Question about Plumbing
I cant get the moen 107546 faucet off - Plumbing
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
Posted on Sep 03, 2009
digritz
  • 530 Answers
SOURCE: I cant stop my Moen single lever kitchen faucet
Even Moen faucets can wear out. The first thing you should do is check your warranty. Below is a link to there warranty information.
If the warranty period is over then your going to need to repair it or replace it.
In general, leaks are often caused by a scratched or torn cartridge, o-ring, or grommet. Typically, a cartridge repair kit or replacement o-ring will correct this type of leak so a repair is less costly.
Places like Home Depot, Lowe's or where you originally purchased the faucet should carry a repair ebuild kit. Most times on the back of the package there will be a diagram of the internal parts and how they assemble to help with installation. If not just take you time as you disassemble the faucet. First make sure the water supply has been shut off under the sink. Make sure you have a clean area to place the old pieces for reference. Having something to stack them on in the order they came out will help. Make sure that you check for any small set screws that may be used to lock things in place.
If you do this repair yourself and have any others questions or if you run into problems feel free to ask me for help.
Good luck.
http://www.moen.com/consumersupport/warranty.cfm?location=TopNavCustomerSupport
Posted on Sep 08, 2009
  • 44 Answers
1. If it's "leaking" from the body then, the O-Rings between the body of the faucet got gunked up with minerals from your water. This interferes with the seal.
The answer is to take some grit cloth/very fine sandpaper and clean the inside of the spout body. Wipe clean. I would also suggest replacing the O-Rings on the faucet body, but at the very least wipe the O-rings and faucet body clean.
THEN: lubricate the inside of the spout body AND the O-Rings with silicone grease. It's translucent and readily available and the only thing I would ever use for a faucet repair. NOT plumber's grease, NOT WD-40.
Reassemble and enjoy.
2. If it's dripping, the you need a new cartridge. You can get them for FREE from the hardware store if you have the old cartridge to trade them. The problem is that Moen cartridges are water-sealed into place and you need a special tool to break that water seal. The special tool (just a tiny piece of specifically shaped plastic, really) comes, you guessed it - with the new cartridge.
Two possible solutions: a) bite the bullet and just buy the cartridge (~$25) or buy a Moen cartridge puller, usually available from the hardware store as well for about the same price. Ask, they might even lend you one.
The point of whichever tool you end up with is to rotate the cartridge itself inside the faucet body to break the water seal so that you can pull it out with a set of pliers. There will be a retaining clip to pull out as well.
www.plumbingpartsdepot.com/moen7300.gif
http://img2.timeinc.net/toh/i/a/plumbing/faucets-toilets-07.jpg
Good Luck.
Posted on Sep 09, 2009
Testimonial: "this will give me something to work on. thanks"
  • 37 Answers
SOURCE: the moen began to leak over time now i cant turn the water for
Call moen and give them your model no. they will send you a new cartridge free of charge. if you can't wait local stores like lowes will have them. Turn off your main water shut off valve and take off handle, then with some pliers take off brass ring, the cartridge will pull out. First notice the notch it rests in and notice where the hot water adjustment disc is. Assemble the new one the same way, put some vasolene on orings and reassemble. hope this helps.
Posted on Jan 12, 2010
  • 94 Answers
SOURCE: leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Posted on Apr 26, 2010
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    Leaking CA87681 moen kitchen faucet
    Throw a cloth over the cover to prevent scratching the finish and grab it with a large pair of channel locks and unscrew it.
    Nov 18, 2013 | Moen 7907 Chateau Two-Handle Kitchen...
    The faucet drips and I cant figure out how to make it quit.
    It can be repaired without taking entire valve out of wall. First shut water off and remove handle. Next you will see a collar that will screw off to remove the cartridge below is a link for a single handle moen faucet. Check it out to get an idea. If you know your model you can research on line ,but they are close enough to give you an idea.
    Once appart replace washers or o -ring's. Pay attention to how you take it appart for easy reinstallation.
    http://www.moen.com/shared/pdf/t2703pt.pdf This link is aparts breakdown of a single handle faucet.
    http://www.moen.com/shared/pdf/t2703pt.pdf This site is installation instructions.
    http://www.efaucets.com/detail.asp?Product_Id=T2703 This site you can enter you faucet model to retrive information.
    Jun 19, 2010 | Moen & One Handle Tub & Shower Faucet
    Leaky moen 2 handle faucet
    Apr 26, 2010 | Moen Monticello Single-Handle Kitchen...
    How do I get to the valve cartridge to replace it?
    how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
    Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    The moen began to leak over time now i cant turn the water for
    Jan 12, 2010 | Moen 3175 Legend One Handle Shower Faucet...
    The cartrige inside my moen faucet leaks
    moens website. they have parts break down and diagrams
    Nov 30, 2009 | Moen F7425 Chateau Single-Handle Kitchen...
    After installing moen model 82248bn(Monticello) tub faucet 3weeks ago it has had a consistent drip from the faucet(one drop every 7-8 seconds). This faucet is brand new and I cant imagine the internal...
    Call Moen's customer service line. They are excellent when you have proof that you are the buyer of the product (Buy it for looks. Buy it for life.® ). They will walk you through the problem and give you a solution. send you a free part, tell you how to adjust, etc.
    http://www.moen.com/consumer-support
    Please rate me.
    Nov 21, 2009 | Moen Villeta 3813W Glacier Single Function...
    Moen 87135c - cant take apart
    On handle of faucet you will see a red/blue plug button, under that is a set screw. loosen and this will allow you to remove handle.
    Oct 03, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    I have leaks under my sink that appear to be coming from up inside my faucet. It is a Moen all in one single hole faucet where the sprayer is the faucet itself. It all pulls out from the center.
    Ther is a defective pin "clasp" which hold the 1 end of the sprayer hose to faucet is in need of attention.
    Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
    Thanks and Please Rate jj505
    http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
    Apr 06, 2009 | Moen Plumbing
    Plumbing Logo
    286 people viewed this question
    Top Plumbing Experts
    Paul Carew
    Tom Chichester
    Are you a Plumbing Expert? Answer questions, earn points and help others
