Question about Whirlpool Dryers
Whirlpool AWZ2303 (857523015031)
Drum moves up and down and a grinding noise
  • 186 Answers
SOURCE: When turned on, the drum makes a grinding noise as
The main bearing may be worn out at the back of the drum allowing the drum to wobble.Reach inside the drum and lift upward. If you can move it up and down this is probably the problem.
Posted on Nov 05, 2009
  • 69 Answers
SOURCE: my whirlpool cabrio electric dryer makes grinding noise
could be a bearing gone
Posted on Mar 27, 2010
  • 7 Answers
SOURCE: I have a whirlpool duet dryer gew9250, still dries
The belt or roller bearings are two parts that commonly wear out.
Posted on Sep 02, 2010
heatman101
  • 43501 Answers
SOURCE: Recently moved and now I am getting a very loud,
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Jan 12, 2011
heatman101
  • 43501 Answers
SOURCE: Our ggw9250pw3 Whirlpool Dryer has
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Mar 20, 2011
My whirlpool electric dryer makes a loud grinding noise
Is there anything caught between the dryer drum and any housing. Can you hear it when the drum is turned by hand.
Jan 26, 2014 | Whirlpool Dryers
LG direct drive washer makes a grinding noise with power and moving it by hand. how much to repair?
sounds like the bearings have worn out. probably expensive, requires the machine to be dismantled almost completely.
Nov 12, 2013 | LG Washing Machines
Machine is making clanking and grinding noise during wash cycle drum does not appear to be turning. does not make this noise if ran without items in wash and drum turns with no items in the wash
You may have a problem with bearing. Place your hand inside the drum and see if you can move it up and down. If the drum can be moved up and down, you have a severe bearing problem that will require a technician to tear down the unit and replace the bearing and drum assembly. It's a very expensive job.
Good luck
Jun 16, 2011 | LG WM0642H Front Load
Recently moved and now I am getting a very loud, almost grinding noise when drum is turning.
heatman101
Jan 12, 2011 | Whirlpool WED5200T Electric Dryer
Nov 05, 2009 | Whirlpool LER4634J Electric Dryer
At the end of the spin cycle, my Kenmore Washing Machine makes a grinding noise like an out of balance brake drum. What could be the problem
If your washer model number starts with 110. it's a whirlpool washer. Whirlpool use a spin tube with two notches in it. There is a block assembly that holds the inner basket down on to the spin tube. This can be accessed by removing the top of the agitator and take out the 7/16 screw. Lift the agitator to expose the top of the spin tube. The tube is stripped on top where the basket sits. When the washer stops spinning, the inner basket keeps moving. That is the noise you hear. Replace the spin tube and possibly the block.
Oct 03, 2009 | Washing Machines
Washer is loud, and won't spin or agitate
check the motor bushes,and also check for bearings in drum you can check this by lifting the inner drum up and down if you feel a knocking noise then this will be the bearings have worn.
Jul 13, 2009 | Frigidaire ATF6000ES Front Load Washer
When turning, loud grinding noise.
Can be a tensioner pulley with bad bearings or the rear drum bearing is shot. When the rear drum bearing goes bad, the drum drops slightly and starts rubbing and making all sorts of terrible noises. I would not run it like this as the pivot on the rear of the drum that rides in the bearing could be cutting into the support. Not a good thing.
Good Luck and hope this helps.
Mar 15, 2009 | Whirlpool LER4634J Electric Dryer
Washer make grinding noise
Hi, Unfortunately this sounds like the drum bearings have failed. Does the drum move around when you try to lift it up and down? Were there greasy spots on your white clothes lately? Any metallic debris in the removable filter? These all point to drum bearing failure.
If these suggestions do help you solve the problem, please give my reply a rating to help others judge my knowledge / guessing skills. If they do not, please delay the rating and add a comment
with more details so I can try to help you further. Cheers, D
Jul 10, 2008 | Whirlpool Washing Machines
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
