Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Menu problems My tv set keeps switching to the menu after turning it on. Each time you exit the menu it switches back to the menu.
  • 1 more comment
  • Dereck Williams Jun 30, 2007
    It is not the remote. I use the remote to change the menu back to the normal station and it keeps coming back to the menu.
  • Anonymous Feb 05, 2009
    We take the menu option off and it comes back on by itself. Help.
  • Anonymous Feb 20, 2009
    the menu screen keeps poping up evey time you exit, won't get off the menu screen. There is no remote so i'm not sitting on the remote
An incredibly simple fix after a month of frustration. Get a blank USB flash drive. Go to Philips web-site. Go to your model #. Look at problems and you'll see the menu problem. You need new software. Follow directions and download software on to flash drive. Plug in to set and watch it load up. Instant fix. I'm a very non-geek and the whole process took <15 minutes.
Posted on Mar 01, 2009
  • PeaceNJoy Aug 04, 2011
    Ditto. I just did the software upgrade and it was simple and it fixed my problem of the TV reverting to the Menu. Go to philips.com and type in the model number of your TV. Click on the Firmware Upgrade Software link and download the autorun.upg file to a USB drive. Instructions on upgrading your TV software can be found here:http://www.p4c.philips.com/files/3/37pf9...
Upgrade the firmware from philips website
Posted on Jul 08, 2007
  • 48 Answers
OK this is going to sound stupid but do you know where the remote is. I had this happen once and found the remote under a book that was leaning on the channel button. Turn the set on and it would just keep flipping between channels. Anyway to first see if it is the remote causing this take the batteries out of the remote and see if this cures the menu pop up problem. If it persists then it is possinble that the menu button that is located on the TV it's self is stuck in, gently tap on it or pull on it to see if this is the case. If the proble still ppersists then it may be another remote causing interference or the menu button on the TV is broke.
Posted on Jun 30, 2007
Menu segreto hannspree hsg1113
http://translate.google.com
Secret service menu Hannspree HSG1113
https://electronicshelponline.blogspot.com/2015/03/hannspree-lcd-tv-how-to-enter-service.html
Possible menu - Quoting from link above:
SERVICE MODE [Hanspree AT06 42" LCD TV] (Horizontal Frequency 31.5KHz to 48KHz)
* In the TV mode, adjust volume to Zero and press number keys 9 > 8 > 7 > 6 to enter service mode.
* To exit, press the EXIT button on the remote control.
SERVICE MODE (Hanhspree GT02 32E - GT03-37E1)
1 Switch on the LCD TV .
2 Press 9-9-1 on the remote control to enter the internal Service menu.
3 Press MENU to switch the service mode pages.
4 Press ?? to scroll through the various menu options.
5 Press ?? to change the menu settings.
6 Press MENUto save the new settings and switch to next page and press EXITto exit from service mode to normal mode.
TV / AV / S-VIDEO / WHITE BALANCE / BRIGHTNESS & CONTRAST ADJUSTMENTS
WHITE BALANCE ADJUSTMENT
1 Press 991 on the remote control to enter the internal Service menu.
2 Press MENU to switch to the PW106 Scaler Menu page
3 Press ?? to scroll to Page 2-3 options
4 Press ??
to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings.
5 Press EXIT to save the new settings and exit. [Don't adjust others setting in page 2-3]
Click on the Pictures to Zoom In
BRIGHTNESS ADJUSTMENT
1 Repeat the above mentioned step 1 to 2
2 Press ?? to scroll to PW106 FE VDC Menu Page 2-1 options
3 Press ?? adjust the Brightness setting.
4 Press ?? to scroll to TV/AV/S Parameter=AV1 setting and pressuto run the setting. (This procedure will copy the settings of AV1 to S & TV)
ATSC DTV WHITE BALANCE / BRIGHTNESS / CONTRAST ADJUSTMENT
2 Press ?? to scroll to PW106 Scaler Menu Page 2-3 options
3 Press ?,? to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings
4 Press to save the new settings and exit. [Don't adjust others settings in page 2-3]
YCbCr & YpbPr of COMPONENT 1, 2 WHITE BALANCE/BRIGHTNESS/CONTRAST ADJUSTMENT
Getting COMPONENT-1 connect to 1080i signal. (The settings could not be saved if signals input from COMPONENT 2 or connect to other sources such as 720P, 480P, 480i,etc.
WHITE BALANCE ADJUSTMENT OF Component
1] Repeat the above mentioned step 1 to 2
2] Press ?? to scroll to PE106 FE ADC page 2-3 options
3] Press ?? to adjust the Offset Red and Off Blue settings.
4] Press ??to adjust the Offset Green setting.
5] Press ?? to adjust the Gain Green setting.
6] Press ?? to scroll to 480i/480P/720P Parameter=1080i setting and press ? to run the setting. (This procedure will copy the setting of 1080i to 480i/480P/720P)
7] Press EXIT to save the new settings and exit.
WHITE BALANCE ADJUSTMENT OF PC INPUT
1.Connecting to VGA Timing mode
2.Under service mode, Press ?? to scroll to PE106 FE ADC page 2-2 options
3.Press ?? to adjust the Offset Red, Offset Green and Off Blue settings.
4.Press ??
to adjust the Gain Red and Gain Blue settings.
5.Press EXIT to save the new settings and exit.
May 14, 2018 | Hannspree Televison & Video
Sanyotv com
Sanyo TV Service Menu Method 1
1.Unplug the power cable.
2.Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
3.Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
4.Use the {CH+} {CH-} buttons to select menus.
5.Use the {VOL+} {VOL -} buttons to change settings.
6.Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
7.Press the {MENU} button or turn the TV off to exit.
Sanyo TV Service Menu Method 2
2.Press and hold the {VOL -} button on the TV while plugging the power cable back into the outlet.
3.Keep pressing the {VOL -} button until the TV powers on with the Service Menu displayed.
Sanyo Projector Service Menu Method 1
Factory Menu Access
1.Press and hold the {SELECT} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Factory Menu will be displayed.
Service Menu Access
1.Press and hold the {MENU} and {INPUT} buttons on the Projector at the same time for about 10 seconds.
2.The Service Menu will be displayed.
Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
To exit, turn the Projector Off.
Sanyo Projector Service Menu Method 2
1.Press & hold the {MENU} button on the Projector for about 10 seconds.
3.Use the {UP} {DOWN} {LEFT} {RIGHT} buttons to move through menus and change values.
4.To exit, turn the Projector Off.
Jul 20, 2013 | Televison & Video
TV stuck on setup menu, no remote
Its possible if side menu does not stop it that button (switch under it) is bad.
About the only remote chance you have is to remove set and a box from power and after several minutes power them back.
Dec 17, 2012 | Televison & Video
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Jul 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
How do i access factopry settings on starview box,
Right..press menu then 0000 to enter factory settings...scan then go back to menu..press 1570 another menu will appear..make sure your emu key is on (at the bottom)..then enter nagravision..and enter codes..you will see you can enter letters by useing the coloured buttons on your remote (just look at the screen to see what I mean) ...and then when codes are installed just exit back to tv (just keep pressing the back button until you get back to tv..) and you should be up and running....if you have any problems let me know..and I will do my best to help.
Good luck
Gord
Apr 15, 2009 | StarTech.com StarView SV211K 2-port KVM...
My remote will not work and the tv menu is on the screen and goes through all the diffrent setting options automatically without stopping. TV buttons will not control the menu. Unable to make any setting...
1# First unplug tv,unhook ant.let set overnight.2# Reconect ant.Plug back in.turn tv on with button on tv.let tv run trew all its modes for 5 to 6 hrs.Don`t push any buttons!!!!! It has to reset everything.then try remote,when it starts to work,set new pin code.use your instruction book,to set all blocks to N,,Clear all favorite channels + erase channels in tv 's memory if there in there yet,takes a lot of time.it will keep resetting,remote won't work.let it run awhile. then push exit, hold 5 to 10 seconds remote will eventually come back,check your settings reset them, be sure menu is set to STOP, it may start running threw all its modes again,let run couple hrs, then push exit 5 to 10 seconds to get your remote back.keep trying this. when you think the tv is working right,turn it off for 10 seconds then back on. If it starts resetting, let it run an hr,then push exit again to get your remote back,it has to reset everything,keep trying, took me 3DAYS to get it right!!!!!!!!! the only thing I don't have working is the pic size button,Don't need that anyway. GOOD LUCK.
Jan 17, 2009 | Toshiba 36A43 36" TV
Cant exit menu on 'the box' digital receiver
hi i went in to factory setings and pressed 0000 now am stuck on language and cant get bac to any channels can any1 help us plez
Dec 20, 2008 | Televison & Video
Setting up playstation
The PS50700 uses the PTK195 series chassis. You can switch the TV to the video mode by pressing MENU, press channel down 3 times to highlight "4 Channel", press MENU, press channel down twice to highlight "3 List and Labels", and then press MENU. The current channel will be highlighted, and you will press channel down until you go below channel 1, which is where the video inputs are (VID1, VID2, FRNT). To exit, press MENU, choose "Exit", press MENU and choose "Exit" again, or just wait until the menu times out. An easier way is to get a universal remote that has an "INPUT" button.
Sep 02, 2007 | Proscan PS50700 50" Rear Projection...
Menu keeps popping up
Hi, heres your fix, replace all of the front control board tact switches, part number is 23344443 & have a Merry Christmas, BMW Rider
Aug 24, 2007 | Toshiba 32A43 32" TV
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
534 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
