Question about Microwave Ovens
Replacement blade 17 cm for cook works food slicer model no 422/0824 (D)
5 Suggested Answers
angelo_mlc
  • 1035 Answers
SOURCE: I have model 1101 food
Hi. If you are asking on where to buy the gear. Here's the link. Please click here.
Posted on Sep 15, 2010
  • 248 Answers
SOURCE: rival slicer model 1101E/7 plastic
try-abtecparts.com
Posted on Oct 12, 2010
tunde007
  • 2382 Answers
SOURCE: I have a rival food
Hi, you can get it from this LINK
  • 8909 Answers
SOURCE: My microwave has melted a huge hole 17 cm in
Nothing is wrong with the microwave, the plastic cover was either not microwave suitable or a splash of grease/oil/food was stuck to the plastic and melted it.
Posted on Jan 24, 2011
Testimonial: "Awesome response!!!great help!!!"
Bosch microwave oven,turntable not working,food not heated
Even if the turntable isn't turning, the oven should still heat the food but it will be uneven cooking. I would suggest that the unit is not "microwaving" This is usually the high voltage capacitor, fuse or diode failure. You will need knowledge of how microwave ovens work and specialist tools to test these. If you don't, I would suggest you get a tech who does. There are extremely high voltages in microwave ovens.
Feb 23, 2015 | Bosch HMT75G451B Stainless Steel...
The oven has trouble ligting,and make,s a boom sound when lighting
Magnetron
If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Enter your model number to see parts for your microwave.
Help me find my model number
Exhaust Fan Motor
If the microwave is loud when running the fan motor might be
Stirrer Motor
If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor
If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Apr 02, 2013 | Microwave Ovens
Need schematics on magic hostess meat slices model mh7e, I think I'm missing a barring behind the blade gear.
The Magic Hostess slicers are the same as Rival 1101 series slicers. What you probably are missing is a friction reducing washer that mounts between the blade and blade head (housing). I offer reproductions of this part, photo attached; these reproduction washers are a different color but functionally equivalent to original. If interested, contact me at lallin@juno.com
The photo I uploaded doesn't show up for some reason. To see photo of blade washer and usage, see https://flic.kr/s/aHsjuXYKep
Sep 16, 2011 | Microwave Ovens
I need an instruction manual for Ronson Food slicer model 87003 please
Bronte,
Did you ever get a manual for your Ronson food slicer, model 87003?
I have 1 of these slicers & am needing a manual as well.
Apr 19, 2011 | Microwave Ovens
Have a Proctor Silex small crock pot, no manual. Setting are Off, 1, 2 and "AutoShift". There is no timer. How can it be set to (1) be sure to cook the food long enough and (2) stay on / keep...
You can find a Use and Care Guide for your product at the following website. You will need to locate the model number of your crock point. Select Slow_Cookers in the product field; Select your model number and click on Submit.
A pdf file of your Use and care Guide will be provided; note they are scanned files and some are of poor quality.
Model 36400 has a similar control to your model. The Guide provides a table of the time to cook at settings 1 (low), 2 (high) and Auto Shift. Auto Shift starts at the high setting and then decreases to the low setting. The time to cook at Auto shift is in between the time taken at the low and high settings. The low and Auto Shift settings are designed for long cook times at a simmer. On the high setting some foods like soups will come to a boil and may need stirring during cooking.
The crock point has no auto turn off and will keep foods at a simmer when on the low or Auto Shift settings. With some practice you will learn how much time this will take for various foods.
The sure way is to use a tip sensitive digital instant-read thermometer to check the final temperature of the food. Check according the guidance provided by the Partnerships Food Safety Education:
http://fightbac.org/safe-food-handling/cook/127-cook-heat-it-up-chart?format=pdf
Feb 06, 2011 | Microwave Ovens
My microwave has melted a huge hole 17 cm in diameter in the plastic cooking cover - what is wrong with the microwave.
Jan 24, 2011 | LG LMV1630ST Microwave Oven
I am looking for a part to my chefmate slicer model #GC510. Is there antwhere that just sells parts?
Globe Food Equipment has a website that gives a parts catalog and a pricelist for the slicers: www.globeslicers.com The parts catalog for your slicer is at : http://www.globeslicers.com/Editor/assets/globe_docs/gc510%20catalog%204.15.8.pdf
If you get your part number from there, you can price compare at some other parts houses (such as onesharpstore.com ) by running it through google.
Hope this helps
Jul 04, 2010 | Microwave Ovens
Farberware v-blade mandoline slicer instructions - nothng in or on box - how do I use and put together
I bought a faberware V-blade Mandoline slicer and I would like to have an instruction manual for the blade usage please
Jun 21, 2010 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
