Question about Keurig Platinum B70 Coffee Maker
Coffee is way to strong
The coffee is just way to strong. I even made a larger cup and poured half of it out and made it again using the smaller cup and still to strong. Is there anyway to make it not so strong or any k cups that are not as full?
  • 1,511 Answers
Change the settings to Large Cup.
Posted on Jan 31, 2014
  • 18 Answers
SOURCE: will not brew a full cup
Mine started off this way, then quit running any water through. I overcame the problem with a reusable K-cup. They are available online and at some national chain stores for about $15.00. It's a little more inconvenient than K-cups, but better than throwing out a $150 coffee maker.
Posted on May 21, 2009
SOURCE: My machine only brews 1/2 cup of coffee. I have
I had some coffee grounds stuck up in the cone shaped hole that the water comes from at the top. I had to use a very long toothpick but it broke up some of the grounds that happened to get caught up inside. Before doing this, I went through 24 oz of vinager ;) .. the toothpick worked!
Posted on Sep 30, 2009
SOURCE: My Keurig B60 is Suddenly Brewing WEAK Coffee
I don't have a solution but have just experienced the same problem and am baffled. I am using the same beans same grind. In fact using the exact same grind it went from great one day to weak the next day.  I always run it for 15 - 16 secs to get the shot and that hasn't changed. Pressure and temperature appear fine. I cleaned the top of the top filter which was a little dirty but not seriously bad - no change. The coffee flow which is normally chocolate coloured to start with is just mid brown.
Posted on Feb 28, 2010
SOURCE: When I use or attempt to have the Keurig serve a
I had the same problem and my Keurig is only two months old. I read advice from another user and called Keurig this morning. They are replacing the unit for me within 3 to 10 days. All they asked for was the serial number, which is very easy to find. Good luck!
Posted on Mar 03, 2010
SOURCE: Sometimes it pours only 1/2 a cup
clean the cup holder and clear the sharp tube . These get clogged from use, especially from cocoa
Posted on May 17, 2010
HOW DO I CLEAN THIS COFFEE POT
I suggest you use vinegar acid.
You need a solution with half part water and half part vinegar acid.
1) pour 4 cups of water into your coffee machines water tank.
2) pour 4 cups of vinegar acid into your coffee machines water tank.
3) turn on your coffee machine to decalc.
4) refill tank with clean cold water and let it run through ( 2 times)
REMEMBER !!! ALWAYS POUR ACID into WATER !!!! AND NOT THE OPPOSITE !!!
If you pour water into acid it can explode and make terrible damages and cause chemical burns!!!
Hope this will help ypu
Jun 28, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
I have a coffee maker that makes 36 cups of coffee. How many cups of ground coffee should I use to brew 36 cups?
I would ordinarily use half the amount of scoops of coffee as the amount of cups the coffee maker makes. A scoop being a Tablespoon of ground coffee. Less if you want it weak and one or two more if you want it very strong.
Apr 09, 2011 | Vacuums
My keurig coffee maker is flashing the words DE SCALE. What does that mean and how do I fix it?
"Scale" is deposits of minerals, etc. normally found in water. Boiling a container of water (in a pot, or coffee maker in this case), leaves small amounts or "deposits" of these minerals on and near the actual heat source. If not removed, they can slow brewing time and more importantly, adversely affect the taste of coffee.
Descaling should be done at regular intervals to prevent this from happening. Your machine lets you know when to perform the descaling task. There are a number of products sold in your supermarket that will do this for you - but one of the least expensive; and just as effective - is to use white vinegar. Here's how to do it:
1) Drain your Keurig coffee machine over a sink.
2) Fill the machine with undiluted white vinegar.
3) Run the brew process at least four times, pouring the cups of vinegar back into the coffee maker.
4) Optionally, let your Keurig coffee maker sit for a few hours, then run the brew cycles again. Pour the vinegar into the sink and drain any remaining vinegar.
5) Fill your coffee maker with fresh water. Run multiple brew cycles with fresh water each time to thoroughly rinse the machine before returning to normal use.
That's it!
I know this will help & good luck. Please rate my reply - thanks!
Feb 06, 2011 | Keurig Ultra B50 1-Cup Coffee Maker
May 17, 2010 | Keurig Elite B40 Coffee Maker
When I pour water into (empty) pot to fill. Bunn coffee maker
If you pour water into the machine, and water comes out, then the reservoir is full of water. There is no way the water can bypass the reservoir and go directly into the pot.
Apr 26, 2010 | Bunn 10 Cup Home Coffee Brewer
Strong plastic odor in West Bend coffeemaker
oh yes. This must be a new machine. I would recommend pouring and draining boiling water in the maker several times. You can also use vinegar, but again it has to be rinsed and refilled and rinsed again with boiling hot water.
Jun 11, 2009 | West Bend 56860 10-Cup Coffee Maker
Vanishing water
Is this problem happening by chance after you have used the maker? If so the heat from the previous use may be causing the water to steam from being so hot and thus causing the pot to be only half full. the hotter the maker the more water evaporates. You might need to let it cool down in between pots.
Joe
May 19, 2009 | Bunn 10 Cup Home Coffee Brewer
First cup of the day ony fills half way
Have you cleaned the exit needle? Seem to be clogged up, more info here: http://www.keurig.com/help/B60_Use&Care_guide_spreads.pdf
Nov 16, 2008 | Keurig B60 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
64 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
