Question about Frigidaire Freezer Refrigeration White Upright Large Manual Defrost Freezer Model FFU2124DW
Leak Electrolux ffu14fc4aw3 - Frigidaire Freezer Refrigeration White Upright Large Manual Defrost Freezer Model FFU2124DW
Why does oil leak at the bottom of the Gibson refrigerator door
Hello Susan;
My name is Peter. I am a retired field service refrigeration technician.
You do not have any oil in your system with the exception of a few ounces in the bottom of your compressor. This is not your problem.
You have a water leak. The water will run across the bottom coils and the floor. By the time it reaches the front of your unit it looks oily.
Pull you unit out. Make sure you raise the leveling screws in the front first.
Remove the lower back cover. There are a few screws holing it on.
1.) Inspect the drain pan. Is it leaking?
2.) Inspect the water shut off valve. Is it leaking.
3.) Inspect the plastic tubing to your water filter, ice maker and water dispenser. Plastic tubing will dry rot and crack over time due to the heat.
4.) Have someone press your water dispenser while you observe for leaks in the back.
Feb 26, 2015 | Electrolux Frigidaire Tappan Gibson...
Hi. We've got used ("as is") Electrolux Frigidaire
Not sure if u still need help but the first thing I would do is remove the grills on the front and back and vacuum out the fins on the condenser...dust and grime collects here and will cause the unit to overheat and not cool properly....sometimes an air compressor can be used or air in a can for the hard to reach places.
Tr this and see what happens...good luck
Mar 31, 2017 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Electrolux freezer only works on super
you should read the catalogue.
Mar 08, 2013 | Electrolux Freezers
FFU14FC4AW3 keeps on running. Will not stop, even it is full and everything is frozen solid.
Try checking the Temperature Control:Testing Temperature Control
Test the control for continuity using a multi tester. Set the multi tester to the ohms setting X1. Place a probe on each terminal. Turn the control to warmest setting or off. The multi tester should display a reading of infinity. If the control does not have an off position, the reading should be near the infinity end of the scale. Now change the control to the coldest setting and retest. The display should read zero ohms. If the control does not pass both of these tests, the switch should be replaced.
Aug 27, 2012 | Frigidaire Freezers
Freezer wont shut off
This is more than likely a sign of Freon issue, where the machine runs non stop trying to reach a temperature that it never does. Even though things are freezing, like meats and such, they have water in them and that freezing point is 32 F. Check the ice cream if you have it in there, does it seem softer than normal, or not as solid as you like. If so, you have a leak and a tech should be called
Jun 22, 2012 | Electrolux Freezers
How to recharge freezer electrolux FFH17FC7CW0
HI, It is a big job to recharge a unit. If it need recharged, it means there is a leak. Do you have any cooling at all? If this a self defrosting freezer? If it is self defrosting, make sure there isn't any frost building up on the evaporator panel.
Vic
May 21, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer bubbling coming from top of freezer inside
hi thanks for the question .when the fridge shuts off the freon is boiling in the freezer that's what makes it cold is the boiling so what your hearing is normal you don't have a leak thanks the appliance doc
Sep 28, 2008 | Electrolux Freezers
Electrolux 23
Go to
this page at devicemanuals.com
and find your model number in the list, click on your particular model, then follow the instructions to download the manual.
Mar 17, 2008 | Freezers
Freezers Logo
35 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
