Question about U-Line Icemaker
Uline UB12115 Submerded.
Can I Replace the fan motor and not the compresser.
Uline wine fridge 2075-wcs not cold enough
Check condenser make sure it is clean then listen to see if condenser fan motor is running . if compressor is running cuntinuesly and other mentioned are ok it could be low on Freon
Nov 08, 2012 | U-Line Refrigerators
Pure pro fan motor
compressed air , you might try bringing it to a electric motor repair shop or a auto shop and ask real nice if they would be nice enough to give your fan a shot of air. a weed blower will work also but not even close to the job of compressed air. last resort is to take it apart totaly and use soapy water and a scrub brush. do not get the motor wet ! and oil the bearings on the motor with zoom spout oil #D01.. and you can milk your favorite fan out for many,many years .. this way is like cheating death! ... jay the pool pump motor repair guy in longwood fl
Jan 12, 2012 | Montgomery Ward Pure Pro Air Purifier
Making a loud squeal or hum during
Sounds like a motor with bad bearings. In that unit it would be the water pump or condenser fan motor. If the sound is coming from inside the unit it is the water pump.
Nov 08, 2009 | U-Line SS95 Stainless Steel
Water still runs into ice bin after trays are full on our uline ice maker
This happens when the motor is running slow or the water switch is sticking. To take care of both things you need to replace the faceplate on the icemaker.
Sep 14, 2009 | U-Line Icemaker
No blower after 20 minutes of running but compresser is still working.
Check for oil ports on the fan motor. Oil the motor if ports are there. Replace the fan motor capacitor. If same problem persists, replace the fan motor.
Aug 02, 2009 | Coleman Mach III Air Conditioner
Describe your uline wine cooler Problem ULINE WC2015: Light comes on but unit won't run. Cleaned as discussed in owners manual. Need help!
OK if you have a 20 series and you have a light and no fan or compressor then you need a thermostat. This will have 2 wires to it and if you bypass the thermostat the unit should run. If it does then replace the thermostat
Jul 18, 2009 | U-Line Wine Captain (2015WC) Wine Cooler
Uline combo unit. Condensor fan will not run and
You just answered your question. If no fan is running then the compressor will overheat and the compressor goes off on overload. Do you have the evaporator fan running? If yes then replace the condensor fan. Both fans will run at the same time. If the evap fan is not running then the unit must be in defrost. Since its a hotgas defrost the compressor will run.
Hope this helps
Jul 13, 2009 | U-Line Refrigerator Ice Maker
Uline Icemaker has dammaged gasket door
no, you will need to replace the gasket. U-line gasket is easy to install. You can visit their website and under customer service you will see parts locator. The gasket just pulls out of the track and the new one pushes back in the track. www.u-line.com
Mar 18, 2009 | U-Line Uline Origins Series...
Uline 15RBK not cooling
hi!! make sure that the inside evaporator fan is on and that the compressor and condensor fan motor is on. if they are all on then you have a seal system leak of refrigerant..Good luck..
Jan 19, 2009 | U-Line 15R Compact Refrigerator
Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
Nov 04, 2008 | U-Line Icemaker
U-Line Icemaker Logo
78 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
jasbo
jasbo
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
