on but it just wont fire up? Dean Fryer
I can tell you from my own experience with fryers, that they take quite some time to heat up....before lighting.... The probe takes some time to get hot, before it will kick on and light. You normally have to hold the light button on for some time, before the manual fryers will light. I have helped many a customer who cannot seem to get their manual gas fryers to light, and normally it's because they don't hold the light button down long enough. The sensor in there takes alittle time to heat up and it tells the fryer it's time to light. I think people get alittle scaried with gas and just don't hold it down long enough. Try holding that button in longer first, then light it... It should work. If not, call us and we'll try to walk you through it.... Our service tech is Ray, and I'm Susan with Restaurant Equipment Outlet, Cincinnati, Ohio, 888-542-5959. Thanks and good luck, Susan
Sep 10, 2011 | Frymaster Dean 2424G Deep Fryer
I am not sure what what model number I have, but when I try to light this older Vulcan deep fryer it doesn't light at all nor do I smell any propane. It's as if it's not getting any gas.
This is our number one issue with gas fryers... Not being able to get the unit lite.... Normally our service techs tell our customers they are not holding down the pilot light button long enough. The sensors in there take some time to get hot enough to send a signal to the pilot telling it to light... If you need someone to walk you through it, call Ray at 888-542-5959, at Restaurant Equipment Outlet.
Aug 31, 2011 | Vulcan EF3 Deep Fryer
The reset button on my Breville DF30 will not reset when pressed. So it is not able to heat up.
Hi there.
If the unit is cooled down and the button will not reset, you have to replace the reset button, its mechanical part may have worn out that's why it wont go back to its normal position.
Regards.
Jul 18, 2011 | Breville DF30 Deep Fryer
I have the AF45 fryer. I cannot light the pilot on this fryer. I have tried all possible solutions to this but still wont work.
Normally, on manual gas fryers, people don't hold down the light pilot button long enough for the sensors to heat up, to tell the pilot to light.... That's our number one complaint, and number one service call, and it's almost always the same thing;..... Hold the button down much longer, then try to light it... If you still have trouble, call our service tech, Ray @ 888-542-5959, at Restaurant Equipment Outlet, Cincinnati, Ohio. Thanks, Susan REO
Jul 16, 2011 | American Range AF45LP Deep Fryer
Please help
the the safety its pretty common on deep fryers with out that man i would be in trouble i leave mine on sometimes so its not a bad thing
Jul 08, 2008 | Wells LLF-14 Deep Fryer
Breville DF30 Deep Fryer Logo
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
