Question about BenQ PB6100 Multimedia Projector
Projector says out of range
Its set to rbg1 its not the cable, blue screen, but no desktop, Projector: NEC LT260, labtop : Dell Lattitude; i am wondering if the computer is too outdated to work with the projector. it doesn't even recognise it when i say search for recently connected devices.
  • Anonymous Mar 19, 2014
    NEC VT470 projector has dark shadow on half the screen
    Problem Solver:
  • 13 Answers
The native resolution on the 6100 is 800x600. I have had it recognize 640x480 and 1024x768 though. Check your computer to make sure the resolution is 800x600. Also set the refresh rate at 60htz, if the refresh is too high it can give out of range errors.
Posted on Jan 28, 2009
Vertical hazy lines are all that can be seen on my LT260 (nec)
make sure the lcd cables are secure in the main board. if that doesn't fix it the polarizers may be burnt.
May 11, 2010 | InFocus Proxima DP6155 Multimedia...
NEC VT460 issue with RGB input saying out of range. Using cable between laptop and projector
Dear please set the resolution of your PC or Laptop ,so that it can give O/P at same resolution as projector. For issue regarding resolution supported by Projector go through manual of Projector.
regards,
rakesh Kumar
Network Support Engineer
Nov 12, 2008 | NEC VT47 Multimedia Projector
Security code for Nec lt260 multimedia projector
The menu and logo password are the only ones you can reset by yourself, if you lose your master password you must contact NEC to get the release code.
See page 113 on the manual :
NOTE: Do not forget your keyword. However, if you forget your keyword, NEC or your dealer will provide you with your Release Code.
After you call NEC and get the code do the following:
1. Press and hold the POWER button for a minimum of two seconds.
The projector will be turned on and display a message to the effect that
the projector is security-protected.
2. Select [Projector Options] → [Security] from the menu and press hte ENTER
button.
The Release Code input screen will be displayed as well as your Request
Code (24 alphanumeric characters).
3. Enter your Release Code in the Release Code Input screen.
The projector will turn on.
* If the projector is turned on by entering the Release Code, your Security
will be disabled.
find contact page from here or call the retailer:
NEC Global
Here is also the remote
Sep 10, 2008 | NEC LT 260K Multimedia Projector
button.
will be disabled.
NEC Global
Sep 10, 2008 | NEC LT20 Multimedia Projector
Security code for nec lt 260
The procedure is the same for LT220, LT240 and LT260.
Here is the user manual
LT260/LT240/LT220 User’s Manual
Sep 09, 2008 | NEC LT 260K Multimedia Projector
Lt260 projecto
From user manual :
"In case you forget your passcode, follow the steps below to delete it.
1. Select the Advanced menu from the Basic/Custom menu. The Passcode
entry screen will be displayed.
2. Press the SELECT (up) button four times and then press the ENTER
button.
The "Warning Passcode!!" message will be displayed.
3. Press the SELECT (down) button four times and then press the ENTER
button.
4. Press the SELECT (right) button four times and then press the ENTER
button.
The "Delete Passcode / Are you sure?" message will be displayed.
Use the SELECT or button to select "Yes" and press the ENTER
button. Your passcode has been deleted."
Aug 05, 2008 | NEC LT 260K Multimedia Projector
Nec lt260
Clean optocoupler under pcb 4554B on color disc wheel.
Dusty on this part make not good sincronice with dlp panel.Good luck.
Jun 28, 2008 | NEC LT 260K Multimedia Projector
NEC LT260 PROJECTOR NOISE
To open this projector, you need to undo six screws at the underside of the case. That means you have to turn the projector upsidedown.
Pls note that one of these scews is a little hidden under the carrying handle.
After removing the screws, return the projector to it's normal 'up-side' up, standing position.
Remove the bulb cover srews and remove the bulb cover.
Lift up the top cover carefully starting from the front then all together.
The cooling fan is mounted very near the bulb assembly.
Carefully check the fan blades for any obtacles, wires or even a broken fan blade, that could be causing the noise.
Baba Anji.
Dec 18, 2007 | NEC LT 260K Multimedia Projector
VT45 Projector: Blue pixels throughout screen
If the problem is what I describe as a blue haze over the entire image projected, I was told this is a defect in the cable - we have a Dell Video Projector 2300 - and it takes only a dell VGA cable.
So, the problem is in the cable - solution is replace cable.
Feb 28, 2007 | NEC VT45LPK Projector Lamp for VT45
BenQ PB6100 Multimedia Projector Logo
5,420 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
