Question about AEM 2002 Chevy Silverado - 2500HD, 6.0L V8 - Brute Force Air Intakes
Cant find torque specs for oil cooler to oil pan mount bolts on 02 Silverado 2500HD 6.0 vortec
98 jeep wrangler tj 4.0 oil pan bolt pattern or layout. An torch specs
Bobby, oil pan bolt torques for 4.0 Wrangler. Oil Pan Bolts 1/4 84 in-lbs Oil Pan Bolts 5/16 132 in-lbs As far as sequence, see last link, start in center, criss cross pattern tighten snug all, then repeat to torque spec.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Oil Pan Gasket leaking
http://jeephorizons.com/tech/99_40l_torque_specs.html
98 jeep 4 0 oil pan bolt torque sequence specs Google Search
May 21, 2016 | Jeep Cars & Trucks
How to remove oil pan
4x4
1. Open the hood.
2. Disconnect the battery negative cables.
3. Remove the intake air assembly.
4. Remove the radiator shroud retaining bolts.
5. Install engine support fixture # 8534B .
6. Raise and support the vehicle.
WARNING: HOT OIL CAN CAUSE PERSONAL INJURY.
7. Drain the engine oil (Refer to 09 - Engine/Lubrication/OIL - Standard Procedure) .
8. Loosen the front engine mount bolts.
9. Lower the vehicle.
10. Use the engine support fixture # 8534B to raise engine out of the front mounts.
11. Remove the engine oil dipstick.
12. Raise and support the vehicle.
13. Remove oil pan bolts, break the pan to block seal, and lower pan slightly and remove oil suction tube fasteners.
14. Remove oil pan and suction tube.
15. Remove the 2 bolts from the front of the engine block stiffener.
16. Remove the oil pan.
4x2
1. Open the hood.
2. Remove the negative battery cables.
3. Raise and support the vehicle.
4. Remove the transmission oil cooler lines.
5. Remove the propeller shaft.
6. Remove the starter bolts.
7. Support the starter.
8. Remove the torque converter bolts.
9. Remove the exhaust hanger bolts.
10. Remove the gear shift cable.
11. Remove the wiring harness.
12. Remove the transmission mount.
13. Remove the crossover bolts.
14. Position the transmission jack.
15. Remove the bell housing bolts.
16. Remove the transmission.
17. Remove the flywheel housing bolts (8).
18. Remove the flex plate bolts (8).
19. Remove the engine oil dip stick.
20. Drain the oil.
21. Remove the steering rack bolts.
22. Remove the oil pan bolts.
23. Remove the oil pickup bolts.
Aug 01, 2014 | Dodge Ram 3500 Cars & Trucks
Cant get the oil pan off a 302
You have to jack the engine up after removing the motor mount bolts on each side. Then once you have the engine jacked up a few inches, slide a piece of wood (2x4) in between the upper and lower parts of the motor mounts on each side. This will keep the engine elevated enough for you to drop the oil pan and replace the gasket. Then, just put all the bolts back in in the proper torque sequence, torque them all to spec,remove the wooden blocks from the motor mounts, slowly lower the engine back down and put the motor mount bolts back in.
Mar 16, 2011 | 1993 Ford F150 SuperCab
Recently "slow" rolled my 2003 2500HD just got the
I agree with the oil pump. Drop the pan and replace it. Just because you had a slow roll that would not effect oil pressure. Make sure you torque the pan to specs, very inportant.
Jan 28, 2011 | 2005 Chevrolet Silverado
I need to know he torque spects for the oil filter container the bolts on to the moter on a 94 BMW 318i...there are 6 bolts...I also need to know the torque spects on the alternator mounting bracket...
OIL PAN OR TRANSMISSION PAN BOLTS TORQUE ABOUT 7 FT LBS. CAN GET SPECS ON BOLTS SIZES. IF BOLTS SIZES IS 13M I4M 15 M TORQUE BOLTS ABOUT 55 TO 80 FT LBS
Nov 11, 2010 | 1994 BMW 3 Series
Torque Specs for Head Bolts on 1997 GMC Sierra V8 5.0 Vortec?
.0L Torque Specs Belhousing to engine bolts 28-38 ft/lbs Camshaft sprocket bolt 40-45 ft/lbs Camshaft thrust plate to engine block bolts 108-144 in/lbs Crankshaft pulley to vibration damper bolts 35-50 ft/lbs Cylinder head bolts -1979-1992 --Step 1 55-65 ft/lbs --Step 2 65-72 ft/lbs -1993-up --Step 1 25-35 ft/lbs --Step 2 45-55 ft/lbs --Step 3 75-85 ft/lbs Differential shaft lock bolt 15-30 ft/lbs Driveshaft U-joint to pinion flange bolts 70-95 ft/lbs Exhaust manifold bolts 26-32 ft/lbs Flywheel mounting bolts 75-85 ft/lbs Front engine mount nuts 72-98 ft/lbs Intake manifold to head bolts --Step 1 96 in/lbs --Step 2 16ft/lbs --Step 3 23-25 ft/lbs Intake manifold (upper intake to lower) 12-18 ft/lbs Oil filter insert to engine block adapter bolt 20-30 ft/lbs Oil pan mounting bolts -1979 --Step 1 (Large bolts) 11-13 ft/lbs --Step 1 (Short bolts) 7-9 ft/lbs --Step 2 (Large Bolts) 15-17 ft/lbs --Step 2 (Short Bolts) 10-12 ft/lbs -1980 to 1987 9-11 ft/lbs -1988 to 1993 6-9 ft/lbs -1994-up 110-144 in/lbs Oil pickup tube to main bearing cap nut 22-32 ft/lbs Oil pickup tube to oil pump bolts -1979 to 1987 10-15 ft/lbs -1988-up 12-18 ft/lbs Oil pump mounting bolts 22-32 ft/lbs Pinion bearing preload 8-14 in/lbs Pressure plate to flywheel bolts 12-24 ft/lbs Rocker arm fulcrm bolts 18-25 ft/lbs Spark plugs 7-14 ft/lbs Timing chain cover bolts 12-18 ft/lbs Vibration damper to crackshaft bolt 110-130 ft/lbs Wheel lug nuts 85-105 ft/lbs
Mar 16, 2010 | Chevrolet C1500 Cars & Trucks
How to remove oil pan on kia sportage 99? thanks,Zak.
Hi Zak:
Kia Sportage 1998-02 Repair Guide
Oil Pan - Removal & Installation
  1. Before servicing the vehicle, refer to the precautions at the beginning of this section.
  2. Drain the engine oil.
  3. Remove or disconnect the following:
    Negative battery cable 2 Top intake manifold bracket bolts Front 3 axle housing mounting bolts, 4WD only Left front bushing from the axle housing mount and lower the front axle housing Both gusset plates from the engine Transmission under cover Engine under cover Oil pan mounting bolts and using a scrapper tool separate the oil pan Oil pan Oil strainer assembly Oil baffle 76b1888.jpg
  4. Fig. Exploded view of the oil pan assembly mounting
To install:
Fig. Tighten the oil pan bolts in sequence
  1. Clean the engine block, oil pan and baffle pan surfaces of any gasket material.
  2. Apply a continuous bead of Loctite Ultra Blue 587® silicone sealant around the baffle pan.
  3. Install or connect the following:
    Oil baffle. Torque the bolt to 84 inch lbs. (9.5 Nm). Oil strainer. Torque the bolts to 84 inch lbs. (9.5 Nm).
  4. Apply a continuous bead of Loctite Ultra Blue 587® silicone sealant around the oil pan.
    Oil pan. Torque the bolts to 84 inch lbs. (9.5 Nm). Transmission under cover. Torque the bolts to 84 inch lbs. (9.5 Nm). Gusset plates to the engine. Torque the bolts to 33 ft. lbs. (45 Nm). Engine under cover Front axle housing into position. When properly aligned, torque the bolts to 48 ft. lbs. (65 Nm). Intake manifold bracket bolts. Torque the bolts to 34 ft. lbs. (65 Nm). Negative battery cable
  5. Fill the engine with clean oil.
  6. Start the vehicle and check for leaks, repair if necessary.
Hope helps with this (remember rated this) Good luck.
Jan 12, 2010 | 1999 Kia Sportage
2001 Silverado oil pan gasket is it hard to change?
it can be you must remove oil filterand housing along with oil cooler lines lower trans lines you really need a repair manual for this kind of repair for torque specs and procedures
Jul 10, 2009 | 2001 Chevrolet Silverado 2500HD
Front Hub Bearing Torque specs to complete replacement
THE LUG NUT TORQUE SPEC - 140FT/LBS\
CALIPER MOUNT - 80FT/LBS
CALIPER BRACKET 129FT/LBS
AXLE NUT 177FT/LBS
Apr 24, 2009 | 2003 Chevrolet Silverado 1500
AEM 2002 Chevy Silverado - 2500HD, 6.0L V8 - Brute Force Air Intakes Logo
37 people viewed this question
Top AEM Tools & Hardware - Others Experts
Lawrence Oravetz
terry stevens
Are you an AEM Tool and Hardware - Other Expert? Answer questions, earn points and help others
