Indesit wd12x. Handle loose. Door won't open. Have drained. Have run a second cycle. Can't unlock by going into top of machine and playing with the door lock internally. Any advice?
SOURCE: The door on my indesit
slide in a piece of string around the door. if lock is on the right, pull round the door til the pieces of string are at left of the door and pull left quite firmly.
Posted on Mar 10, 2009
  • 1294 Answers
SOURCE: washing machine door locked indesit WD12X
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Posted on Apr 02, 2009
  • 92 Answers
SOURCE: Suspect door handle is broken on Indesit Washer Dryer WD12x
yes u can open door from the inside,take the top off (take plug out first)put your arm down to near the door latch and you will feel the mechinism there just gently push down or up until the door opens,if water is still in the washer then take drain pipe out of the waste pipe and place a bucket on the floor then put the pipe in that to manualy drain it,hope this helps you,ps you can buy a new door handle from any washing repair shop and they are easy to replace just see how the old one comes off,rgrds,paul
Posted on Jul 07, 2009
  • 24 Answers
SOURCE: Washing Machine Door is jammed (Indesit WD12x): I
UNPLUG IT
Posted on Oct 13, 2009
  • 353 Answers
SOURCE: i have a 2 year old indesit wd12x been fine
could be the catch has broken you may have to force it open and new complete door is about £25.00
Posted on Mar 02, 2010
Indesit washing machine wie167 the word door came flashing up, the cycle has stuck and the door wont open
Ok the machine needs to be drained. Then switch the machine on again. The door should open.
Oct 06, 2012 | Indesit Door Handle Kit for W123, W133,...
My Indesit WIL163 is stuck washing - won't go on
I suspect that the logic board has developed a fault and probably needs replacing. 'Phone your Indesit Service Centre and get an engineer out. I believe a replacement board costs about £100 fitted, but a 12-month service plan paid monthly may be a bit cheaper, and will cover further breakdowns. Unfortunately, these boards are not the most robust or reliable examples of technology.
Turn off the power to the machine; preferably unplug it.
If you can open the door(?), bale out the drum by hand. I don't think there's a pump/filter access panel on this machine, so it's not easy to get the water out. You could try
disconnecting the discharge hose from the pipework, then lower the open end over a washing-up bowl so that the water drains from the drum by gravity. It depends how close to the floor you can get the open end. When enough water has drained, it should be possible to open the door to remove the laundry. Sorry, this may take a while.
Hope this has helped.
Jan 11, 2018 | Washing Machines
Bosch Nexxt 300 has error code E-13 and the door is locked. turned on/off, unplugged, removed the drain hose to see if it is blocked, but ok. but still won't unlock. Is there someway to unlock the...
Turn the dial to off position wait few second, door should unlock. Unless you try to open it during cycle, it won't open. Otherwise, follow owner manual. call the manufacture.
May 18, 2011 | Bosch Washing Machines
I have a 2 year old indesit wd12x been fine
Mar 01, 2010 | Washing Machines
Door will not open on creda ied12, finished cycle looks like the handle is loose
Needs a new door handle kit which is the easy part.
the hardest part is getting the door unlocked, play with the handle to unlock it, or take the top off and try unclip the catch from the interlock .
You may have to break the door plastic, don't break the interlock though and buy a new door
Sep 19, 2009 | Washing Machines
Jul 07, 2009 | Indesit W 123 Front Load Washer
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Washing machine door locked indesit WD12X
Apr 01, 2009 | Washing Machines
The door on my indesit wd12x washer dryer will not open. The machine has finished the cycle and was on the tumble dry mode when it finished. The handle feels loose like a spring has sprung. Any...
Oct 17, 2008 | Washing Machines
Washing Machines Logo
718 people viewed this question
Top Washing Machines Experts
