Question about InFocus Proxima UltraLight X350 Multimedia Projector
How do i check the number of hours left in my lamp timer
  • InFocus Master
  • 3,904 Answers
It will be in your setup menu. Most likely under settings/setup but could be under video or maintenance. They shift around where it is all of the time so it will just take some looking around in the menus
Posted on Jan 07, 2013
How do i check the status of my lamp life in my rca rled4633b tv
You have to check its lamp timer. Electro help . Check this link to know more. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 07, 2014 | Televison & Video
How to check lamp timer
Bulbs do not really have a certain lamp life they only have a lamp timer. You will want to be sure you can get a replacement lamp they can go anytime between 0 and 6000 hours.
Apr 22, 2013 | Mitsubishi SL2U Multimedia Projector
I have a Sony VPL-CX61 Multimedia Projector. I just changed the lamp and I cannot get the "please replace lamp" message to go off.
When you use a projector it automatically keeps a timer of how long the lamp has been used for. The message that comes up on screen saying "please replace the lamp" comes up not because it's some how sensing that the lamp is getting old, but because the lamp hours gets to a certain number (usually up around 1500 hours). Because of this when you replace the lamp you need to reset the lamp hours counter, or the projector doesn't even know you've changed it. Every projector does it this way, and they all do it a different way, I googled the model you gave us and found this set of instructions on how to do it, so give it a go.
Reset the lamp counter hours of operation for the projector SONY VPL-CX61
Using the remote commander while the unit is powered up, press "ENTER", "ENTER", "LEFT"
and "ENTER" in sequence. A prompt will appear on the screen asking if you wish to enter the factory mode.
Press the "UP" key on the remote and the unit is now in service mode. This sequence will add two new groups
to the customer setup menu. Press the "MENU" button to view.
Whenever the lamp is replaced, the lamp timer should be reset. With the unit in the "factory" mode, press
"RESET", "LEFT", "RIGHT" and "ENTER" on the remote commander. Verify the lamp hours have been reset to
zero in the service menu.
Hope this worked for you,
Mar 23, 2011 | Sony VPL-CX61 LCD Projector
I have a First Alert model 610 timer. It is an older model and I need the instructions for it.
I called First Alert @ (800) 323-9005 and they faxed me the instructions for Model LS510 which is the same and got it working. They will mail it too but not email. Choose Fixed or Random mode. Choose how many hours it will stay on after dusk. Turn your lamp off and unplug the lamp. Plug lamp into timer. Put function in Fixed or Random position. Put hours on switch to number of hours you want it remain on after dusk. Plug timer into the wall outlet. Turn the lamp's switch on and Timer's LED light should be on and the lamp should be off. Turn the lamp's switch off then on again TWICE. The second time you turn the lamp's switch on the bulb in the lamp will flach on then off quickly. This indicates that the Timer is controlling the lamp's operation. Leave the lamp switch in the ON position. The timer is now set for automatic. I hope this helps.
Jan 06, 2011 | Vacuums
How to find the timer lamp to see hours used ?
Good news ! I solved the problem !
Go to the bottom ''Up-Down-Left-Right'' ON the projector.
Hold the bottom ''UP'' 30 sec. approx. and then, you can see how many hours the lamp are used !
I hope you understand my ''bad'' english !
Have a nice day !
May 11, 2009 | Televison & Video
I wanted to know how to tell how many lamp hours are left on a NEC VT47 LCD Projector- also how does the lamp hours work? if you have 2000 hours does that mean the lamp life is over or you have 2000 hours...
if the bulb has 2000 hours that means it is supposed to last 2000 hours of continual use. It is hard to keep track of the lamp hours though unless the projector has a timer built in. It depends on the manufacturer as to if it is telling you 2000 hours left or used. There should be a way to switch this. But a lamp rated for 2000 hours has 2000 hours of being on is expected lifetime
Jan 14, 2009 | Computers & Internet
Benq PB8220 lamp used for 375 hrs shuts projector automatically
Hi Ash, check your manual as by memory you can do this by a 2-3 button reset via the remote control. Regards Kevin Andreassend. http://www.iceav.co.nz iceavtech@gmail.com +64-9-4142348
Jan 05, 2009 | BenQ PB8220 DLP projector 2200 ANSI lumens...
Lamp replacement
Hi there
You need to reset the lamp timer.
Mar 11, 2008 | 3M (EP7640ILK) Projector Lamp for MP7640
Lamp timer reset
Found in the owners manual.
It's important to reset the Lamp timer after replacing the lamp since the Lamp timer
will trigger the warning message. This can be done in Standby mode by pressing the
following sequence within 5 sec.
RESET, Left Arrow Key, right Arrow Key, ENTER.
This is also explained in the operation manual of the Lamp.
Jan 25, 2008 | Sony VPL PX11 Multimedia Projector
How to check lamp hours on xf-45 or xf-35?
On the XF-45, you push the "UP" button and then the "Menu" button and hold both of them for approximately 20 seconds. After that you will see a bunch of numbers in the top left hand corner of the screen. Using the Left and Right arrow keys, move the "Group" number until it reads 111. Then using the Up and Down arrow keys to scroll through each lamp (0-3).
If you move the "Group" number to 110, you can see total number of hours that socket has run.
Jan 22, 2008 | Sanyo PLC XF45 Multimedia Projector
InFocus Proxima UltraLight X350 Multimedia Projector Logo
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
