Question about Sharp R-1610 Microwave Oven
Power shuts off
Loose connection somewhere
  • Sharp Master
  • 9,047 Answers
Service manuals are here:
http://www.microwavedisplay.com/r1610_r1611_r1612_sm.pdf
http://www.microwavedisplay.com/r1600_r1601_r1602_sm.pdf
You can order Sharp parts from Encompass here or you can call them toll-free at 866-779-5835.
Posted on Jan 09, 2013
Microwave went totally dead while operating; there is power to the outlet.
If the control panel lights up intermittently, then you either have a loose connection somewhere near the panel, or a failing component on the circuit board itself.
Jul 10, 2015 | LG LMV1813ST Microwave Oven
My ge microwave model # jeb1095sb03 shuts off after 1-2 seconds
Hi Bruce,
i think power supply problem,maybe loose contact of jumper wires or loose connections of PCB.
go for repair center,
regards,
nuwan
Jan 12, 2014 | GE Microwave Ovens
Intermittent Power Loss
Take the unit apart and carefully inspect the wires under the keypad...short of that..junk it and get a new one. It seems they just don't make things the way tey used to.
Nov 19, 2013 | Samsung SMH9187 Microwave Oven
GE JVM1540sn1ss Microwave loses all power including interior light, control panel, etc. I have to set the clock each time. I can wiggle door or control panel and power comes back on. I appears there...
It may be a loose fuse holder or a rare condition, an intermittent fuse.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
If you need further help feel free to contact me with your full model number and symptoms.
Jul 06, 2011 | General Electric Microwave Oven
Does not matter what the setting is on,the microwave will only run for 2 min. and then shut off. It is only 5 yrs old.
Please check all the poer connections on the power side, the magnetron section. specially the capacitor. Also if there is fault on the control processor board.
This can trip off the power and reset. possible loose connection or even if the outlet power - if it is lower when the microwave starts.
Feb 18, 2011 | Magic Chef MCD1311ST Microwave Oven
Samsung smh7175wc - dead??
id say there is a bad connection somewhere and is arcing due to that which is causing it to trip breakers. so when you banged it and it started it made a connection and then stopped when you turned it on. open up the back abd just pull the wires anywhere connections are made and see if any are lose.
Jan 13, 2010 | Samsung SMH7174BC Microwave Oven
Power loss then surge GE JE 1860 Microwave
Well it does appear that you have an intermittent problem. I do not think that there is a loose ground problem, but there is a thermal switch attached to the case of the magnetron that resemble the thermal switches in wall gas heaters. Like the one in wall heaters they tell the heater when to shut off and on. If that switch begins to open or is trying to open it will make it seem like your microwave wants to shut down. Of course that is just one solution which I think is the best. By the way that thermal switch only has two wires that go to it and resembles an oversized watch battery when it is out. What could cause that also is if those two wires which are connected with plugin spade terminals have become loose due to the vibration of the magnetron over the years. To cover all your bases at once, with the power off, take the cover off and reseat all the spade connectors that you can see and get to. Anything in line with that switch or with the power coming in at all can cause the same thing. Let me know if there is any other question that you have.
Feb 09, 2009 | GE JE1860 Microwave Oven
I have just bought a NN-CS596S. I followed the unpack and startup instuctions without amy problem. It will now work consistently on microwave thogh. It works fine on grill or oven, but seems to have an...
This is usually caused by either a bad door switch, a loose door switch mount, or a misaligned door.
It may have been damaged in transit. A loose door may leak microwave energy.
I'd return it to the dealer since it's so new and under warranty.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Panasonic Microwave Ovens
Magic chef over the oven microwave shuts off.
Is not normal for a microwave to shutdown after 4 minutes of operation.
From the info you are providing, It looks like the magnetron might be overheating causing the thermal fuse to shut it down until it cools down. There may also be a loose connection in one of the switches or a cold solder joint in the low voltage power supply.
I would suggest to check and make sure that the fans are functional, If always did; it could be that there isn't much air circulation where the appliance was installed.
Mar 03, 2008 | Microwave Ovens
Sharp R-1610 Microwave Oven Logo
16 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
