Question about Exercise & Fitness
Controls are on treadmill does not come on. the treadmill has been sitting for a while.
    Top Expert:
  • 12,223 Answers
Step 1:
use the software calibration see the instruction.
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Step 2:
see the video too.
Posted on Jan 07, 2013
My treadmill got rained on last night and when I plug it in it turns straight on to 11mph even with the safety plug pulled out. Could it possibly go back to normal when it dries out?
Very possible. Suggest you take the electronics apart to help it dry out. Use pressurized dry air to blow water out. I would not just let it sit with the covers on.
Mar 12, 2015 | Exercise & Fitness
Golds Gym Treadmill motor will not start after sitting idle for about a year
see the video and fix it. However after you did this and the problem remain, you must test a) control board or b) replace the old board deck belt.
Mar 24, 2013 | Golds Gym 450 Treadmill Drive Motor
Golds Gym Treadmill motor will not start after sitting for about a year.
see the video and LUBE . However after you did if the problem remain test a) control board see the diagram block b) time to replace the old board deck belt.
God bless you
Mar 24, 2013 | Golds Gym Trainer 410 Treadmill
Proform xp 580 - Does anyone know how to remove the control panel cover? Is there a diagram somewhere of all screws?
Look up your model on IconService.com, they have the user manual, and also the schematics that I use as a Tech. Note that even as a repair tech, I rarely ever get into the console.
Technical note - on treadmills, the top electronic board is actually called a "console". The "controller" is the circuit board that sits next to the drive motor in the bottom housing in front of the drive roller.
Jan 05, 2013 | Proform XP 580 Trainer Treadmill
My t101 treadmill is not working, when you switch it on it does the normal checks then sits at P0, when you try quick start it just moves you through the "time" then the distance then the...
YOU MUST ADJUST THE SPEED SENSOR +reed switch sensor
Tight the flexible cable from keypanel vs display board and then tight the connector from display board and lower board.
See the block diagram.
You will have 3 options:
see the block diagram
12_1_2011_4_38_18_pm.giffINALLY YOU WILL 2 OPTIONS: A) DISPLAY BOARD FAULTY B) MAIN MOTOR CONTROLLER BOARD.
SINCERELY.
Sep 29, 2011 | York Barbell Home Use Fold-Up Treadmill
Treadmill won't turn on after not being used for 6 months
the only on/off switch on that model is located beside the power cord where it enters the lower body area.
Nov 12, 2009 | Exercise & Fitness
I have a Landice L8 and the error code L5???
LS Error on Landice L-Series Treadmills with Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. This error can occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring Corrective Action A) Speed sensor should sit parallel with the flywheel and gap between speed sensor and flywheel should be within 1/16". Adjust speed sensor if necessary.
B) Inspect speed sensor connector to relay board. Check for pushed pins or loose wires. Repair or replace speed sensor assembly if necessary.
C) Inspect upper harness or display cable connector to relay board. Check for pushed pins or loose wires, giving specific attention to pin 5 (brown) and pin 9 (green). Repair or replace display cable if necessary.
D) Inspect speed control wiring:
  1. Checking purple wire from V+ on pwm board to P3 on the relay board
  2. Checking orange wire from P1 on pwm board to P1 on the relay board
  3. Checking brown wire from P2 on pwm board to P2 on the relay board
  4. Confirm P3 on pmw board has no connection
Correct speed control wiring if necessary.
Details about LS Error on Landice Series Treadmills with Belt Movement
Jul 09, 2009 | Landice L8 LTD Cardio Trainer Treadmill
Landice treadmill 05 error code comes on when i hit start
Jun 28, 2009 | Landice L8 LTD Pro Sport Trainer Treadmill
Exercise & Fitness Logo
32 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
