Question about LG Phoenix P505 - Blue at&t Cellular Phone - Fl
Lg p505 boot loop problem
My phone will only turn on to the LG screen & will not boot properly. I can't do a hard reset. It will boot to the emergency mode or fastboot screens by pressing the Volume etc. keys! Help would be greatly appreciated! Thanks!
SOURCE: LG Flatron 775FT monitor distortion
Doesn't look very good :( You can try returning to the "factory settings" in your monitor's menu. Maybe try the monitor in another computer to check whether your graphics card is faulty. But all in all it looks like a fault from the monitor :( Good Luck!
Posted on Jul 27, 2007
SOURCE: Touch Screen not working
ı have problems about wıth my touch screen. ıt does not works sometımes.
ı have to restart my phone to make ıt work . can ı do somethıng more?
Posted on Sep 28, 2008
SOURCE: When I press the power button LG displaying chars for 1 second
Had the same problem, turned out it was due to a faulty capacitor on the inverter board, 680uF 25V (105 celsius rated). Simple to fix once you have the unit dismantled and the correct replacement part. Two screws hold the shroud on, but you need to be careful with an (old) credit card levering it off.
Unit is now working fine.
Posted on Oct 23, 2008
  • 140 Answers
SOURCE: LG RZ42PX11 PICTURE PROBLEM.
I do not know who was helping you before but the problem you are having can be caused by three boards in the tv each by themselves or in combination. Those are the control board with part#6871QCH053G, the Y- board part #6871QYH036D or the Z-board part#6871QZH041B. Without being able to do voltage and signal measurements directly for you, the Z-board is likely the culprit here. But I will tell you that even experienced tv technicians find themselves swapping one or more of the boards until they fix the problem. I am assuming here of course that you have not had problems with your tv before. The part #s I have given you are for the improved boards that LG has assembled to take care of future similar problems and come with their latest training manual for technicians. God bless and good luck.
Posted on Jan 15, 2009
  • 7 Answers
SOURCE: PLEASE HELP!! Volume control on LG KU990
The volume can be changed whilst in a phone call by using the camera/jog wheel on the back of the phone.
Posted on Apr 17, 2009
Lg flex 2 model LS996 turns on and off without charger like a boot loop but with charger plugged in will come all the way on past the boot logo to home screen then vibrate and turn off.
Battery is ahot. Same exact thing happened with my Samsung note2. I recommend an anker brand battery. Available at amazon or ebay
Oct 26, 2016 | LG Cell Phones
How do I fix a rooted LG Optimus Fuel stuck on LG splash screen loop
Hi there.
Usually a Splash Screen loop indicates that the Phone's Software / OS is corrupt and therefore will not boot.
I recommend having the device reverted back to Stock. It is likely that the Root firmware was not compatible or the Flash process was done incorrectly.
Jan 13, 2016 | LG Cell Phones
How do you hard boot into recovery mode,volume down and power then release both and press again on lg screan dont do it both ways only factory reset
Do not forget to backup your phone’s data before doing a factory data reset. Here’s our guide.
Performing a Factory data reset restores your device to the original factory settings as it comes out of the box. It also deletes the data like installed apps, contacts, messages, images, etc. present on the internal storage. It does not, however, affect any data stored on the external SD card. Now here is how you can hard reset your LG G2/G3 from device Settings:
Tap the Menu key from Homescreen.
Select System settings> General.
Now scroll to PERSONAL.
Select Backup & reset option.
Tap Factory data reset> Reset phone.
Select Erase everything.
When the warning window prompts, tap OK.
Hard Reset LG G2 with Hardware Keys
If you unable to perform a factory data reset on your LG G2/G3 using the device settings for some reasons, you can try the hardware key method. Just follow the steps given below:
Turn off your LG G2/G3.
Now press and hold the Power + Volume down buttons simultaneously for about 8 seconds.
When the LG Logo appears, release and then immediately re-hold the Power button.
Release the Power key as soon as you see the ‘FACTORY HARD RESET’ screen.
Press the Power key to reset your device.
Press the Power key again to confirm factory data reset.
Wait till reset is done.
Boot LG G3 /G2 into Safe Mode
To fix an issue caused by a 3rd-party app, you can boot your LG G3/G2 into Safe mode and delete the suspect app. You can turn on Safe mode by following these steps:
Jan 06, 2016 | LG Cell Phones
How do I fix my LG neon LITE?
touo have bricked your phone due to messing about with important files/partitions on their LG Neon LITE and found that it won't boot up and gets stuck in a boot loop. try to Flash / Unbrick your LG Neon LITE
Dec 28, 2017 | LG Neon GT365 Cell Phone
My LG Esteem will not turn on it will go to the MetroPCS saying and then shut off, nothing happened to the phone , its on the charger and still will not turn on , I have no idea why it was fine yesterday...
I would think not, i'd say memory may be filled up and the phone cannot load and store it's data so it keeps boot-looping you hopefully have your contacts on the cloud or backed up to a sdcard. If so you can do a hard reset this Will Wipe the phone settings out! Press the volume up and down together and prrss power when the lg logo pops up release power, The phone shuld prompt you to erase everything pressing power confirms and the phone is wiped to factory. If you have trouble try googling how to reset lg esteem but this shuld work. But sadly all data is gone afterwards. Good luck.
Nov 23, 2017 | LG Cell Phones
My LG KP500 doesn't turn on
You can buy all sorts of cell phone parts on ebay. Are you sure you have a fully charged battery in your phone? If the battery is charged, and the phone will not boot past the welcome screen, you will either need to do a hard reset to reinstall all of the operating system files or replace the motherboard. Do an internet search for LG KP500 hard reset for detailed instructions for the hard reset. Caution - this will delete all files which were saved on your phone. It will not delete files on your SD memory card.
Mar 28, 2012 | LG KP500 Cell Phone
Does anyone know how to access the reboot\Recovery menu on the LG Phoenix P505?
This WEB site may provide you the solution you need.
http://www.lg-cellphone.com/tip-how-to-reset-factory-settings-the-lg-phoenix-p505.html
Feb 25, 2012 | Computers & Internet
The touch screen doesn't work
here are various problems the lg ks660 touch screen could encounter. Although there are times when the screen does not work altogether, there are other situations when certain portions of the screen work and others don't. Press and hold the home button as well as the reset button on the top of the lg ks660 phone to turn the lg ks660 off.
May 09, 2011 | LG KS660 Cell Phone
I can attempt my lg gt540 mobile pattern code wrong then mobile is locked.so plz help me
dear friend,
visit unlock-zone.com for the help
hope this will do
enjoy & cheers
Jan 24, 2011 | LG GT540 Cell Phone
How to hard reset LG GW520? The phone starts up and come yo frozen screen. Thanks
Type for soft reset *#7780# . For hard reset *#7370# If it as default 1234
May 20, 2010 | LG GW520 Cell Phone
LG Phoenix P505 - Blue at&t Cellular Phone - Fl Logo
89 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
