Question about Belkin F1DK102P 2-port KVM Switch
Aten 2 port usb kvm switch won't work on win 7 suse
dcolvard
  • 65 Answers
SOURCE: How to switch between computers
Do you know which model you have? Most KVM's switch by hitting Scroll-Lock twice kinda fast and then the port# you want to switch to. In your case it would be 1 or 2. If that doesn't work let me know what model you have and I will give you a definate solution
Posted on Mar 20, 2009
jbjennings
  • 24 Answers
SOURCE: I have a Viewsonic VS11531 27.5 inch monitor I use
In the link below, on page 9 of the PDF the maximum stated resolution of the KVM is Up to 1920x1440 @ 75Hz.
http://cache-www.belkin.com/support/dl/p75457_f1da116z_man.pdf
The monitor supports up to 1920x1200 @ 60Hz.
It sounds like there is an issue of synchronization between the monitor and KVM. This will force the monitor into a lower resolution to sync them. You may want to check with Belkin to see if there is a firmware update for the KVM. There may also be a driver issue with one(all) of the video cards on the system. I recommend updating the drivers on all affected machines with the monitor connected directly to the individual machines. Rather than using generic drivers, I would use the drivers downloaded from the manufacturer of video cards and from Viewsonic for the monitor.
Posted on Nov 03, 2009
  • 4 Answers
SOURCE: Hi how can i switch computers using Belkin
Try tapping the scroll lock key twice and then the up or down arrows, or tapping the scroll lock key twice and then the "s" key to auto scan.
Posted on Dec 05, 2009
  • 39 Answers
SOURCE: How do I switch between computers using old Belkin 2-port KVM?
if i remember right, hitting the scroll lock key twice, and then pressing 1 or 2, depending on which box is your xp box.
hope this helps
Posted on Feb 16, 2010
Testimonial: "Tony354, Thanks so much. Those were exactly the keys to press. Not exactly intuitive...so I really appreciate your mental retention."
SOURCE: Scroll Lock doesn't work /BELKIN 2-PORT KVM SWITCH
What operating systems are these? Have yout ried hitting scroll lock 4x instead of 2x?
What brand/model of KVM are you using?
USB or PS/2?
Posted on May 06, 2010
Why won't my Logitech Traackman MArble FX work with Windows 7?
If you are trying to convert your Logitech Trackman Marble FX from PS2 to USB so it will work with Windows 7, you can't just convert the port type - you have to get an "adapter" that converts the PS2 signal to a USB signal. See for ATen - UC 100KMA. WEB SIte:
http://www.aten.com/products/KVM/KVM-Modules-&-Accessories/PS2-to-USB-Adapter~UC100KMA.html#.U5sYrCi4NAE.
It allows you to convert a PS2 keyboard and PS2 mouse/trackball with the one device. It's what I use and it works just fine. The regular $2.00 port adapter was useless.
They are on EBAY sometimes for $20 or so. GOOD LUCK. :)
Jun 13, 2014 | Logitech Trackman Marble FX Trackball
I have Aten USB KVM Switch, and i lost the user guide. I need to switch between the Pc's, what is that hot key i have to press to switch it. M.J Regards
You can check out here- there's a lot many Aten usb kvm switch, check your model and find out how to resolve your problem http://www.kvmstuff.com/server-management/kvm-switches/usb-kvm-switch.html
Jan 11, 2011 | Altusen Aten CS64U--4 Port USB KVM...
Brought a CS62US and Mircosoft KB with mouse. When USB combo plugged on the left USB, only KB is worked together with switching function. When USB combo plugged on the rigth USB, both KB & Mouse worked...
Unfortunately, this switch has a dedicated port for keyboard that listens for the keyboard keystroke. You MUST plug the keyboard into the dedicated keyboard port on the KVM switch for the hotkeys to work. I recommend putting the mouse that comes with your keyboard to the side, and using another mouse, plugged into the dedicated mouse USB port on the switch. Not the prettiest solution, but some of those mouse/keyboard combos have some funky hardware!
Feb 17, 2010 | Altusen Aten CS62U-2 Port USB KVM Switch
XP Display turns off after switching to Win 7
search for WIN 7 & KVM switch issues... you will find thousand of hits, because WIN 7 has one unique feature where it disables internal and external ports if these are not in use.
In a KVM solution setup this would mean, while you are connected everything is fine, now when you switch over to your (Lets say) WIN XP and work for 30 minutes on it... and then switch back, WIN 7 might have already scanned and seen that the USB port where the KVM cable comes in is IDLE... so it disconnected it... you cannot get it back until you reboot your WIN 7 system. Its not the KVM solution is one of those Microsoft wonder weapons that breaks what has worked for 20 years
Jan 17, 2010 | Avocent SwitchView 2-port KVM Switch
Can't switch
Make sure your keyboard and mouse are plugged into the correct usb slots on the switch. One is labled for keyboard, and the other for mouse. If you mix these up, those hotkeys will not work! :) Also, try tapping scroll-lock twice to switch. It's much better than trying to use the num-lock + and - keys, since it's only a two-way KVM. Tapping Num-lock twice automatically switches, so you don't have to hit multiple buttons.
Oct 24, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
Not working
Make sure your keyboard and mouse are plugged into the right USB ports on the switch. If you plug the keyboard into the mouse USB port the hotkeys will not work! The USB ports on the KVM switch are labeled under each port, with a mouse and keyboard icon respectively.From the Quick Start Guide/Manual: The Numlock hotkeys are listed as:
[Num Lock]+[-] [1] Switches to output 1
[Num Lock]+[-] [2] Switches to output 2
[Numlock]+[-] [A] Auto-scans and chooses which ever port is connected.
Alternatively: Tap [Scroll Lock] twice to automatically switch between ports.
Note: I've never been able to get the Numlock key combinations to work correctly. I always just use double-tap [Scroll Lock] trick to switch.
If you get stuck with your scroll-lock and Alpha lock lights flashing, just hit [Esc] to fix it.
Source: http://www.aten.com/download/download.php#productGuide (Scroll down to "Quick Start Guide" and choose CS62U out of the drop down).
Oct 03, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
Hi, the CS62U is connected with an HP8750 (win2000) and a MSI WIND NETTOP 120 (win XP home). It works perfectly with the HP desktop but the mouse is not responding anymore.
Try this:
1. Disconnect your HP computer, so that only the MSI Wind is connected.
2. On the keyboard, hit [Numlock]+[-] then press [A] (this will auto-search for the computer that's connected, and connect both keyboard and mouse to that port).
Give XP a minute to detect new hardware. If XP does not detect the mouse, try plugging the mouse into a port directly on your netbook. If XP still does not detect the mouse, it's XP that's not detecting your mouse properly, not the kvm switch. :) If it does detect it, you should be able to then plug it back into your kvm switch and it should work at that point.
Note: if you get stuck with lights flashing on your keyboard, just hit [Esc] on the keyboard. That will reset the KVM switch.
Hope this helps!
Sep 24, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
Lost the instructions for the CS62U switch
here is the link to the aten website.
go to the select quick guide section and locate the model # in there,
p.s. its cs not c5
Aug 15, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
Belkin F1DK102P 2-port KVM Switch Logo
44 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
