Question about Cretors Kitchen Appliances - Others
Shaft is loose and losing popping oil
Would like to find part and instructions on how to remove and replace it.
    Champion:
  • 252 Answers
Need to know the exact model and serial number of your cretors popper to find the correct documents.
Posted on Feb 18, 2013
I have no revers, sometimes very very little 1999 saturn sl
Check the line pressures, and if low, suspect a worn bore on the pressure regulator. Check for a loose nut on the main shaft. Air check the 2nd oil passage, and if losing pressure, remove the side cover and check for a loose main shaft nut. If a loose nut on the mainshaft is not the problem, Your going to need to pull the transmission and have it rebuilt.
Aug 14, 2012 | 1999 Saturn SL
Mitsubishi legnum/galant vr4 1996 front drivers drive shaft removal
when you pop the axel out of trans you could possibly lose a little fluid but not a whole lot you will lose less if the vehicle is only raised on the side you are removing i would also check the hub bearing
Mar 30, 2012 | Mitsubishi Galant Cars & Trucks
Replacing drive shaft on drivers side
must take tire off then bottem of shock lose big nut center of wheel axle will pull out of back side then pop loose from trany with small pry bar not to hard hopes this helps!
Jan 29, 2011 | 1998 Ford Escort
How do you remove a pulley from a spindle unit to replace the bolts holding it to the deck.
First remove the nut on top of the pulley using a 1 1/16 in. wrench or socket. Then you will need to pry the pulley of the shaft using two pry bars. A bit of force may be required. It will kind of pop off when it does finally break loose. Be careful not to lose the half moon key that will still be in the slot on the shaft.
Aug 18, 2010 | King Kutter Pull Type Rotary Kutter 72in....
Oil loss when removing drive shaft seal 55 plate fiesta zetec
You may lose a little, nothing major. Add in the transmission filler tube, where the dipstick goes.
Mar 13, 2010 | 2005 Ford Focus
How do i remove the water pump on a 1999 suzuki rm 250
hi,drop the oil, remove the right hand casing. undo the water pump casing. remove the impeller (10mm bolt) dont lose the copper/ally washer. draw the drive shaft from the inside of the casing. remove the bearing. remove the seals, keep note which way round the seals are. they should be opposite. one keeps oil in and the other keeps the water out of the oil. if there are any score marks on the drive shaft,replace it , as it will only leak again. to put it back together, just reverse process. hope this helps. kev.
Mar 08, 2010 | 2005 Suzuki RM 250
Change transmission instructions
this is for rear wheel drive only front wheel drives require removing axle shat and dropping tie rod end and lower ball joint to get tranny out. If you start this I will give tork setting when I know what you have as it is a lot of work to type this out.
First disconnect the battery, inside the cab pull shifter boot off and remove snap ring to remove shifter, next get a block to go under engine remove drive line bolts and be sure E-brake is set and block the wheels, next put bolts from driveline into the read differential in order so you will be able to find them next disconnect the two starter bolts from the starter and tie starter up as not to allow the starter weight to hang on the wires. Remove two bolts holding slave cylinder on let hang off the side do not lose the shaft out of slave. Next remove the transmission mount bolt out next pull four bolts out of transmission cross member, next remove 5 bolts out of bell housing now get a baggie and a couple of rubber bands and pull drive shaft slide baggie over the transmission tail shaft and put on rubber band on bag to keep from losing fluid move drive shaft out of the way. Next disconnect the Speedo cable and wiring harness the reverse switch is at the top so will have to drop the tranny down to keep from breaking wire. Once you have a gap between the transmission and engine put block under back of engine slide the transmission out let the front drop down then lift up on rear of transmission and slide the cross member out of the way. Next slide tranny out of the way next remove the 6 bolts on the clutch assembly turning each bolt 1 and a ½ turns each till clutch is loose remove the clutch pressure plate and the throw out bearing, remove flywheel take to machine shop and have surfaced, replace the clutch plate pressure plate and the throw out bearing reinstall in reverse if you see any oil leaks replace seals, also replace rear transmission seal now if you don’t it will leak next after it is back together be sure you put new fluid in the transmission and bleed the slave cylinder.
Jun 28, 2009 | Nissan Pickup Cars & Trucks
Cutter is stuck onto shaft, how can I remove it?
First, check to see if there is a set screw in the side of the cutter which screws against the shaft.
If no set screw, a gear puller would probably do the trick. There are many types -- you might luck out and find one which will fit on your first shopping trip.
Apr 29, 2009 | Champion 2000+ Household Juice Extractor
Kitchen Appliances - Others Logo
350 people viewed this question
Top Cretors Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Cretors Kitchen Appliances - Other Expert? Answer questions, earn points and help others
