Question about Music
Crate PS-115HP manual - Music
Need a manual for crate px-600dlx
Try Googling (crate)(px-600dlx)(manual) without parens.
Jan 13, 2018 | Crate Music
I have a crate vtx200s has very little volume everything else works whats the deal?
Hi, you hadnt mentioned how long you've had the amp, or how new it is, so I'm going to assume it's new to you. The Crate VTX200 has 3 channels, each with its own volume level. Let's check the simple things first:
1. Check to make sure you're adjusting the same volume knob volume knob to the same channel. The active channel will be lit with a green light.
2. Check the cables from the "Speaker Out" jacks on the amp (if you are using them). Are they plugged in all the way, or are they damaged?
3. Are you playing through a preset that you may have accidentally made "low", and may not be aware of or are stuck in it?
If none of these answers helps, there might be a problem with the input buffer in the circuit or possibly within the damping circuit of the speakers. I'd advise having the amp serviced to confirm an internal electrical problem also. If you don't have a manual for the amp, one can be found here:
http://www.manualguru.com/crate-amplifiers/vtx200/users-manual
Jan 22, 2016 | Crate Music
PS 1`2H HORN DRIVER ?
is this a loud tech speaker or SLM speaker?
Jun 11, 2014 | Crate Music
Where is the serial number on a crate amplifier
Real basic owners manual is here:
http://www.crateamps.com/pdf/manuals/CA6110DG_OM.pdf
Look at the chassis, or pull a part number off the original speaker to match speaker and back cross reference to the amp versions that used it. The OM is at least good enough with the block diagram to allow it to be serviced easily enough.
Feb 21, 2012 | Crate CA6110DG Gunnison Acoustic Guitar...
Three button crate footswitch wires need to be refastened. I need a wiring diagram.
My mate's crate uses two stereo jack leads similar to 6.35mm guitar leads but stereo. You can buy them anywhere.
Sep 16, 2011 | Crate Cfs3
I need an owner's manual for the crate cfs3 3 button footswitch
I could not find a manual for the footswitch... USUALLY the details are covered in the amp manual it is connected to... and the only issue is if the particular footswitch is compatible with a particular amp.
Sep 02, 2010 | Crate Cfs3
Amps broken need to fix it
Their may be a schematic on the inside of the amp.I don't remember if Crate puts one or not. And I have had several Crate amps. never needed repair except for tube replacement. If there is not one in side , go here and find what you need . http://www.crateamps.com/support/warranty/ Good luck DFD please rate me TK U
Apr 18, 2009 | Crate Music
Looking for a circuit board manual or diagram for a crate mx120r guitar amp
You can try Loud Technologies @ 866-858-5832, techmail@loudtechinc.com.
They hooked me up with parts and schematic for my Crate G212XL.
Apr 18, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Music Logo
201 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
