Question about Cell Phones
MY USB DOES NOT WORK
WHEN I OPEN USB APPLICATION IT CLOSE BY ITSELF
    Problem Solver:
  • 9 Answers
1. You should scan your USB with anti-virus software
2. Check another application (if it work, your app may not be able)
Posted on Jan 07, 2013
I have toshiba c660. its built webcam was working perfectly. but few days back when i used it a blue light turned on but after closing the web cam blue light was still on but light was dim. when i opened...
Restart the computer and see if the blue light comes back on by itself. If you are still having problems visit the Toshiba support site for your country (or region). Download the webcam application compatible with your version of Windows (32 bits, 64 bits) and reinstall the application. Test it using the Start>Toshiba>Utilities>Webcam Application, or the Face recognition software. You close the running application by clicking the x at the top right corner of the application window
Oct 27, 2013 | Toshiba satellite c660
Tip
Close Application at Once
When you're done working on your computer for the day, you probably close each open application one-by-one. If so, chances are that you've wished that you could close all you open applications at the same time
To do so, hold down the [Ctrl] key and click on each application button on your taskbar. When you do, you'll notice that each button remains selected. Once you've selected all the application buttons on the taskbar, right-click on any one of them and select the Close Group command from the shortcut menu. When you do, all your applications will close. If you have any application in which an open file hasn't yet been saved, that application will prompt you to save the file.
on Apr 25, 2010 | Microsoft Windows Server 2003 Enterprise...
Webcam doesnt work
I hv. pressed and opened the kingston 4gb dell pendrive now m nt able 2 close it.
make sure there is no application using it. sometimes there might be some process using it but not showing up on task bar or systray. you can use task manager to kill those process if you can find them. you can also open the USB device box by double clicking on the USB device icon in systray and then select the top usb device and click on the close button, or try the drive letters in that box if the first approach does not work. or you can try open device manager and remove the USB devices from there if necessary.
Jun 08, 2011 | Computers & Internet
When i turn it on it just shows the ILO symbal and flashes
Hello.
In order to fix Your iLO Mp3 Player please follow these steps:
  1. Please connect the player to a rear USB port on the computer. The display should show “USB Connected”. (If not, please press the power button.)
  2. Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible.
    Download the Firmware.
  3. Click Open to initiate the download.
  4. Double click on the ILO or Siren folder icon. There will be 14 icons.
  5. There will be a Setup icon that looks like a box with a blue line on it; please double click on this.
    Then click Run - this will open the Install Wizard.
  6. The Install Wizard has the instructions on the screen as you go through it.
    Once the firmware has installed, please click the Start menu, then Programs.
  7. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware.
Additional Tip: The player itself requires a lot of power while flashing the firmware. We suggest disconnecting all USB devices from the computer except the MP3 player and mouse; you can reconnect your keyboard once the firmware has been flashed.
Good Luck.
Nov 03, 2009 | iLO (2 GB) MP3 Player
Blackberry 7290 device error 400 how solve this problem
When adding, deleting, or updating applications on your BlackBerry smartphone, your BlackBerry device resets itself and stops responding.You receive the following error message:
Device error 400
  1. Disconnect your Blackberry smartphone from your computer.
  2. Open BlackBerry Desktop Manager.
  3. Open BlackBerry Application Loader.
  4. Reset your Blackberry smartphone.
  5. When the LED indicator has turned on, reconnect the BlackBerry smartphone to the computer.
  6. Click Next.
  7. On the following screen you will see either USB:Unknown or USB:; click Next.
  8. Select the required applications from the applications list and click Next. The firmware is loaded to your BlackBerry smartphone.
Warning: The following procedures will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the data on your BlackBerry smartphone before performing this procedure.
Nov 01, 2009 | RIM BlackBerry 7290
Close the other video streaming application to start video
Your camera is already online. Double click the camera icon in the lower right task bar and it will work. That is the problem, the program is trying to run twice. Again, the camera is online and working and the access to it is in the task bar at the bottom. You, of course, can change these setting if you like.
Jun 21, 2009 | Dell Studio 1737 Laptop
Could not start the camera. Close other applications and try opening the camera again
Very gently take the back off of the Blackberry, slightly push in on the camera itself, reboot and the camera should work.
I found out the hard way selling my phone on eBay only to have it returned because the camera didn't work. It's a hardware issue and not a software issue.
If it's still under warranty, try and get a new phone, otherwise --problem solved.
Feb 20, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
HP 5550. Stuck in install loop
uninstall previous printer driver and resintall again the cd driver
Feb 01, 2008 | HP DeskJet 5550 InkJet Printer
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
