Question about Kettler Exercise & Fitness
How can I enter the setup mode on Kettler Marathon HS (7899-600)
    Top Expert:
  • Kettler Master
  • 12,223 Answers
See the steps. God bless you
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Posted on Jan 07, 2013
2 Suggested Answers
anupam19
  • 263 Answers
SOURCE: The running belt on my kettler marathon tx1
Use grease and check if any lock is there
Posted on Mar 12, 2011
My kettler tx1 marathon running machine causes the electricity to swith off in the house. This occurs when I start the treadmill, not when I simply switch it on. Any idea as to the cause?
The motor or the Motor control board is faulty. Can be the motor brush or the shorted igbt transistor in the motor contol board. If you wish to get some more details about treadmill repair then check the following link.
http://electro-medical.blogspot.com/
Sep 28, 2016 | Kettler TX1 Treadmill
Problem with Kettler Marathon ST, error 01 and not starting
adjust the speed sensor, see the diagram attached, clean, and tight the wires connector very well.
2) Test the input voltage motor, if there are the motor need repair.
3) Tes the output voltage board, for input voltage motor, if there are NOT the board is faulty.l
After you did, RUN the software calibration for diagnose, troubleshooting,and fix it.
sincerely. GOD bless you
May 05, 2012 | Kettler Exercise & Fitness
The +/- speed buttons and the red stop button do not function
Sounds like the function keypad has failed or worn out from excessive use of those buttons Call Kettler's customer support
KETTLER International Inc.
P.O. Box 2747
Virginia Beach, VA 23450 USA Tel (757)427-2400 Fax (757)427-0183 Email info@kettlerusa.com or www.kettler.co.uk
Jul 17, 2010 | Kettler TX1 Treadmill with FREE INSIDE...
Treadmill won't start
If you have a multi meter I would first check the AC outlet follow the path (power cord, on/off switch, fuse holder, motor control board) to see if their is any power interruption . Also I have to ask is the safety lanyard attached to the upper console. Hope this give you some direction.
May 15, 2010 | Kettler Exercise & Fitness
Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
May 10, 2009 | Exercise & Fitness
Language setup for Mitsubishi HS-U510 VCR
I contacted Mitsubishi support. It is very likely the 510 and the 520 are similar. I was told to look at the back of the VCR (in the middle and lower) for a "timer reset" button. Pushing it will put you into initial setup mode and you can set your VCR to english menu. It works!
Ronrr
Jul 14, 2008 | Televison & Video
try holding down the power button for 8 + seconds upon first starting the vcr. the language option will again be afforded you. see the manual.
Nov 07, 2007 | Mitsubishi HS-U510 VHS VCR
Exercise & Fitness Logo
281 people viewed this question
Top Kettler Exercise & Fitness Experts
Jim London
Jim London
ray gallant
Steven's...
Steven's...
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
