Question about Banner American Products Office Equipment & Supplies
Need plastic gear for itsh 555 paper shredder
ITSH 555
  • 329 Answers
SOURCE: Office max paper shredder
You need to find out who made the shreddr, Fellows, GBC, etc. parts are available to brand name machines...
Posted on Jun 24, 2008
  • 35 Answers
SOURCE: Broken teeth on drive gear wheels Taros paper shredder Taros 31.8
New gears are $88.50 plus freight. You won't find any used gears because these usually break first. I can help.
Posted on Feb 23, 2009
  • 3 Answers
SOURCE: NEED A REPLACEMENT PLASTIC GEAR THAT DRIVES THE UNIT
This Shredder is an Aurora AS650C Rebranded for Walmart as Durabrand. You can call Aurora at 800-327-8508 8-5 PST and tell them that you need one of the plastic gears for the WM6X Durabrand, they know exactly what your talking about, and will offer you two gears. The one that is in contact with the drive motor is gear "A" and the Plastc reduction gear that drives the steel gears is gear "B" Hope this helps
Posted on Jun 04, 2009
  • 7 Answers
SOURCE: Have a Staples shredder SPL 1506X and need to find
no there is not
Posted on Jun 11, 2009
  • 1218 Answers
SOURCE: How do I go about getting replacement plastic
For Royal parts and prices give Royal a call at 1-800-524-0799.
Posted on Aug 21, 2010
Paper jam
Does it sound like the motor is spinning? or does it sound like the motor is bound up? I ask because if it sounds like the motor is spinning, then chances are good you stripped a plastic gear somewhere in the drive system that feeds the steel shredder. I just pulled apart one of these and saw that the motor has a steel gear on it. that steel motor gear meets with a plastic gear, and then the plastic gear meets with steel gears attached to, and which spin the shredder. So if you ever bind the shredder with too much paper, the steel motor gear will grind the teeth right off the plastic gear and it won't spin anymore. If your motor sounds like it's bound, then the good news is that the gears aren't stripped. You'll have to take the shredder apart so you can remove the paper causing the problem. Of course unplug it first before opening it up. They are not overly complex but just remember where the screws goes so you put them back in the right holes.
Sep 01, 2014 | Office Equipment & Supplies
DX-PS10MC gear broken
Might have to go to eBay or Gumtree.
Mar 05, 2014 | Dynex - 10-Sheet Microcut Paper Shredder
ITSH 555 plastic gear stripped. Can anyone offer a source for these gears? I can't see throwing away a $50.00 shredder for a $.50 cent gear,
I have to believe that you could find a place online for this gear. My other thought is looking for a replacement out of an old printer, typwriter or something along those lines. The shredder is not that complicated and if you get a little inventive you probable have something broken at home that would work for that.
Jan 09, 2013 | Banner American Products Office Equipment...
I have a paper jam - Model ITSH-555. It's a small home model. The shredder makes an awful noise when it's on either in "Auto" mode or "reverse" and doesn't work. I can see the jammed...
Uplug the shredder and press the power button and hold it for at least 30 seconds to empty all energy in the machine.
Turn it over and use a pair of needle nose pliers to grasp the little pieces of paper hanging down and pull as many of them out as possible.
Turn it back right side up and find a hard plastic card (possibly a credit card that is no longer any good or similar) and see if you can push the card through the wheels where you insert the paper that is to be shredded. Pushing the card through the same way that you would insert paper should move the wheels and bring the paper out the bottom of the shredder.
If you are unable to get the wheels to move and release the paper out the bottom, then your only other option is to clean out the trapped paper manually. There are many ways to clean it out manually. You can use needle nose pliers, tweezers or a flat headed screw driver to try and get as much of the paper out as possible.
When you have cleaned out as much paper as you can, plug the machine back in and rock the forward and reverse lever back and forth to try and further the paper that is stuck to the outside of the machine. If it does not release the paper that is jammed inside the machine, it may push it further outside of the shredder or move it further along where you may be able to grab more manually and pull it out.
Unplug the machine and again remove as much paper as possible.
Repeat the steps above until you are able to clear the jam.
Dec 06, 2010 | Office Equipment & Supplies
Replacement plastic gear for a Royal 150MX shredder
For parts call Royal at 1-800-524-0799; they should be able to help.
Don't forget to lubricate the cutting shafts on x-cut shredders.
Apr 02, 2009 | Royal 150MX Cross-Cut Shredder
Jun 03, 2008 | Office Equipment & Supplies
Order main drive gear for geha paper shredder
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Feb 18, 2008 | Geha Primo 2600 Shredder
53 people viewed this question
Top Banner American Products Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Banner American Products Office Equipment and Supply Expert? Answer questions, earn points and help others
