On its last rinse and spin x - Washing Machines
    Genius:
  • Washing Mach... Master
  • 1,669 Answers
Linda, the wash in the unit is out of balance in the last spin. If you want it not to do the Hula, open the door just before it starts to spin.Don't worry, the drum will slow down and stop and you should, at that time distribute the wet clothes around the drum as much as possible so as not to have a bundle in one place.
Posted on Jan 07, 2013
My Fisher Paykel washing machine won't spin it's goes to rinse then stops. The wash light and the last rinse light comes on also spin light comes on and it's beeping
Fisher & Paykel technician in your area
Contact
Http://www.fisherpaykel.com/au/support/service-appliances#
request-a-service
Customer Care - Online Locator
Feb 18, 2016 | Fisher Washing Machines
The Tub Clean function never ends
why do you use tub clean function, we have never had the need to reclean the tub having just run hot detergent and water thru it .
Oct 04, 2015 | LG WM Washing Machines
Why does not agitate on rinse cycle
It shouldn't agitate on rinse cycle. ''Quick wash'' is the last type of ''cycle'' you can select that the machine will ''agitate.'' On ''rinse'' cycle, it will fill with water and then simply drain & spin.
May 18, 2015 | Washing Machines
After rinse cycle won't washer won't spin
Sound like it could be a lid safety switch.
May 24, 2014 | Kenmore 22422 Top Load Washer
Machine will not spin on final rinse
Generally, the final rinse is a bit longer than the others, and may last about a minute. It is not so healthy for clothes to keep it inside the unit till last rinse. I suggest turn off the rinse after 1 or 2 or a maximum 3. Now to your problem. It seems like a problem of your board which fails to cut off supply at high speed. The final rinse will stop but it will take many times longer than normal. You can repair the board and it will be moderately expensive. If the model is an old one, it will be very difficult to get its spare parts.
Jul 05, 2010 | Washing Machines
Will not drain the last 2 minutes and spin
Clean out filter, Check drain hose at sink, Could also be small coin partly turning within drain hose,, Good luck
Oct 04, 2009 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
MACHINE DOESN'T CYCLE OUT OF RINSE
Does it spin if you move the timer manually? ist it being used on a delicate cycle@? if so it will stop in the last rinse water
Jul 10, 2007 | Ariston Technologies AWD 121
Machine will not empty or rinse
Put off the machine. After 3 or 4 minutes put the control to "spin only" & put the machine on. If this does not work you hv a drain problem which shd be checked......
Aug 27, 2006 | Zanussi F1045W Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
