Question about Refrigerators
Not cool the refrigerator
My ICE WORLD Samsung refrigerator model SR-32 NMB well not cool the refrigerator and the freezer is full of ice within a few days, the fan works perfectly
dididsaythat
  • 291 Answers
SOURCE: SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Posted on Oct 12, 2007
fridgetech
  • 473 Answers
SOURCE: refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Posted on Nov 16, 2007
zeusfaber
  • 247 Answers
SOURCE: Samsung Fridge Freezer (Freezer on top)Model SR-52NXA wont cool
Depends a bit on whether the compressor really is running, or if it's just humming because it's got power on the run coil, but not on the start coil.
Have a careful listen to the compressor. If it's making the trilling or gurgling sounds that go with a working compressor, then your problem is probably one of lost gas. Fixing this is not a do-it-yourself job.
If the compressor sounds like it's stalled, the problem may lie with the starter. Replacements are usually cheap enough for it to be worth fitting a new one just to see if it works.
A.
Posted on Feb 28, 2008
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
had same exact problem - followed advice for fixing same problem in similar refrig. took of the back panel off the freezer section - 8 hex head screws - and found the cooling fins all frosted over.
Posted on May 31, 2008
Techsim
  • 59 Answers
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
Samsung RFG298AAWP refrigerator gets warm. I unplug, plug back in, gets cold. Then few days later, same cycle.
Check for icing of the evaporator (cooling) coil located behind the cover on the back wall inside. There is a cooling coil with a fan to supply the cold air for the refrigerator. Otherwise you might have a control board issue. The iced coil is much more likely. There are repair kits for ice build up and/or defrost problems. To get the proper parts for Samsung you must supply all the ID numbers including full model, full serial number and BOM number (if it has one.)
Nov 01, 2016 | Samsung Refrigerators
Where can I get a repair manual for a Hotpoint Fridge
First of all, the model number you gave is not complete. But check you defrost system in the freezer, when the refer section stops cooling, your evaporator in the freezer is possibly full of ice and the fan won't move air through ice. When the refer sections fails to cool, check for a fan in the freezer. If it works, you have a defrost problem and is occurs every 3 - 5 days. The unit should defrost once or twice a day. Good Luck
Apr 20, 2016 | Hotpoint Refrigerators
Why as food suddenly started to defrost in freezer
If the fan is running in the freezer and there is some cooling, the evaporator (cooling coil) is probably iced up due to failed defrost timer or heater.
Jul 27, 2014 | Samsung CoolTech Plus / Basic Bottom Mount...
For Samsung Refrigerator SR-L629EV my freezer
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Jul 19, 2011 | Samsung RF265AA Bottom Freezer French Door...
Hello, we hv the samsung SR-C31NMO samsung fridge. from 2 days the freezer is not working. Same thing had happened few days back, but automatically it became normal. I can hear some sound behind the...
It sounds like the evaporator fan is not working properly. If the fan is stopping and starting it can cause the freezer to become a block of ice.
The fan motor may need replacing
Mar 31, 2011 | Samsung Refrigerators
SAMSUNG REFRIGERATOR MODEL SR-368 freezes and no cooling.
Hi!!! You have a defrost problem.You need to change the defrost timer mechanism.In Samsung frig the defrost timer is in the main pc board..Good luck..
Jan 05, 2009 | Samsung Refrigerators
Chilled water stopped .chiller frozen in bottom of fridge
SR-32 EMB MODEL, FREEZER OK, BOTTOM NOT COOLING PROPERLY. ADVICE SETTINGS
May 28, 2008 | Refrigerators
Refrigerator compartment not cooling
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
