Question about Adaptec 29160LP SCSI Controller
29160lp sees cd drives but not HDs
At boot 29160lp sees the cd drives but not the hdds. I checked the ribbon to the card and drives, all seems well. HD Drive activity lights blink at boot but not listed in scsi utility, only the cd drives are listed.
Thanks
    Sergeant:
  • 238 Answers
I'd suspect the termination or the cables. SCSI is notoriously particular about seeing the proper termination. I've found that I've had to use external termination to get some devices to work. Try one drive at a time to see if you can get any of the hard drives recognized. If not, try better cables or external termination.
Posted on Jan 23, 2009
Had a problem with my drive getting on internet installed new hard drive now can not boot up dont see drives
it sounds that you have problem in the mother board, you can hooked up your drive to other pc as slave just to ensure if it will read. if ok, then their is no problem in your hard drive also with other drive.
Nov 19, 2012 | Dell Dimension 5100 (D51L1) PC Desktop
Getting three beeps with my asus m4a785t-m motherboard initializi
Okay, not much else is mentioned about the system so I would assume you have one CD/DVD drive and now two HDDs and your new HDD is still set to factory default of "Cable Select" or CD, if not and the new hard drive is a replacement for a damaged OS (Operating System) drive, then you need to insert the Windows OS Installation disk prior to booting and set the system to check your CD-ROM before checking Hard disks, for the OS.
First off if IDE, you have a ribbon that resembles this [====[========[ the furthest to the right would be what plugs into you motherboard, being the one with the furthest distance between itself and the next plug/connector.The one on the other end is for the Master drive and teh middle one is for Slave.
If only one HDD, then the jumper for the new drive needs to be set to Master and the CD/DVD-ROM needs to be set to Slave.
  • If two HDDs & one CD/DVD Rom, On the primary IDE Controller, set the OS HDD to Master, the CD/DVD-Rom to Slave & put the second HDD on the secondary IDE Controller as Master.
  • If two HDDs & 2 CD/DVD-Roms they must be set up on totally different IDE controllers to cancel out the chance of cross-communication. This happens on some systems because of having two CD/DVD Roms and/or two IDEs. So, we set the OS HDD to Master on the Primary IDE Controller & we set the CD/DVD-Rom to Master on the second IDE controller and the
I would normally say that three beeps from the motherboard itself would be either graphics card or memory problems, normally solved by simply pulling either or both and reseating them. Wear Nitrile gloves (the blue ones) to keep oils and static charge from damaging the components, ground yourself &/or touch the case before and while pulling the components. Check this site for "Post Codes" if the beeps are coming from the MoBo... if you have Award BIOS (should show what BIOS brand when booting up the system)
Award BIOS Post Codes
If three beeps from the system itself, then that would say it can't find the OS... and you might possibly also find an error on the monitor, stating something similar to "no power to monitor".
If you don't have an illustration on your drive telling you what pins are for what when it comes to the jumper, then search google for the drive brand and the word "jumper" or words "jumper configuration" or "jumper placement"
example: Maxtor Jumper configuration
If the system is SATA only (I believe it to have at least one IDE controller unless the board's controllers are all blue & black, to which I see a controller, but can't tell if it is FDE or IDE), then you'll most likely have to enable the SATA controllers in BIOS and set the boot preference/sequence/order as mentioned above, to check the correct disk for the OS, after removable devices & CD-ROM. Should be that order anyway, with floppy seek disabled to save wear on the head.
Hope that was not too much and that it helps!
Apr 15, 2010 | Frigidaire FEQ1442ES Electric Dryer
Had frozen screen and removed extra hard drive and it worked for one day with the original mac hard drive then went back to frozen screen.mac g-4 mirror door desktop.
Sounds like you're having a major failure. I would remove the hdds you have now - in case they are crashing for good - buy a new hdd - format and put an operating system on it and boot the pc - put the other hdds back on as exterior hdds - get the info off of them and move on. BUT - only if - removing all ram but one stick - and all the other cards that you do not absolutely need to make the pc function - take out - take everything out but one stick of ram - the video if it is a card and the hdd - - - start from there and see how it goes - 99 times out of a hundred it will perk up. I would seriously consider backing up the old hdds and getting fresh - HDDS are cheap now.
Best of it
Mar 30, 2010 | Computers & Internet
Hard Drive Not detected/Windows still boots
Try setting the first boot device as the device with the boot sector on it.
Feb 26, 2017 | Computers & Internet
MY DVDRAM DRIVE WAS CANT WORK, THERE IS NO (E) DRIVE SHOW IN MY COMPUTER.SOME TIME CAME DRIVE (R) BUT SOME TIME CANT WORK. I CANT ABLE TO RUN MY DVDRAM. PLEASE HELP ME OUT.
sounds like the ribbon (cable) could be a controller issue, unplug the h.d.d. from controller head on mb and plug in the cd rom ribbon there boot into bios and look for the cd roms if the same problem is there replace the ribbon or you can check each one seperaely by running them off the primary ide as a slave to the hdd
also swap ribbons with the hdd and see if there is still a prob. if these do not correct the prob you have a controller issue buy a controller pci card and use it or replace the board, the card is much cheaper or the last poss. is both cd roms are bad
Dec 12, 2008 | Computers & Internet
Machine won't recognize CD-ROM after harddrive format
When booting up select whichever key gets you into the Bios. Normally either F2 or delete. Once in the Bios, find the boot up sequence and by the instructions that will be there to change the sequence change it to Floppy Drive, then CD Rom, then your hard drive with Windows on it. Press F10 to save and reboot.
Nov 19, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Where to start
Disconnect the Maxtor drive completely. Play a game or what every & see if the system runs ok. Personnally you should be running a SATA as C:\ since it will transfer much faster than an IDE. Give it a try & post you're findings.
Mike
Jul 13, 2008 | ASUS A8N-SLI Deluxe Motherboard
Stops booting - SATAII
buy a new coputer :0) Make sure all cables are secured into the harddrives and also check that the pins on the harddrives are set to master and slave. press firmly on the ram to make sure they are inserted properly sometimes they can unseat. clear your systems cmos by removing the pin and placing it from 1, 2 to 2,3 resest and place back to original 1,2 this should allow you to enter system bios. check and see if bios recognizes both harddrives if not remove one and check to make sure pins are set to master and restart.If this still does not work remove the pin entirely and retry , once again if does not work place pin on CS. If there is still a problem your cord could be bad if your cd/dvd rom is found disconnect and try that cord if this works you know your problem.
Jul 09, 2008 | Foxconn NF4UK8AA-8EKRS Motherboard
Pci ide raid card problem
Could be a PSU problem. What wattage PSU do you have?
Jan 31, 2008 | Sabrent SBT-RDIT PCI IDE Silicon Image...
You have to change it in the bios, press F2 or DEL on startup depending on your bios type. The bios screen then will have second line of advanced bios settings, in here you need to select the cdrom as the first boot device, by using the up down arrows or pageup/down or '+or-' keys. Press ESC when cdrom selected and save settings when propmted. The system will re boot so ensure the cd is in the drive and press enter when prompted to start with cdrom.
Jan 29, 2007 | IBM NetVista A40 PC Desktop
Adaptec 29160LP SCSI Controller Logo
106 people viewed this question
Top Adaptec Computers & Internet Experts
Rommel Balcita
Martin Murray
Robert Graf
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
